Like Tree43Likes
Old 10-23-2012, 12:45 PM   #8356
JosephBlack's Avatar
Originally Posted by eddie708 View Post
so most people are running 4 hole pistons?
My brother and I run 4 hole pistons. We've tried the two holes, and countless other setups. But came back to 1.3 x4 holes.
JosephBlack is offline   Reply With Quote
Old 10-23-2012, 01:30 PM   #8357
M3Armand's Avatar
It seems like everyone is running the 4 holes. My issue with this is that we'd have to get a 1.3 drill bit and drill our own using the blanks that was provided...
Having said that, why can't we just use the 1.3 x 6 holes and use a thicker oil? Won't that make up the difference? The question is, what flavor of thicker oil? If we are using 40/30 wt with the 4 hole, do we use 50/40 wt with the 6 hole? Or even 60/50 wt front/rear?
Durango DEX210, SpeedMerchant REV4, HB TCX, Traxxas EMaxx, HPI RS4 Pro, Tamiya TA02, Yokomo YZ10, Associated RC10 Team Car, Bolink Eliminator 10, Kyosho Optima, Tamiya HotShot, Tamiya Grasshopper
M3Armand is offline   Reply With Quote
Old 10-23-2012, 01:38 PM   #8358
BRSracing's Avatar
Trader Rating: 55 (100%+)
Kudos to Durango for dumping the chassis and going to a +8mm plastic chassis.
BRSracing is offline   Reply With Quote
Old 10-23-2012, 02:07 PM   #8359
Trader Rating: 19 (100%+)
In a word- pack. The 6 hole pistons simply do not offer enough pack on tracks that have anything more than small jumps, unless you perfectly downside them every lap. Cornering with 6 hole pistons can be dialed in very well, but chassis slapping and getting the car upset is what made guys go to 4 holes. That said, we're trying 2 holes in the buggy this weekend as they have been excellent in our ST and SC trucks.
XRAY, RC America, MOTIV, Sanwa, Arrowmax, Neverlift Racing Apparel
Jonny5ive Designs- by racers, for racers!
Jonny5 is offline   Reply With Quote
Old 10-23-2012, 02:20 PM   #8360
M3Armand's Avatar
I'm not sure if you read my post correctly. Using THICKER oil with the 6 hole piston, wouldn't that give you all the pack you need?
Old 10-23-2012, 03:01 PM   #8361
Tunatsol's Avatar
Im using the 6 hole with 60/50 and still get slap off small jumps
Josh Youngs
Team Durango: DNX8, Dex8, 408, 210, 410v3,
Sponsored By: Dialed Hobbies
Tunatsol is offline   Reply With Quote
Old 10-23-2012, 03:04 PM   #8362
Plugging the holes is easy enough. I use JB Weld. Some glue them. Some melt the hole shut.
Old 10-23-2012, 03:09 PM   #8363
The number/size of the holes is what relates to pack, not the oil weight. So no, it won't. To achieve enough damping to simulate the needed pack, your oil weight would be so high that handling would suffer- unless, like I stated before, your track has very small jumps or you are able to precisely downside every lap so as to not slap and kick the chassis.
Read this for starters: http://users.telenet.be/elvo/. Particularly the suspension section that deals with damping.
And I highly suggest this: http://www.amainhobbies.com/product_...ston-Drill-Set
Old 10-23-2012, 03:09 PM   #8364
M3Armand's Avatar
That tells me I need to try 70/60
That's a darn great point!!
Old 10-23-2012, 06:45 PM   #8365
tobamiester's Avatar
Trader Rating: 281 (100%+)
Send a message via AIM to tobamiester Send a message via Yahoo to tobamiester
Yup. Gary's (GMK) Drill bit set is a must for your Shock needs.
tobamiester is offline   Reply With Quote
Old 10-23-2012, 07:08 PM   #8366
P6
didnt find that site yet im always looking to learn more ,, doesnt the way the oil flows throught the holes affect all of this especially the number of holes not just the size and if the hole isnt perfectly circle
P6 is offline   Reply With Quote
Old 10-23-2012, 07:44 PM   #8367
i use 4 hole 55s all the way around and it works awsome no bounce off the jumps.
zylstra is offline   Reply With Quote
Old 10-23-2012, 09:25 PM   #8368
I understand what u mean now. i will run 4 hole pistons and then go from there. And thanks for that link very helpful
eddie708 is offline   Reply With Quote
Old 10-24-2012, 08:09 AM   #8369
Default newbie need help
Want to buy 210 but im being told not too. Doing sc now never owned a buggy the 210 being highly tunable i could mess it up. Indoor dirt clay track is where ill be running. 210 looks awesome will get one a some point but should i start with a b4.1 .. opinions. & thoughts greatly appreciated thanks.
dolfns1 is offline   Reply With Quote
Old 10-24-2012, 08:38 AM   #8370
M3Armand's Avatar
If you're a newbie, you're probably better off with the B4.1. There's probably too many points of failure in assembly and maintenance for you.
St Ives RC Club B4Bandit Australian Racing 16577 Yesterday 07:21 PM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-08-2017 12:57 AM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 10:51 PM
