Like Tree23Likes
Old 10-17-2012, 09:08 AM   #8296
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
Originally Posted by scr8pn4205 View Post
whats a good starting gearing for a tekin 10.5 no boost on a track roughly 125x50. Thinkin about 25/81 but wondering your thoughts. thanks
Sounds ok depending on the jump layout. What motor and where is the motor timing set?
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,KoPropUSA,JConcepts,Avid RC,MIP,SikLidz,ImagineItGraphx, FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 10-17-2012, 03:22 PM   #8297
nmdesertracer's Avatar
Trader Rating: 58 (100%+)
How many turns out from full tight do you all have your diff? Im running on carpet and my diff is little over 1/8th turn out. In MM4 this baby is a rocket.
Trailer Park Boys Racing!
nmdesertracer is offline   Reply With Quote
Old 10-17-2012, 04:36 PM   #8298
Team Tekin
Randy_Pike's Avatar
1/8 is about par for the course. I set mine tight enough it doesn't bark and stop.
Old 10-17-2012, 04:50 PM   #8299
Cool thanks Randy. I thought I might have it to tight. Got some ceramic diff balls coming in.
Old 10-17-2012, 05:06 PM   #8300
Trader Rating: 109 (100%+)
Send a message via AIM to kwiksi
For those who are interested...Exotek has jump on the band wagon and now have USA made 4mm thick carbon fiber front shock tower with machined alum camber link mounts. There is another version for ST and SC as well.
http://www.exotekracing.com/dex210-front-tower-set-b/
kwiksi is offline   Reply With Quote
Old 10-17-2012, 05:15 PM   #8301
pekow91's Avatar
Trader Rating: 45 (100%+)
Hey guys, I just got a new Durango buggy and I am having some issues with the steering. When I turn the buggy a certain way, the wheel that I am turning towards seems to get over extended. And when I turn it back the other way the steering links tend to bind up. Any help would be most appreciative.
Also here are a few photos of the problem.
pekow91 is offline   Reply With Quote
Old 10-17-2012, 05:34 PM   #8302
On the front axle where are you running your wheels trailing at. If its say 4 you have to have 4 1mm shims behind the C hub. 3 would be 3 rear 1 front. I didnt know this till last night. This site helped me out a lot http://www.petitrc.com/setup/durango...ngoDEX210.html
Old 10-17-2012, 07:19 PM   #8303
Tdiddy's Avatar
Send a message via Yahoo to Tdiddy
You actually want your wheels to turn like that. The inside wheel follows a tighter path than the outside as the car rotates through the turn. It's called the ackerman effect.
Mark Thomas
Really cool since 1975.
Tdiddy is offline   Reply With Quote
Old 10-17-2012, 07:29 PM   #8304
pekow91's Avatar
Exclamation
Ok thanks. Any clue why the links would bind/ get stuck when moving back the other dirrection after being in this possition. I haven't tried it with a servo yet. Just played with it by manually moving the servo link.
Old 10-17-2012, 07:37 PM   #8305
Tdiddy's Avatar
Using your turnbuckle wrench, twist the turnbuckle slightly one way than back to ensure it's alligned in both ballcups. This might free things up a little.
Mark Thomas
Old 10-17-2012, 07:45 PM   #8306
Atomicsickness's Avatar
Trader Rating: 26 (100%+)
You do not have shocks on the car and if you do not have the droop screws installed the arms are going to travel well past normal movement. This will cause all kinds of wacky angles and binding. Also if your camber is way out it will cause binding.
☆http://www.loganvillerc.com☆
☆http://hotshotrc.com/☆
Atomicsickness is offline   Reply With Quote
Old 10-17-2012, 08:46 PM   #8307
zipperfoot's Avatar
Trader Rating: 16 (100%+)
I had two of the stock plastic preload collars come loose on the rear shocks and throw my buggy out of adjustment. Was a good excuse to order the red Tresrey collars.
zipperfoot is offline   Reply With Quote
Old 10-17-2012, 09:38 PM   #8308
Tunatsol's Avatar
I had the same thing going on with mine but only if I turned the steering at the wheel if I use the steering rack it did not happen. Just my .02
Josh Youngs
Team Durango: DNX8, Dex8, 408, 210, 410v3,
Sponsored By: Dialed Hobbies
Tunatsol is offline   Reply With Quote
Old 10-17-2012, 09:59 PM   #8309
Hey guys,
I'm running a 7.5 motor with a 25 tooth piņon gear on stock spur. The esc and motor is cool to the touch after a full pack but I find top speed kind of slow for a 7.5 turn motor, am I under gearing? Any suggestion on what piņon to use as I don't want to spend too much on trial and error, I'm already way over my budget.
gixx is offline   Reply With Quote
Old 10-17-2012, 11:28 PM   #8310
morris's Avatar
Trader Rating: 40 (100%+)
Originally Posted by gixx View Post
Hey guys,
im running 81/23 on an 8.5 motor and my buggy is fast.i would think if your spur is an 81 tooth and a 7.5 motor you should be geared at or around a 21 or 22 tooth.
hope this helps.
AE/VIPER/XPERT/DIRTCHEAPRC.COM/JCONCEPTS
A big thx to all the tracks that I race at:cause if it wasnt for these guys..we wouldnt have a place to race our r/c cars!!!
morris is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16564 Today 05:06 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
