Like Tree17Likes
Old 10-07-2012, 11:38 AM   #8131
M3Armand's Avatar
Originally Posted by 1armed1 View Post
34/75 will put you at 5.74 and
35/75 will put you at 5.57
I ran 35/75 at the Spektrum race, the car was plenty fast.
Temps were right at 120 after a 5 minute run.
Hey guys, with 35/75 the gear box cover won't fit anymore... Is there an aftermarket one available?
Durango DEX210, SpeedMerchant REV4, HB TCX, Traxxas EMaxx, HPI RS4 Pro, Tamiya TA02, Yokomo YZ10, Associated RC10 Team Car, Bolink Eliminator 10, Kyosho Optima, Tamiya HotShot, Tamiya Grasshopper
M3Armand is offline   Reply With Quote
Old 10-07-2012, 11:54 AM   #8132
Panic09's Avatar
Originally Posted by Konich View Post
Nice eyes! Tersrey is making a light weight milled chassis for the 210. Look for more detail soon!
Any idea when it will be released?
"I was so far behind I thought I was first"
MIKES RC WORLD(r.i.p) | TACOMA RC RACEWAY | FOUR SEASONS RC RACEWAY(r.i.p) | ISLAND RACEWAY
Panic09 is offline   Reply With Quote
Old 10-07-2012, 07:18 PM   #8133
Konich's Avatar
Originally Posted by R-E-A-P-E-R- View Post
Ready for some winter racing!!!
When are you going to mhor so we can dial that in?
Tresrey Spec DEX410 - Yaiba Spec B5M
Konich is offline   Reply With Quote
Old 10-07-2012, 07:27 PM   #8134
nmdesertracer's Avatar
Trader Rating: 58 (100%+)
http://www.rcshox.com/dex210-gearcover/
Trailer Park Boys Racing!
nmdesertracer is offline   Reply With Quote
Old 10-07-2012, 07:48 PM   #8135
R-E-A-P-E-R-'s Avatar
Soon!
Serious About Racing........
R-E-A-P-E-R- is offline   Reply With Quote
Old 10-07-2012, 08:40 PM   #8136
Trader Rating: 19 (100%+)
Just dremel the inside a bit where the pinion rubs. If you bolt the cover on so its just barely snug to the pinion and rotate the wheels to spin the motor it will rub marks into the cover to sneedshere it needs relief.
Serpent America/Desoto Racing- www.serpentamerica.com
TrakPower Speed Equipment- www.trakpowerusa.com
B Fast RC Performance- www.bfastrc.com
Futaba | Strictly R/C- Norridge, IL
Thank you all for the help and support!
Jonny5 is offline   Reply With Quote
Old 10-07-2012, 10:00 PM   #8137
Woulvesbaine's Avatar
Default MN v. RM handling characteristics
So I purchased a 210 new, built in MM configuration. I thought I'd give it a try that way before likely some day switching to rear. I can say that after adjusting the camber and toe in, "out of the box" this car handles great.
It lacks a little traction out of tight sweepers going into a jump in the current config when run at WCRC (clay).
My question is if anyone's tried both configs and can talk about the difference in handling characteristics between MM and RM. I like the way it handles in MM and am wondering what, if anything, I'll give up if/when I switch the config to rear.
Also, this thing feels like a brick with a 17.5. Do most people run a shorty in it to save weight?
|| Team C TM4 || OCRC || SCVRC || Facebook: Squid Ink Paint
Woulvesbaine is offline   Reply With Quote
Old 10-07-2012, 10:53 PM   #8138
Azagar's Avatar
Definitely run a shorty, to shed some weight. You're looking at around 1600g stock with a shorty pack which is not too bad for buggies nowadays. After some weight saving hop-ups you can hit around 1565 which is my current buggies weight in 17.5. Never tried the car MM at my track but unfortunately when you switch to RM, with the same stock springs the car will react very different in a bad way. Since there not the ideal springs for a RM setup, need softer fronts and stiffer rears.
Team Durango DEX210
Avid | AKA | Exotek | Jconcepts | KO Propo | Lunsford | Tekin | Turnigy Nano-tech
Azagar is offline   Reply With Quote
Old 10-08-2012, 08:05 AM   #8139
Dog Runner's Avatar
Trader Rating: 21 (100%+)
Send a message via Skype™ to Dog Runner
What is the benefit of the RC Shox "garodisc" replacement slipper pads? Looks like some people use them with their 210s. If you've used them, would you recommend them?
JR
Need a real estate agent? I can help.
Dog Runner is offline   Reply With Quote
Old 10-08-2012, 09:24 AM   #8140
jackcarter3's Avatar
I just built up a mm4 car. Running the same set up as my rm3 except for 1.5 anti squat. Run on med to high bite clay indoor. First time out with it, I beat my best on the current layout. The car rotates very well and is planted. It will be a handful as traction goes away and the car is not as forgiving to drive as rm3. Especially if you case a jump. Gonna get the tresrey high traction rear weight and be done with it. I like the mid motor a lot so far. I also moved the rear hubs forward 2mm to give more forward bite.
jackcarter3 is offline   Reply With Quote
Old 10-08-2012, 10:29 AM   #8141
Not sure if you guys have been looking for the aluminum lower shock caps from TD, but they have been out of stock for some time now. Once again Tresrey has answered the call for a much needed part, of course in beautiful Tresrey red: http://tresreyusa.blogspot.com/2012/...stock.html?m=1
I have also found their .5mm and .75mm shims to be extremely useful. When shimming the rear hubs and front caster blocks, 4mm of shims leaves a little slop, but an extra .5mm shim is too tight. Using a .5mm and a .75mm shim instead of a 1mm shim gives an extra .25mm to perfectly take up the little bit of slop. Dialed!
Old 10-08-2012, 10:47 AM   #8142
I got them in almost all my cars. They dont glaze up. Well worth the money!!
Old 10-08-2012, 10:59 AM   #8143
Azagar's Avatar
Jonny5 you're defentiely right. I've been using .3 kyosho 3x5 shims for the front and rear. Getting rid of that extra play makes such a difference.
Team Durango DEX210
Old 10-08-2012, 01:13 PM   #8144
Thanks. Would you mind posting your setup or listing it out? I'm basically running box setup on an indoor clay (WCRC).
Old 10-08-2012, 01:15 PM   #8145
Tech Legend
Cain's Avatar
Trader Rating: 233 (100%+)
what springs are cool to have when running the MM or RM setups other than stock?
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL x 2 | Yokomo YZ-2 DTM x 2>
St Ives RC Club B4Bandit Australian Racing 16561 Today 03:54 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
