Like Tree24Likes
Old 10-16-2012, 07:19 AM   #8251
Leedog's Avatar
I really appreciatte the help and opinions on the buggy. But what is this hex adaptor im hearing about for these cars?
www.fastlanegear.com
Leedog is offline   Reply With Quote
Old 10-16-2012, 07:22 AM   #8252
Atomicsickness's Avatar
Trader Rating: 26 (100%+)
http://www.petitrc.com/setup/durango...0_FrontHexMod/
☆http://www.loganvillerc.com☆
☆http://hotshotrc.com/☆
Atomicsickness is offline   Reply With Quote
Old 10-16-2012, 07:24 AM   #8253
discgolferlee's Avatar
Trader Rating: 42 (100%+)
Originally Posted by Atomicsickness View Post
I guess I just don't get what's wrong with the stock setup for front wheels?
What's the need to do this?
discgolferlee is offline   Reply With Quote
Old 10-16-2012, 07:30 AM   #8254
Trader Rating: 19 (100%+)
+1. I prefer bearing fronts.
Serpent America/Desoto Racing- www.serpentamerica.com
TrakPower Speed Equipment- www.trakpowerusa.com
B Fast RC Performance- www.bfastrc.com
Futaba | Strictly R/C- Norridge, IL
Thank you all for the help and support!
Jonny5 is offline   Reply With Quote
Old 10-16-2012, 07:30 AM   #8255
Trader Rating: 27 (100%+)
Some people do this mod, so that they can run different wheels....
Edwin Hartman
Tekno RC Regional Team Manager - Southern Midwest region
Sponsors: Tekno RC - Pro-Line Racing - Tekin - LutzRC - O'Donnell Racing Fuel - TrakPower - Advantage Racing Products - Futaba - Sumo Racing
ehartman_49348 is offline   Reply With Quote
Old 10-16-2012, 07:33 AM   #8256
I did it so that I could run the Hex wheels made for the B4 and Kyosho buggies. I prefer not having to pop out the front wheel bearings out every time I change or clean the front tires.
It does not offer any performance gain. It is just a preference and convenience mod.
Old 10-16-2012, 07:33 AM   #8257
Trader Rating: 21 (100%+)
Agreed.......
Kyosho Rb6.6
Kyosho ZX6.6
Kyosho Rt6
kerby is offline   Reply With Quote
Old 10-16-2012, 07:45 AM   #8258
Originally Posted by kerby View Post
Agreed.......
So you really prefer having to remove your frontwheel bearings every time you change or clean your frontwheels?
It also allows you to use the same wrench front and back.
The DESC210R and DEST210R do not have wheel bearings in the frontwheels.
Old 10-16-2012, 07:50 AM   #8259
Which pistons do you guys drive??
B0tt0mline is offline   Reply With Quote
Old 10-16-2012, 08:07 AM   #8260
What I prefer is less slop and tighter tolerances. I tried hex setups when I ran the sc10 and went pack to bearings. On the new TD sc and st there is at least a performance trade off- same wheels/tires can be used front/rear. That said, my personal preference would still be bearings if I had a choice. Unless you are completely dunking the wheel there is no need to remove the bearings, and at $1 per bearing I don't mind just leaving them in the wheels.
Old 10-16-2012, 08:25 AM   #8261
I usually know which tire to use and don't take them off.....I wash my tires while they're on the car. Honestly....does it really take that much longer? It's not like the bearings are super tight on the wheel.
Kyosho Rb6.6
Kyosho ZX6.6
Kyosho Rt6
Old 10-16-2012, 08:26 AM   #8262
that's what I was thinking. If you are getting the bearings wet cleaning tires then you are probably doing it wrong. probably ruining your foams with dirty water
Old 10-16-2012, 08:49 AM   #8263
Sorry to come back to this:
Which pistons would you recommend?
GHEA, Team Durango Taper, Team Durango Dual Taper??
Old 10-16-2012, 09:13 AM   #8264
Panda-PR's Avatar
+1
Want to know. Could't find the dual taper in stock
snake pit:
Serpent: S811T TE-Novarossi Roma/Werks 2058 | S811b-e 2.0
Kyosho MP9 TKI3 Nova 4btt wc & Losi SCTE 2.0
Thanks to Merlin Fuel/Sweep Tires
Panda-PR is offline   Reply With Quote
Old 10-16-2012, 09:14 AM   #8265
The TD ones are probably the easiest to get ahold of, and were in stock at Tower last I checked. We've been using single taper- haven't tried the dual taper yet. As for the quality, the TD, Ghea, and the ones we got from Nick on Oople are all great quality/fit.
St Ives RC Club B4Bandit Australian Racing 16564 08-19-2017 05:06 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
