Like Tree26Likes
Old 10-24-2012, 07:39 AM   #8371
Trader Rating: 520 (100%+)
Originally Posted by dolfns1 View Post
Want to buy 210 but im being told not too. Doing sc now never owned a buggy the 210 being highly tunable i could mess it up. Indoor dirt clay track is where ill be running. 210 looks awesome will get one a some point but should i start with a b4.1 .. opinions. & thoughts greatly appreciated thanks.
IMO you are getting some biased advice, unless you run on many different tracks, once you get a base setup established, the only tuning you really need to do will be slight changes. Just because you have more tuning options available, doesnt mean you will need to use them on a daily basis, but it is nice to have the abilility.
flame56mx is offline   Reply With Quote
Old 10-24-2012, 07:54 AM   #8372
zipperfoot's Avatar
Trader Rating: 16 (100%+)
In the last six months I have owned the Losi 22, B4.1, and the DEX210. I like the 210 the best so far. I consider it a cross between the durability and solid feel of the 22, with the responsiveness and steering of the B4.1.
Buy it, build it per instructions, do the four hole piston thing, upgrade the steering brace, and you will be good to go.
Owning a buggy teaches you the importance of tire selection, weight placement, springs, pistons and oil, etc., but it is by no means something you could mess up. I had my buggy dialed with minimal effort, but it did take a little time to find the right springs, piston size, and oil to suite the tracks I visit. Just like any other car.
The practice thing is where I suffer.
zipperfoot is offline   Reply With Quote
Old 10-24-2012, 08:27 AM   #8373
Autocratic's Avatar
Trader Rating: 26 (100%+)
For anyone that has issues with the transmission binding when tightening the motor plate screws, were you able to resolve the issue, and how?
One thing that I haven't been able to get right on this car is the motor plate screws backing out, causing the slipper assembly to bind since the plate is coming loose. I've done a few things to try and keep the screws tight, while at the same time having the transmission spin free, but nothing has been a permanent solution.
Thanks to my sponsors for 2015!
XFactory RC | Proline Racing | Fantom Racing | Avid RC | Speed Passion USA | Factory1 | Hy-Traction Juice | Mike's Hobby Shop
Autocratic is offline   Reply With Quote
Old 10-24-2012, 08:37 AM   #8374
michaelfox's Avatar
I have had this problem too, it seemed i had one to many chims on the gears in the gearbox...
problem solved
Thomas Michelsen
Kyosho Mp9 TKI2
Durango dex 210
Durango dex 410
Spectrum dx3r
michaelfox is offline   Reply With Quote
Old 10-24-2012, 08:50 AM   #8375
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
On the trans to make it super free when snugged up simply remove and adjust the shim placement. Not all of the housings require all of the shims.
On the motor plate screws ALWAYS use red loctite here. When I build my transmissions I snug up the plastic to plastic screws only enough to seal any gaps. Then the motor plate screws are done in the same fashion with loctite. Let it setup overnight.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 10-24-2012, 08:59 AM   #8376
Trader Rating: 74 (100%+)
I agree with Randy. This is a practice, I have been doing with all of my builds.
Team and Sales Manager for USRC Imports, home of Sworkz! Looking for drivers for 2017-2018, KingMax Servos www.kingmaxhobby.com Gens Ace www.gensace.com, MIP www.miponline.com,Schelle , WWW. Schelleracing.com, Slavich Designs, GARCIA GRAPHIX
CHECK OUT GARCIA GRAPHIX ON FACEBOOK -LOOKING FOR 2017 TEAM DRIVER'S!
Raul Garcia is offline   Reply With Quote
Old 10-24-2012, 09:38 AM   #8377
Jerad8's Avatar
Trader Rating: 104 (100%+)
I have had 2 DEX210's and on both of mine I basically trim down a little off that aluminum spacer that goes on the top layshaft in the tranny. I keep trimming it little at a time until I can tighten the tranny screws up with no binding in the tranny (I can tighten my tranny pretty tight and still have no binding). Also doing this I have never had that small (5x8x2.5mm) bearing go bad, that some people seem to have to replace often.
Jerad8 is offline   Reply With Quote
Old 10-24-2012, 10:07 AM   #8378
Woulvesbaine's Avatar
Default A question about droop.
I bought my 210 new/assembled and of course the setup was all over the place!
My question is what are good positions for front and rear droop and what are the affects of increasing or reducing droop in the front and the rear?
For now, I increased the front droop from horizontal to allow the arms to fall to about 15% below horizontal.
Thanks.
|| Team C TM4 || OCRC || SCVRC || Facebook: Squid Ink Paint
Woulvesbaine is offline   Reply With Quote
Old 10-24-2012, 10:21 AM   #8379
RiseRC's Avatar
Front
Less Droop (arm Higher)
Decreases front chassis upward travel on-throttle
Less rearward weight transfer
Better on smooth tracks
More on-power steering
More responsive in direction change
More Droop (arm Lower)
Increases upward chassis travel on-throttle
More rearward weight transfer
Increases rear traction on corner exit
Better on bumpy tracks
Rear
Decreases rear chassis upward travel off-throttle or
under braking
Less forward weight transfer
Increases rear chassis upward travel off-throttle or
under braking
Less stable under braking
Increases steering on corner entry
More turn-in
Mike H.
RiseRC is offline   Reply With Quote
Old 10-24-2012, 10:24 AM   #8380
RiseRC's Avatar
I measure the droop by measuring the length of the shock from eyelet to eyelet. I am running the front at 78mm and the back at 97mm.
Mike H.
Old 10-24-2012, 01:27 PM   #8381
Originally Posted by RiseRC View Post
Front
Rear
under braking
under braking
More turn-in
Wow! Thanks for a concise yet fullsome explanation. Even though, I've yet to even get a baseline setup, I already like the handling of the 210 and I love the ability to easily tune every aspect - including droop.
There are a few negatives I see out of the box for this kit:
chassis slapping: with the kit pistons this thing bottoms out. I read hear though that the fix is gluing the pistons such that they become 4 hole.
Leaky shocks: it seems that, though brand new, two of the shocks are leaking out of the bottom. I read here that the fix is a kyosho part - though I'd like to hear any more advice on this.
ball cups: pop more than popcorn in a microwave: what's the simplest (and cheapest) conversion? the losi approach or the associated tc5 (or something - thought there was an associated parts approach). Don't think I feel the need for lunsford here (love lunsford - but this should not need to be a $60 fix).
Steering link: a little sloppy; my purchase came with a FTW brace NIP so I'll install that.
Springs: stock blue springs seem good now if I can fix the slapping but that's because this kit came assembled MM. If/when I eventually switch this to RM3/4 (I'm running clay at WCRC), I assume I'll need to go with stiffer springs in the rear. These stock springs feel a bit light to me - I'm guessing they were designed for MM/carpet.
Old 10-24-2012, 07:37 PM   #8382
P6
threadlock then snug it and if its still a problem back out a little , i havent had a problem since i was told to do this
P6 is offline   Reply With Quote
Old 10-24-2012, 07:41 PM   #8383
RiseRC's Avatar
When I put a kit together I boil the ballcups for about 10 minutes or so to soften them up a bit. I have not had a problem with them popping off and I can turn the turnbuckle easy as well.
I use the 1.3 hole pistions with two holes jb welded to create the 1.3 x 4 hole.
I tryed the 1.6 2 hole in the back and it was okay, I felt the 1.6 x 2 was not what I liked up front. I race mainly on indoor clay tracks that a tight and dont have allot hard landings so I stick to the 4 hole piston.
Mike
Mike H.
Old 10-24-2012, 09:32 PM   #8384
zipperfoot's Avatar
You are reading way too much into this. The stock set up works fine on a groomed track, but most of us in the real world of bumpy tracks prefer four hole pistons. Leakage? Never heard of it. Steering link sloppy? No way. Chassis slap? drive a b44.1 and talk to us about chassis slap. I ran stock springs with four hole 1.3 pistons all around. No issues with rm3. Set your buggy up with stock settings and rm3 with four hole pistons and report your findings. Then we will talk.
I replaced the ball cups with tc6 ball studs and jconcepts ball cups and have regretted it. Stock ball cups no issues. Modded the ball cups and studs and broke 2 parts.
Old 10-24-2012, 09:32 PM   #8385
M3Man03's Avatar
Do they make a non-dish wheel for the DEX210?
It uses a 14mm hex on all 4 corners, right?
Team Durango DESC210R / DEX210 / DEX410 / DETC410 / SJF01-F1 / Tamiya 416x / TE-Maxx 3.3 / OFNA DM-1e
M3Man03 is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16568 09-15-2017 05:07 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
