Like Tree18Likes
Old 10-02-2012, 06:15 PM   #8071
air8's Avatar
Same here dan-o. I built the car running the turnbuckles in and out of the ball cups several times. I did have to take two of the links back off and run them in and out again a few times. Those two were popping off when adjusting camber. But all good now.
Haven't had one pop off yet from a crash. Knock on wood. Probably at least 20 battery packs worth of run time now.
I actually notice the turnbuckles move in/out slightly, but only from rubbing the pipe at full speed or during crashes. But I have the same thing happen in 8th scale sometimes. Just gotta check camber and toe before/after each run.
Hand up. I've always used RPM ballcups on the Associated cars.
--Driver...you are cleared into the track.....Smoke On.
--"U Ain't Fast!!"
Chris Pearce
air8 is offline   Reply With Quote
Old 10-02-2012, 07:31 PM   #8072
Trader Rating: 19 (100%+)
Originally Posted by flame56mx View Post
There have been many who have had issues with the ball cups, and many who haven't. They require a little more attention than other brands, but understand other cars have uniqueness also. Show of hands--how many b4's owners out there with RPM ballcups? Or 22 owners running AE diff parts, Or etc.... I have the stock ball cups on my car, and also have them on my 410, and they have never been a problem area..
Serpent America/Desoto Racing- www.serpentamerica.com
TrakPower Speed Equipment- www.trakpowerusa.com
B Fast RC Performance- www.bfastrc.com
Futaba | Strictly R/C- Norridge, IL
Thank you all for the help and support!
Jonny5 is offline   Reply With Quote
Old 10-02-2012, 07:32 PM   #8073
Trader Rating: 36 (100%+)
Yep they pop off pretty easy now. I will do the in and out on them and report back. Thanks for the help
Mik G is offline   Reply With Quote
Old 10-02-2012, 08:47 PM   #8074
zipperfoot's Avatar
Trader Rating: 16 (100%+)
Ive been happy with the hd ball cups. I built them per all the tips, tricks, and instruction i could find. No issue. My issue was the size is unique, and parts are hard to find in these parts... I used AE parts in my 22, and rpm on my B4.1. Not knocking the 210, just commenting on my experience.
I do think the buggy needs some minor refinements:
The steering linkage should be carbon or aluminum out of the box.
Four hole pistons should be included in the kit. (Or at least supply some tooth picks... LOL).
Shock caps and o-rings need to fit better (to keep the o-rings from buldging)
The ball cup plastic should be revised for those with problems. (And there are many)
Other than that the buggy is great!
If slow is fast, how come I'm still slow?
zipperfoot is offline   Reply With Quote
Old 10-02-2012, 09:39 PM   #8075
About the shock caps- I use TD 330028 orings from the regular bores. Couple that with a 45 chamfer on the lip of the cap, and there is no bulging and the cap goes all the way down flush to the shock body.
Old 10-02-2012, 10:15 PM   #8076
air8's Avatar
Agree to the chamfer of the shock caps. Worked like a charm with big bore o-rings. My LHS is still building his supply of Rango parts. So no small bore parts at all.
I think there are now 4 DEX210's running at our track now. So the parts should really roll in now. I'm hoping there's a big order showing up tomorrow. I'm gonna be there first thing to get first dibs. LoL.
--"U Ain't Fast!!"
Chris Pearce
Old 10-02-2012, 10:16 PM   #8077
air8's Avatar
Mik, are you gonna use new ball cups since your current ones might be used up from popping on and off?
--"U Ain't Fast!!"
Chris Pearce
Old 10-03-2012, 04:26 AM   #8078
Jeff Werner's Avatar
Trader Rating: 14 (100%+)
Send a message via Yahoo to Jeff Werner
Heck Air8 I have not needed many parts. Messed up a rear hub when I got lawndarted other then that not broken anything. Been really happy with my buggy.
Jeff Werner is offline   Reply With Quote
Old 10-03-2012, 06:30 AM   #8079
No air8. 2 quals and 1 main with no pratice time. I hit the pipe same place everytime. The same one poped off everytime. I might replace just the one on that side.
Old 10-03-2012, 06:40 AM   #8080
Crazy Carl's Avatar
Trader Rating: 7 (89%+)
Question:
Have any of guys play with the front spindle positions and trailing locations.
Results?
My current track :hard packed dirt\clay mix very low bite.
Crazy Carl is offline   Reply With Quote
Old 10-03-2012, 07:06 AM   #8081
Any time a ballcup pops off it should be replaced - including if it pops during adjustment.
Originally Posted by Crazy Carl View Post
Question:
Results?
Running in full trailing will be the smoothest/least aggressive. As you move the axle forward, turn-in will be more aggressive. Also, if you move the axle forward 1mm, you should move the caster block back 1mm to keep the wheelbase the same.
Old 10-03-2012, 10:03 AM   #8082
heygobenny's Avatar
Anybody try the new 8+mm chassis for the DEX210? You have to buy the 8mm extra body to but it's only $20 for the body and $50 for both. The bew body looks sick to. Let me know if it adds and durability or better performance or just pm me. Thanks
Durango FTW
Team Durango DESC410R W/ Tekin RX8 Pro 4
Team Durango DEX408 W/ Tekin Rx8 t8
Team Durango + Savox + Futaba + Tekin + AKA + GensAce + Upgrade + Exotek =WIN
heygobenny is offline   Reply With Quote
Old 10-03-2012, 10:42 AM   #8083
Trader Rating: 74 (100%+)
Question:
Results?
Hey Carl. How have you been? I have experimented with different blocks for trailing to max inline . I have come to like max inline the best along with 4mm behind the castor block . It give the most consistent feel. more trailing kills the steering. I'm running between RCHR or Wolcott .
Serpent USA www.serpentamerica.com, King Max Servos, Gens Ace, MIP, www.miponline.com,Schelle , WWW. Schelleracing.com, Slavich Designs, GARCIA GRAPHIX
CHECK OUT GARCIA GRAPHIX ON FACEBOOK -LOOKING FOR 2017 TEAM DRIVER'S!
Raul Garcia is offline   Reply With Quote
Old 10-03-2012, 01:21 PM   #8084
air8's Avatar
Well it's time for diff rebuild for me. Getting to the diff is quite a task. For some reason I didn't realize that when first building. Guess I was too excited to get it completed. LoL. Durango would've earned brownie points to design a quick access tranny case.
--"U Ain't Fast!!"
Chris Pearce
Old 10-03-2012, 01:32 PM   #8085
murky123's Avatar
tranny access is one downside of a multi purpose tranny like this one.
AE SC10 4x4, Durango DEX210 + DESC210R, HB D413
www.rcracing.nl www.mvb.nl
murky123 is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16562 Today 05:07 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
