Like Tree23Likes
Old 09-27-2012, 02:07 AM   #7981
stiltskin's Avatar
Trader Rating: 102 (100%+)
Originally Posted by flame56mx View Post
What speedo you running?
Tekin. (I knew I left something out). Thanks.
Tony Rumple
Team EAM // Gravity RC
stiltskin is offline   Reply With Quote
Old 09-27-2012, 05:30 AM   #7982
FRONTI3R's Avatar
Originally Posted by Tunatsol View Post
Hate to say this but Traxxas Rustler turnbuckel end will fit on the stock buckels. Just have to through bolt and shim to your likeing. You will almost never have one come off after that. Will cost about $7 U.S. to change over the hole car. Had to do this on my Desc210.
These ones?
Traxxas Rod Ends & Hollow Balls (12)
[TRA5525]
I don't think I like the idea of them NEVER coming off! You noticed you're breaking any other parts in crashes since you switched over to these?
Sponsors: Tekno RC, GFX Designs, RCOttawa.com/forum/
www.teknorc.com
FRONTI3R is offline   Reply With Quote
Old 09-27-2012, 07:30 AM   #7983
TAMAK's Avatar
Trader Rating: 28 (100%+)
Saw this on the Tresrey Blog!!! Not interested in the battery holder. I am interested in this black, milled out chassis!!! Murdered!!
TrakPower Speed Equipment / Speed Passion
Serpent Natrix 748 TQ - Nova REX
D413 Reventon 1.1ex 13.5t; AE B6d Laydown Reventon Pro 1.1
DNX408V2-NovaP5, DETC410-Reventon 1.1ex-5.5t MMM
RC10 , RC10GT2- CV-R- SAVOX,
TAMAK is offline   Reply With Quote
Old 09-27-2012, 08:12 AM   #7984
SoCalGuy's Avatar
Hi guys,
Finished up the build with the exception of the shocks. I have been waiting for the 4 hole tapered pistons I ordered from Nick, but figured I might as well get it set up with the stock stuff so i can at least run it. Can someone recommend which stock pistons to start with (front and rear), and a good starting place for the oil? Most of the setup sheets I've seen are using the 4 hole variety. Rather small, technical dirt/clay track; mostly small jumps. Pretty much stock set-up except for different springs (as recommended here for the RM3 config) Will be using a shorty Lipo as well.
Thanks all!
SoCal
Mugen MBX6 Eco, Kyosho ZX-5 FS2, Team Durango DEX210
Tamiya TB-03, Tamiya M-05 Pro, Associate 18R, Vaterra Kemora
SoCalGuy is offline   Reply With Quote
Old 09-27-2012, 08:12 AM   #7985
Trader Rating: 19 (100%+)
Attachment 974989
The cat's out of the bag...
Serpent America/Desoto Racing- www.serpentamerica.com
TrakPower Speed Equipment- www.trakpowerusa.com
B Fast RC Performance- www.bfastrc.com
Futaba | Strictly R/C- Norridge, IL
Thank you all for the help and support!
Jonny5 is offline   Reply With Quote
Old 09-27-2012, 09:15 AM   #7986
Tunatsol's Avatar
Originally Posted by FRONTI3R View Post
These ones?
[TRA5525]
Have had no problums for the switch but its only been on the track 2 times now. Could brake trans case tabs we will see.
Josh Youngs
Team Durango: DNX8, Dex8, 408, 210, 410v3,
Sponsored By: Dialed Hobbies
Tunatsol is offline   Reply With Quote
Old 09-27-2012, 10:50 AM   #7987
Trader Rating: 21 (100%+)
Originally Posted by SoCalGuy View Post
Hi guys,
Thanks all!
SoCal
I run 4 hole 1.2 on all four shocks. Losi orange springs up front and White in the rear. Oil 25wt front 20 rear Losi oil. Works well for me....I don't run shorty packs...I think the car is more stable with the regular sized 4000-5000 bricks
Kyosho Rb6.6
Kyosho ZX6.6
Kyosho Rt6
kerby is offline   Reply With Quote
Old 09-27-2012, 10:54 AM   #7988
M3Armand's Avatar
I assume you had to purchase these 4 hole 1.2mm pistons? I thought it was what came in the kit, but the kit only has 6 hole 1.2 and 1.3mm pistons...
Durango DEX210, SpeedMerchant REV4, HB TCX, Traxxas EMaxx, HPI RS4 Pro, Tamiya TA02, Yokomo YZ10, Associated RC10 Team Car, Bolink Eliminator 10, Kyosho Optima, Tamiya HotShot, Tamiya Grasshopper
M3Armand is offline   Reply With Quote
Old 09-27-2012, 10:59 AM   #7989
Trader Rating: 27 (100%+)
The car comes with 6x1.2 and 6x1.3 and blanks. You can either drill the blanks with 4x1.2 or solder 2 of the 6x1.2 holes closed.
Edwin Hartman
Tekno RC Regional Team Manager - Southern Midwest region
Sponsors: Tekno RC - Pro-Line Racing - Tekin - LutzRC - O'Donnell Racing Fuel - TrakPower - Advantage Racing Products - Futaba - Sumo Racing
ehartman_49348 is offline   Reply With Quote
Old 09-27-2012, 11:51 AM   #7990
I plugged two holes....toothpick and a drop of CA glue on each side and you're ready to roll
Kyosho Rb6.6
Kyosho ZX6.6
Kyosho Rt6
Old 09-27-2012, 12:51 PM   #7991
Azagar's Avatar
SoCal
1.3 stock pistons all around with 45/40 have been working really well for me. I honestly felt 4 hole gave the shocks too much pack, which is something I personally have never liked. Never bothered to try 5 hole though. That might be where the sweet spot is like kyosho bigbores.
Team Durango DEX210
Avid | AKA | Exotek | Jconcepts | KO Propo | Lunsford | Tekin | Turnigy Nano-tech
Azagar is offline   Reply With Quote
Old 09-27-2012, 01:09 PM   #7992
Seems a bit thick for a buggy.... Don't run that in my 4wd sc. What kind of surface do you race?
Kyosho Rb6.6
Kyosho ZX6.6
Kyosho Rt6
Old 09-27-2012, 01:10 PM   #7993
I have been seeing a lot of carbon front shock towers for the 210 and noticed that several of them convert the inner camber ball studs to horizontal (stock is vertical) and was wondering how this affected the geometry. To make the ball studs horizontal, they would have to push them further out (forward) on the chassis from the stock position.
Anyone have any experience with any these towers?
J
jdawg53 is offline   Reply With Quote
Old 09-27-2012, 01:23 PM   #7994
air8's Avatar
Got any pics of those towers? Haven't seen that yet.
--Driver...you are cleared into the track.....Smoke On.
--"U Ain't Fast!!"
Chris Pearce
air8 is offline   Reply With Quote
Old 09-27-2012, 01:23 PM   #7995
Azagar's Avatar
Med. size indoor dirt packed track, mostly smooth except for acceleration points and some small craters scattered throughout. If you consider the most common setups call for 4 holes 35/30 or near there. 40+ is needed for 6hole, otherwise you will be bottoming out. I am also using dark green springs up front with dark blue rear.
Team Durango DEX210
St Ives RC Club B4Bandit Australian Racing 16564 Today 05:06 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Dopkal
