Like Tree23Likes
Old 09-28-2012, 05:07 PM   #8011
Tdiddy's Avatar
Send a message via Yahoo to Tdiddy
Default Bulletproof ballcup
I found a video somewhere that shows how to make the inner rear ballcup secure. After buying the Tresrey rear camber mount, I threaded some button head screws into the trans case. After checking several times for clearance, I locked everything down. Now, the inner-rear ballcup can't pop off. These inner cups were the ones that poped off every time out on the track during my first trip to the track with this car.
I also installed the Cream shock towers on the front and rear of my car.
Mark Thomas
Really cool since 1975.
Tdiddy is offline   Reply With Quote
Old 09-28-2012, 05:08 PM   #8012
Tdiddy's Avatar
Here is the picture of the camber mount and the screw I added.
Mark Thomas
Old 09-28-2012, 07:55 PM   #8013
air8's Avatar
Only trouble I had building the kit was the O-rings under the shock caps. They kept trying to fold and push out before getting the shock cap tight.
I put shock oil on the o-rings but they still wanted to fold and push out. I just kept tighten a little then push the o-ring in, tighten a little, push o-ring in, etc.
Hopefully these won't cause issue. Shocks feel ok right now but haven't been on track with it just yet.
--Driver...you are cleared into the track.....Smoke On.
--"U Ain't Fast!!"
Chris Pearce
air8 is offline   Reply With Quote
Old 09-28-2012, 08:06 PM   #8014
Trader Rating: 520 (100%+)
If you bevel the inside of the cap a little with a hobby knife, the orings stay put..
flame56mx is offline   Reply With Quote
Old 09-28-2012, 08:22 PM   #8015
air8's Avatar
Didn't see this mentioned either....
When using the clamping hexes are people cutting the Durango cross pin shorter
...or using a whole different size pin?
Thanx.
--"U Ain't Fast!!"
Chris Pearce
Old 09-28-2012, 08:23 PM   #8016
air8's Avatar
Nice tip. Thanx.
--"U Ain't Fast!!"
Chris Pearce
Old 09-28-2012, 08:51 PM   #8017
Trader Rating: 19 (100%+)
Thanx.
The Tresrey hexes come with a shorter pin and a few shims in the package.
Serpent America/Desoto Racing- www.serpentamerica.com
TrakPower Speed Equipment- www.trakpowerusa.com
B Fast RC Performance- www.bfastrc.com
Futaba | Strictly R/C- Norridge, IL
Thank you all for the help and support!
Jonny5 is offline   Reply With Quote
Old 09-28-2012, 09:08 PM   #8018
jonski's Avatar
Trader Rating: 233 (99%+)
I have read every post on here about which ball cups and ball studs to use...my question is, can I use the JConcepts ball cups with the stock turnbuckles? Don't want to phaeton buy different turnbuckles right now.
jonski is offline   Reply With Quote
Old 09-29-2012, 01:35 AM   #8019
You can also use small bore o-rings. The stretch makes them thinner and they fit and seal perfectly without having to modify anything.
Yellow Wheels is offline   Reply With Quote
Old 09-29-2012, 02:03 AM   #8020
So*Cal AFDude's Avatar
Trader Rating: 21 (100%+)
Still haven't had an issue with the stock HD ball ends after 200+ battery packs.. strange
-Aaron Willming
~ Hobby-Pro USA ~ Viper-RC ~ IERC Raceway ~
www.IERCRaceway.com - www.Facebook.com/IERCRaceway
So*Cal AFDude is offline   Reply With Quote
Old 09-29-2012, 04:01 AM   #8021
air8's Avatar
Interesting also. Being stretched that thin and they still seal well???
Good to hear that. I built mine according to the Tips and Tricks on Durango's sight. Used a drill to run the turnbuckles in and out the ball cups about ten times. They seem real easy to adjust, and hope to hit the track today if I get finished with my daughters agenda in time. I feel there will be no pop off problem.
--"U Ain't Fast!!"
Chris Pearce
Old 09-29-2012, 04:09 AM   #8022
murky123's Avatar
same here. my first popped off after 9 months of running. and that is just becouse there is a tiny bit of slop in the balcup after 9 months.
AE SC10 4x4, Durango DEX210 + DESC210R, HB D413
www.rcracing.nl www.mvb.nl
murky123 is offline   Reply With Quote
Old 09-29-2012, 06:43 AM   #8023
air8's Avatar
Nice, yea I saw your post on that a few pages back. The B4.1 I used last year only had one pop off when I slammed into a SC who was jumping lanes. The 210 should be just the same.
--"U Ain't Fast!!"
Chris Pearce
Old 09-29-2012, 06:48 AM   #8024
Trader Rating: 74 (100%+)
Simple solution. Use the lunsford kit. This question is only asked every 14 seconds.
Serpent USA www.serpentamerica.com, King Max Servos, Gens Ace, MIP, www.miponline.com,Schelle , WWW. Schelleracing.com, Slavich Designs, GARCIA GRAPHIX
CHECK OUT GARCIA GRAPHIX ON FACEBOOK -LOOKING FOR 2017 TEAM DRIVER'S!
Raul Garcia is offline   Reply With Quote
Old 09-29-2012, 08:20 AM   #8025
Konich's Avatar
Same here, amazing how well they work when assembled properly and you stay off the pipes. Ream out the ends, thread them through a couple times and you won't have any problems.
Tresrey Spec DEX410 - Yaiba Spec B5M
Konich is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16564 Yesterday 05:06 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
