Like Tree43Likes
Old 10-08-2012, 02:51 PM   #8146
jackcarter3's Avatar
Originally Posted by Woulvesbaine View Post
Thanks. Would you mind posting your setup or listing it out? I'm basically running box setup on an indoor clay (WCRC).
I go to the track Wednesday and I will grab my set up sheet and let you know.
jackcarter3 is offline   Reply With Quote
Old 10-08-2012, 03:30 PM   #8147
Woulvesbaine's Avatar
Thanks much!~
|| Team C TM4 || OCRC || SCVRC || Facebook: Squid Ink Paint
Woulvesbaine is offline   Reply With Quote
Old 10-08-2012, 05:45 PM   #8148
Azagar's Avatar
Originally Posted by Cain View Post
what springs are cool to have when running the MM or RM setups other than stock?
I'd say all of them. The price for each spring set for the front and rear is just hard to beat. But I would say Jorn Neumann's spring choices are the best starting place for find the right springs for yourself. Dark green/dark blue for RM and light brown/black for MM.
Team Durango DEX210
Avid | AKA | Exotek | Jconcepts | KO Propo | Lunsford | Tekin | Turnigy Nano-tech
Azagar is offline   Reply With Quote
Old 10-08-2012, 07:46 PM   #8149
Thumbs up good base set up
i had my first race this past sunday with my dex10. i could not get the rear end to stay behind the front end. i found that by extending the rear upper links to the outter most hole on the hub , then raised the inner up 2 mill with a 2 mm spacer i also use team losi truck springs yellow for the rear springs, with losi 22 front red spreings with 25.5 in the front and 25 rear. these small changes made a world of a difference. i was now doing 16 -17 laps qualifiers no prblem the ass end was very planted . i run on clay indoor . im so happy with my purchase of the dex 10 . it has helped my driving prowes ten fold. so if any new dex10 owners have the same problem . follow the rear caber set up . and play with the droop too as i found make a great tuning aid.. happy racing
batremi is offline   Reply With Quote
Old 10-09-2012, 07:04 AM   #8150
Funny. Tower Hobbies shows estimated stock date for the DEX210 composite chassis to be January.
______________________________________________________
Team Tulsa - Team R/C Paints by Sonny - Durango DEX410
qwkpony is offline   Reply With Quote
Old 10-09-2012, 07:48 AM   #8151
coaltrain's Avatar
That's the dimec02 chassis the dimec +8 is early November
Exotek/PRS1 V3 FM/DEX210, DEX410, MIP-SCTE
coaltrain is offline   Reply With Quote
Old 10-09-2012, 09:54 AM   #8152
Is that new tresrey milled chassis that is on red rc right now a +8 mm? It doesn't say In the description. Man it looks real nice!
Old 10-09-2012, 09:57 AM   #8153
Atomicsickness's Avatar
Trader Rating: 26 (100%+)
Don't think so I don't see the addition of the extension pieces needed if it was +8
☆http://www.loganvillerc.com☆
☆http://hotshotrc.com/☆
Atomicsickness is offline   Reply With Quote
Old 10-09-2012, 10:03 AM   #8154
I got an e mail from them recently though inquiring on the 8 racing +8mm and they said they had something new coming out in regards to a plus 8 so maybe this is it.
Old 10-09-2012, 10:13 AM   #8155
Trader Rating: 74 (100%+)
I cant wait for mine..
Team and Sales Manager for USRC Imports, home of Sworkz! Looking for drivers for 2017-2018, KingMax Servos www.kingmaxhobby.com Gens Ace www.gensace.com, MIP www.miponline.com,Schelle , WWW. Schelleracing.com, Slavich Designs, GARCIA GRAPHIX
CHECK OUT GARCIA GRAPHIX ON FACEBOOK -LOOKING FOR 2017 TEAM DRIVER'S!
Raul Garcia is offline   Reply With Quote
Old 10-09-2012, 11:34 AM   #8156
Azagar's Avatar
The milling on that new chassis is incredible, really can't wait for that.
Team Durango DEX210
Old 10-09-2012, 03:44 PM   #8157
scr8pn4205's Avatar
Has anyone had an issued with the slipper plates getting grooves in them. i have replaced mine 2 times with new pads, set slipper to correct tension and after a 2 day event I looked at the slipper assy and I am getting a groove in the slipper plate???
Airtronics M12
Team Xray XB2 2017 CE
TSR power
scr8pn4205 is offline   Reply With Quote
Old 10-09-2012, 03:49 PM   #8158
If its on the outside, make sure the screw lengths going through the gearbox are correct. If they are too long they will make contact with the outside of the plates.
Old 10-09-2012, 04:31 PM   #8159
discgolferlee's Avatar
Trader Rating: 42 (100%+)
I bet this is your problem!!!
discgolferlee is offline   Reply With Quote
Old 10-09-2012, 04:55 PM   #8160
Lazi's Avatar
Originally Posted by M3Armand View Post
Hey guys,
I literally just finished putting the radio / electrics in and put stickers on the body. I just mated the transmitter and ESC and found a "wobble" in the driveshaft. First, I noticed that the driveshaft seems a little "short" when the wheels are fully extended down. This is the same for both left and right sides - see pics. Is this NORMAL or did my kit come with short ones? Tip to tip, mine is 105mm.
Also, one of the driveshafts is actually slightly bent. The car hasn't even left my desk yet. So now I have to take it apart and straighten that driveshaft?
p.s. - I like how the hole guides on the wing doesn't match the wing mounts as they are mounted on the car...nice...NOT! Experience taught me to check in advance. I pity the beginner/semi-intermediate builder who will have to buy a new wing if they drilled using the the hole guides.
some people have a same problem. The problem is the ball diff outdrive is shorter than the geardiff outdrive! if u gona landing a sideways in the rear may popping out! i switched to the geardiff and have no problem!
Lazi
Sponsored by:TEKNO RC-RC HOBBIES-JCONCEPTS-EXOTEK RACING-RADIOPOST-KALGARD-BOCA BEARING
Lazi is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16581 Today 03:23 PM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-08-2017 12:57 AM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 10:51 PM
