Durango DEX210 Thread
#8236
this question is for the guys that did the 12mm hex mod to Tue front.i ordered all the parts that were needed per the part numbers that was posted in the thread.after i got everything on my front rim is hitting the screw on the arm that holds the hinge pin from falling out.im using the new aka rims.which the offset should be the same.has anyone else had issues with the front rim rubbing on the arm causing it to bind up?
Do you have four of the 1mm shims behind the C hub? Also make sure you have shimmed the axial at least 4mm out from the hub.
#8237
#8238
With 6mm spacing the Kyosho wheels fit best. The PL, AE, JC wheels would still rub barely. Kyoshos don't rub at all with 6mm spacing. Idk.
#8239
bottoming out
Are the stock springs too soft?
I recently acquired a new built kit that I completed in MM config with the stock springs. When I received the car, it's rear ride height was set very low, so I raised it to about 24mm rear and 25mm front. The car still easily bottoms out with the stock springs.
Shocks are currently in mid hole positions all around. Thoughts?
#8242
#8243
Some help please.
Hello all. I have a question for 210 owners that race there buggys. Im gonna pull the trigger on one of these in the upcoming weeks but I have just a couple questions as I do not have alot of knowledge on this buggy.
My question is. Now that you have owned your buggys. If you were gonna buy one now. What parts would you buy for it along with the kit? As far as replacements or option parts . Mod parts? I ask this question to racers, as that is what this will be used for. Not concerned about tire selections or oils. But mainly parts that you have seen on the kit or any option parts that you would of done if you were buying another one. I would rather just do it all at once. Thanks again for the help. Lee
#8246
1.) Carbon Steering rack
2.) Shorty lipo pack
3.) BFAST diff balls / thrust bearing
4.) Tresrey clamp on rear hex
5.) Alloy or Titanium quick change shock mounts
Spares:
1.) Shock tower set
2.) Rear hub set ( Or fill the neighboring holes with grub screws to prevent a collapse)
3.) RF hinge pin block set.. Never broke one though others have.
#8247
According to the Hudy Off-Road Manual, its opposite of what you are saying. Is it just something specific with the Durangos that would change this?
STEERING ROD INNER MOUNTING POSITION CHARACTERISTICS
Forward holes (sharper angle)
• Smoothens out steering response
• Car reacts smoothly
• Better suited to smooth fl owing tracks with
high speed corners
Rearward holes (shallower angle)
• Quickens initial steering response
• Car reacts faster to steering input
• Better suited to small, tight tracks
high speed corners
#8249
#8250
IMO these are the essential upgrades:
Spares:
1.) Shock tower set
Spares:
1.) Shock tower set
