Like Tree24Likes
Old 09-25-2012, 10:57 AM   #7936
Azagar's Avatar
Thought I might add what I noticed yesterday, from a small shipment of Durango parts to my lhs. If anyone is still using the carbon composite shock towers, it looks like they have re designed the rear shock tower. Slightly anyway but should help prevent those breaks where they touch on the motor plate.
Team Durango DEX210
Avid | AKA | Exotek | Jconcepts | KO Propo | Lunsford | Tekin | Turnigy Nano-tech
Azagar is offline   Reply With Quote
Old 09-25-2012, 12:07 PM   #7937
murky123's Avatar
you got a picture of the tower?
AE SC10 4x4, Durango DEX210 + DESC210R, HB D413
www.rcracing.nl www.mvb.nl
murky123 is offline   Reply With Quote
Old 09-25-2012, 12:29 PM   #7938
Azagar's Avatar
Sorry for the poor picture. Also i'm not sure if its because my backup towers are a bit older or Durango has changed something in their carbon composite formula but these new towers feel much more rigid then the old ones.
Team Durango DEX210
Old 09-25-2012, 12:38 PM   #7939
jackcarter3's Avatar
Any ideas on when the Durango +8 composite chassis will be available?
jackcarter3 is offline   Reply With Quote
Old 09-25-2012, 12:42 PM   #7940
coaltrain's Avatar
November
DEX210 DEX410 MIP-SCTE
coaltrain is offline   Reply With Quote
Old 09-25-2012, 01:05 PM   #7941
murky123's Avatar
and in 2 different sorts of composite. one is a bit stiffer than the other DIMEC20 http://www.team-durango.com/part-inf...artNo=TD320222
Old 09-25-2012, 01:09 PM   #7942
EvanAZ's Avatar
Trader Rating: 99 (100%+)
Hum, those both say for the DESC210, I thought the buggy was shorter.
**Over The Top RC - Cars for Kids Program**
***Looking for a responsible person to help run the track and program***
EvanAZ is offline   Reply With Quote
Old 09-25-2012, 01:12 PM   #7943
Brollywood's Avatar
If the plastic chassis is anything like the short course mounted up it will flex like crazy. The sc has the most flex ive ever felt. You may want to wait for the stiffer carbon composite chassis
A-main Bodies $ Fastraxx Hobbies $ The Ohio R/C Factory $ Team Chase Lemuiex $ Skipgear.com $ The Bearded Wonder
Eli Ezrow is my Father
"Josh Cyrul can't walk on f%cking water" - Nancy Filo
Brollywood is offline   Reply With Quote
Old 09-25-2012, 01:22 PM   #7944
Trader Rating: 19 (100%+)
Dremeling a bit off the ear where the gear cover mounts helps as well. On a hard landing the rear flexes that mounting ear into the tower, producing a lever effect against it and, well, snap...
But, the carbon tower is about as bulletproof as it gets. Still have the original CF towers on both buggies, crash tested and Cush approved.
Serpent America/Desoto Racing- www.serpentamerica.com
TrakPower Speed Equipment- www.trakpowerusa.com
B Fast RC Performance- www.bfastrc.com
Futaba | Strictly R/C- Norridge, IL
Thank you all for the help and support!
Jonny5 is offline   Reply With Quote
Old 09-25-2012, 04:03 PM   #7945
dubum's Avatar
Trader Rating: 85 (98%+)
Thumbs up
Originally Posted by ekt View Post
I would contact Team Durango at support@team-durango.com.
To convert to the aluminium chassis you would need -
MAIN CHASSIS PLATE Part No: TD320125
CHASSIS SIDE POD SET Part No: TD320122
3x10mm CS Screws x12 For mounting the side pods and rear suspension holders.
And probably a new body since the RTR has a +8mm chassis
DEX210 CLEAR BODY SET (INCLUDES DECALS & MASKS) Part No: TD402009
I think that is it.
I have contacted them and I am interested in what they have to say. In the meantime I think I will convert to the aluminum chassis. I also had no idea the rtr was a +8 chassis. Maybe I will go with the +8 carbon chassis right away. Any bad words to say about the 8-Racing CF chassis?
Thanks for your help, I really appreciate it.
dubum is offline   Reply With Quote
Old 09-25-2012, 04:12 PM   #7946
ekt
ekt's Avatar
Here are the DEX210 ones, they are both +8
Standard
http://www.team-durango.com/part-inf...artNo=TD320163
Stiffer
http://www.team-durango.com/part-inf...artNo=TD320220
ekt is offline   Reply With Quote
Old 09-25-2012, 04:36 PM   #7947
Torian4000's Avatar
Trader Rating: 49 (100%+)
Just bought at 210 yesterday! I've been an 8th scale nitro junkie for the last 10 years. I'm looking forward to racing 10th scale buggy. What are some common issues with the buggy other than the circlip in the ball diff?
Torian4000 is offline   Reply With Quote
Old 09-25-2012, 06:09 PM   #7948
DBL15's Avatar
Thumbs up
can not say anything bad about them at all i love my 8 - racing 8mm chassis its awesome and for stock racing saved a fair amount of weight and well
car just feels so planted compaired to the smaller chassis IMO
C/O Coast2coastrc (www.coast2coastrc.com.au) SMC Lipo
Tekno Rc , Team Tekin , Panther-Rc , De Racing , Upgrade Rc , Team Triton rc , M2C clutches , Nitro X fuels
DBL15 is offline   Reply With Quote
Old 09-25-2012, 06:43 PM   #7949
rcjunky1's Avatar
After handling the dex210 rtr, I'm going to say the regular +8mm chassis probably won't be the chassis to get, it has so much flex its crazy, so much it would be tempting to run solid links instead of shocks on carpet, it has more flex then my duratrax evader, and as much as the desc210r. I'd go with the 8 racing one if you want one now or wait for me to release my aluminum one. Other then that (and the weird body) the rtr looks pretty good, just add your tires and set up of choice and go racing. It has the same springs as the kit so it probably won't have much steering out of the box with its hard tires, but for $420 its a great price.
Official distributor of Dan-O-Mite Custom Parts- Durango 210 RF pivot blocks
Andrew Butters' Burghgraef
Team Durango Canada
Great Hobbies, Hobbico, Skyrc, Exotek
rcjunky1 is offline   Reply With Quote
Old 09-25-2012, 07:48 PM   #7950
Panda-PR's Avatar
Hi, I'm building mine MM4 and when I installed the plastic gear cover on the motor plate it scrubs a little on the gear cover. Is this common or I missed something?
snake pit:
Serpent: S811T TE-Novarossi Roma/Werks 2058 | S811b-e 2.0
Kyosho MP9 TKI3 Nova 4btt wc & Losi SCTE 2.0
Thanks to Merlin Fuel/Sweep Tires
Panda-PR is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16564 08-19-2017 05:06 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
