Like Tree24Likes
Old 10-20-2011, 08:17 AM   #826
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Originally Posted by Jonny5 View Post
I put 6 hole pistons in and plan to make some 5 and 4 hole pistons to get a bit more pack.
Originally Posted by Jmuck69 View Post
you could try gluing some of the holes closed.
That won't affect pack. Pack you get from the size and shape of the holes and how they create turbulence... not the number of them.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 10-20-2011, 08:20 AM   #827
Super Moderator
So I TRIED, and I TRIED, and I TRIED, and I TRIED, and I TRIED to build my shocks without any air in them, and I just can't do it. I use to pride myself on being an expert shock builder with whatever kit I was currently running... but these shocks sound like they have been leaking for a year
"squish smoooosh.. squish smoooosh.." (Thats what they sound like... towards the top of the stroke)
Heck, I can even build an AE shock perfectly velvety smooth without an ounce of air in them... Anybody figure out the magic secret to these guys?
- RCSpecialties -
Old 10-20-2011, 08:24 AM   #828
Jmuck69's Avatar
Are you putting enough oil in them or putting a drop or two in the cap before sealing them up?
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 10-20-2011, 08:24 AM   #829
Super Moderator
Originally Posted by jamminjim View Post
manual needs some updates
Yep.. for those of you about to start your build, there are a few mistakes. The length of a pair of screws up front is wrong... (this had me digging all over the place for the right screws) and all the little baby screws are labeled as needing a 1.5mm allen, when they are actually 0.5.... and there are some others, but nothing that will keep you from finishing the build.
- RCSpecialties -
Old 10-20-2011, 08:25 AM   #830
Jmuck69's Avatar
My new Orion R10 pro and setting box just arrived in my office! This is going in the 210.
B6D | B64D
Old 10-20-2011, 08:26 AM   #831
grapejuice's Avatar
Trader Rating: 132 (100%+)
The best thing I have figured is when compressing the shock shaft to bleed them, don't push it all the way in before putting the bleed screw in, leave about 1/4" of shaft showing and hold it so oil is up to the top of the bleed hole, then put the screw in. Usually works for me and still gives very minimal rebound.
MHOR RC Raceway / 5280 Raceway
grapejuice is offline   Reply With Quote
Old 10-20-2011, 08:28 AM   #832
Bobby Z's Avatar
Wow, no pictures of the 210 from new owners.
Bob Zahn
Sponsored by TLR - Horizon - Spektrum - Orion - AKA
Bobby Z is offline   Reply With Quote
Old 10-20-2011, 08:28 AM   #833
jzemaxx's Avatar
Anyone try one of these on a dry loose track?? I have tested the Losi 22, and also the B4.1. The 22 flat was WAY better and actually had rear traction in dry and loose conditions, where the B4.1 would kick out bad under accel.. Wondering how this car will do or if anyone has even tried it yet?
Kyosho MP9 TKi2 Tekin
Kyosho MP9 TKi2/3 Novarossi BTT
jzemaxx is offline   Reply With Quote
Old 10-20-2011, 08:29 AM   #834
grapejuice's Avatar
That too, make sure to have the shock shaft about half way in and have enough oil as to where it is about to spill over so there is a bit of a bubble shape before screwing the cap on.
Old 10-20-2011, 08:31 AM   #835
Super Moderator
Yep, just like my AEs, I fill the body completely, and the cap completely, side by side... screw them together as fast as I can, and the shock is locked up. put pressure on the shaft while backing out the bleed screw till the extra oil is bled out. then usually that has to be repeated a couple of times till the cap can be fully threaded.
you would THINK the process would introduce no air, but alas... nasty squeky shocks at the top of the stroke...
what am i missing?
- RCSpecialties -
Old 10-20-2011, 08:32 AM   #836
Super Moderator
Yeah... i think you're right... I was trying to get every ounce of rebound out of the shock, and inevitably, somewhere towards the end... air gets sucked back in.
- RCSpecialties -
Old 10-20-2011, 08:56 AM   #837
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
Ok here's how I do it. I take the shock body and fill it up, bleed out all the air, let it sit for at least 2 minutes to make sure there is non trapped in the body.
Now take the shock cap, install the screw just enough that it won't fall out, say 3 turns.
Next hold the body very steady and fill it up enough to where there is a "dome" of oil. This will dome up enough to stand above the body so don't spill it!
Next screw the shock cap down while still keeping the body 100% upright. DO not lean it over at all. Snug the cap down fully.
While still holding the shock up right loosen the screw while pushing the shock shaft down onto the table SLOWLY! DO not go fast, the slower the better here. If you've done this right there will be a very little bit of oil from the front shocks coming out when bled. The rears will displace more oil so more oil will come out of the bleeder so don't worry.
The biggest part of this is to never never never lay the shock on it's side. Keep the air at the top of the shock cap at all times.
In the end you will always have some air in the shock since they're emulsion shocks. But you should be able to get the air/oil to mix within 2 shock cycles and the "noise" should be gone.
If this doesn't describe it well enough let me know and I will take pictures.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,KoPropUSA,JConcepts,Avid RC,MIP,SikLidz,ImagineItGraphx, FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 10-20-2011, 09:00 AM   #838
Trader Rating: 19 (100%+)
what am i missing?
I found it helps to tilt the shock so that the bleed hole is pointed up. I think if the shock is vertical a small amount of air gets trapped in the cap. Also, when building new shocks i usually fill them up and stroke ot a few times and then dump it and start over so that I get every bit of the body/cap covered with oil. Then refill and bleed them.
Serpent America/Desoto Racing- www.serpentamerica.com
TrakPower Speed Equipment- www.trakpowerusa.com
B Fast RC Performance- www.bfastrc.com
Futaba | Strictly R/C- Norridge, IL
Thank you all for the help and support!
Jonny5 is offline   Reply With Quote
Old 10-20-2011, 09:09 AM   #839
Hmmmm. Explanation there? I figured less holes would create more pack along with more roll resistance since the same amount of oil has to travel through less holes.
Old 10-20-2011, 09:16 AM   #840
t0p_sh0tta's Avatar
Trader Rating: 35 (100%+)
Are these shocks the same as the 410's? If so, I could never get them smooth.
They'd be smooth as glass until 75-85% compression, and SQQQQUUUIIIISSSSSHh.
I've met some of the strangest people while playing with my toy cars...
t0p_sh0tta is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16564 08-19-2017 05:06 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
jcr
