Like Tree43Likes
Old 10-09-2012, 05:09 PM   #8161
scr8pn4205's Avatar
im talking about where the slipper pad and slipper plate meet. It on the pad side of the slipper hub not the outside. i cant put pics on here but I can email if you would like
Airtronics M12
Team Xray XB2 2017 CE
TSR power
scr8pn4205 is offline   Reply With Quote
Old 10-09-2012, 05:15 PM   #8162
Atomicsickness's Avatar
Trader Rating: 26 (100%+)
I know what you are talking about. I have the same thing happen to the inside plate on my 210. I have not replaced my plate and it does seem to impact performance. I looked over the pad for something that could have caused it but found nothing. Unless you are seeing a performance issue with it I would not replace it.
☆http://www.loganvillerc.com☆
☆http://hotshotrc.com/☆
Atomicsickness is offline   Reply With Quote
Old 10-09-2012, 05:23 PM   #8163
scr8pn4205's Avatar
here is a pic
Airtronics M12
TSR power
Old 10-09-2012, 05:25 PM   #8164
here is a pic
Yes same thing happened to mine
Old 10-09-2012, 06:09 PM   #8165
M3Armand's Avatar
Originally Posted by Lazi View Post
some people have a same problem. The problem is the ball diff outdrive is shorter than the geardiff outdrive! if u gona landing a sideways in the rear may popping out! i switched to the geardiff and have no problem!
I ran the car for the very first time this past weekend...I must say, this was a pretty awesome driving car... After all my building issues (issues in my opinion), I was pretty happy with the car. The driveshafts did not pop out at all. I also had no issues (so far) with the ball ends.
The ball diff was not tightened enough even though I tightened them by hand "just when it's hard to spin the gear" method. Well, I must have been pretty weak since I kept spinning the gear on carpet. I think I did 2 full turns until the diff stopped spinning. Regardless, I made the gear diff purchase for $28 and will never have to worry about it again.
Lastly, I didn't break any parts either even though I hit the boards a few times and landed a bazillion different ways. However, it does seem like the arms got a bit loose and I had to add 0.3 mm shims to the front. I will probably need 0.5 mm shims in the rears. The wing got scratched up a bit, but surprisingly did not fall off or crack. For a whole day's worth of bashing around on the track, no breakage, but most of all, SERIOUS FUN, I am super happy with the purchase.
Durango DEX210, SpeedMerchant REV4, HB TCX, Traxxas EMaxx, HPI RS4 Pro, Tamiya TA02, Yokomo YZ10, Associated RC10 Team Car, Bolink Eliminator 10, Kyosho Optima, Tamiya HotShot, Tamiya Grasshopper
M3Armand is offline   Reply With Quote
Old 10-09-2012, 09:52 PM   #8166
heygobenny's Avatar
I have been looking to get the JConcepts silent spur for my DEX210 and wanted to know if they fit this buggy before going out to buy it. Anyone know?
Durango FTW
Team Durango DESC410R W/ Tekin RX8 Pro 4
Team Durango DEX408 W/ Tekin Rx8 t8
Team Durango + Savox + Futaba + Tekin + AKA + GensAce + Upgrade + Exotek =WIN
heygobenny is offline   Reply With Quote
Old 10-09-2012, 10:35 PM   #8167
Azagar's Avatar
Will work if you purchase this. RW spurs are just as good though in terms of being silent and precision machined.
Team Durango DEX210
Avid | AKA | Exotek | Jconcepts | KO Propo | Lunsford | Tekin | Turnigy Nano-tech
Azagar is offline   Reply With Quote
Old 10-09-2012, 10:53 PM   #8168
nmdesertracer's Avatar
Trader Rating: 58 (100%+)
no it wont fit hole is not big enough. I think tesrey makes a b4 shaft deal for the 210. thats gonna be my next upgrade.
Trailer Park Boys Racing!
nmdesertracer is offline   Reply With Quote
Old 10-09-2012, 11:01 PM   #8169
Trader Rating: 19 (100%+)
+1. Works just like it's supposed to, I have this on my DESC210.
XRAY, RC America, MOTIV, Sanwa, Arrowmax, Neverlift Racing Apparel
Jonny5ive Designs- by racers, for racers!
Jonny5 is offline   Reply With Quote
Old 10-09-2012, 11:14 PM   #8170
Tdiddy's Avatar
Send a message via Yahoo to Tdiddy
I'm going to hold off on changing the top shaft in my buggy untill the Avid Triad slipper is released. I've ran it in my Associated cars and its the real deal.
Mark Thomas
Really cool since 1975.
Tdiddy is offline   Reply With Quote
Old 10-10-2012, 04:06 AM   #8171
triplesix's Avatar
here is a pic
I had the same thing happen to mine. The car was only driven on carpet indoors...
At least after I changed to AE pads it did never happen again.
MBX6R
B5M Lowrider
DEX410
Supastox GT
triplesix is offline   Reply With Quote
Old 10-10-2012, 07:55 AM   #8172
zipperfoot's Avatar
Trader Rating: 16 (100%+)
Im a little confused as to what springs are recommended. I did the four hole piston mod per instructions, used the stock springs, but now i read that the stock springs are designed for mid motor.
I am running rm3, using a 13.5, at SRS or glitch which are both medium grip outdoor tracks. I am getting ok traction but the rear seems a bit bouncy at times. I am using 35wt losi oil in the front and 30 in the rear with 1.3 pistons all around. I have not added any weight.
If other springs are being used, what brand and color?
Any advice or suggestions would be appreciated.
zipperfoot is offline   Reply With Quote
Old 10-10-2012, 08:25 AM   #8173
Tech Legend
Cain's Avatar
Trader Rating: 239 (100%+)
Where is a good place to order this from or is it all direct?
< HB Racing D413 | Tekno EB48SL / SCT410.3 | Tekno EB410 | Yokomo YZ-2 DTM x 2 | LC Racing EMB-1 Buggies and Truggies >
Old 10-10-2012, 08:49 AM   #8174
discgolferlee's Avatar
Trader Rating: 42 (100%+)
http://www.tresrey-usa.com/
has the slipper
discgolferlee is offline   Reply With Quote
Old 10-10-2012, 10:11 AM   #8175
TD Black springs for the rear and dk green springs front are a good baseline for medium/high grip tracks. If you already have them, Losi and Kyosho big bore springs are direct fit as well, but you would have to match up the rates. There is a handy spring chart on petitrc.com that has all manufacturers springs on one sheet.
St Ives RC Club B4Bandit Australian Racing 16575 11-18-2017 12:44 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-08-2017 12:57 AM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 10:51 PM
