Like Tree26Likes
Old 09-16-2012, 09:27 AM   #7801
Trader Rating: 61 (100%+)
Default TRESERY carbon rear ballstud fix
hey guys quick question on using the tresery carbon u-bracket for the rear ballstuds
is it necessary to replace the bulkhead once it has broke or can you simply put the carbon bracket tresery sells over the top and keep on trucking ?
thanks in advance
LATER COOKIE
TEAM REDS RACING ENGINES USA
TEAM PROLINE-RACING
TEAM RC AMERICA/XRAY/HUDY
zixxer is offline   Reply With Quote
Old 09-16-2012, 09:39 AM   #7802
Trader Rating: 38 (100%+)
Originally Posted by zleader_99 View Post
Can some explain the difference in running the car in either mm3 or mm4. I picked dex210 to run carpet indoor a few months back. I came setup mm3. I have not changed it as I was missing the parts for mm4 and just left it.
You are probably going to want to run it MM, all the guys at my track are running their rango's and TLR's in mid, I tried running mine in RM3 and it pushed like crazy.
don't take it too serious, they are toys....
vw addict is offline   Reply With Quote
Old 09-16-2012, 09:47 AM   #7803
Trader Rating: 520 (100%+)
MM3 is a 3 gear transmission, MM4 is a 4 gear. Basically it is the direction of the motor spins that makes them different (other than the extra idler). MM4's motor direction drives the rear end down, providing more rear traction and less steering, where MM3 will lessen rear traction and increase steering to a degree.
flame56mx is offline   Reply With Quote
Old 09-16-2012, 09:59 AM   #7804
Trader Rating: 19 (100%+)
thanks in advance
It's a straight bolt on part. You also don't have to remove the ballstud mounts from the tranny case, but it's recommended for maximum adjustability.
XRAY, RC America, MOTIV, Sanwa, Arrowmax, Neverlift Racing Apparel
Jonny5ive Designs- by racers, for racers!
Jonny5 is offline   Reply With Quote
Old 09-16-2012, 10:01 AM   #7805
Matt Howard's Avatar
thanks in advance
you can keep on trucking, it doesn't use the stock camber link mount at all so if you did break it you can install the tresrey setup and keep running without replacing the gearbox
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 09-16-2012, 11:32 AM   #7806
jonski's Avatar
Trader Rating: 239 (99%+)
We did it on our 1/8 scale tires, but is everyone punching holes in 1/10 tires and rims? Front as well? Thanks guys
jonski is offline   Reply With Quote
Old 09-16-2012, 11:55 AM   #7807
I punch holes in the tires and tape the holes in the rims for closed cell foams, and just use the holes in the rims (no punch) for open cell foams.
Old 09-16-2012, 12:20 PM   #7808
thanks guys
anyone trying the gear diff with any success
LATER COOKIE
TEAM PROLINE-RACING
Old 09-16-2012, 03:05 PM   #7809
+1. Same here.
Old 09-16-2012, 03:52 PM   #7810
Trader Rating: 15 (100%+)
Default ??
I am planning on running the blinky class. I was wondering what motor seems to work the best with the Tekin RS Pro and what gearing?
Mike Hyams
Vehicles: Losi 8ight 2.0, Xray XT8, Losi SCTE, Top Photon, CRC Gen X10
mdhyams is offline   Reply With Quote
Old 09-16-2012, 04:39 PM   #7811
Trader Rating: 20 (100%+)
Default Thanks
Thanks for your input.. In mm3 I have so much steering I have to dial it out. I going to try mm4 see how that goes..
TLR 22
Desc410r
zleader_99 is offline   Reply With Quote
Old 09-16-2012, 06:59 PM   #7812
Aaronk99's Avatar
Johnny, what shock oils,pistons,springs are you running on cush's 210 for indoor with shorty pack?
Team Xray X12-Speed passion GT2.1-Trinity d3 13.5
TLR 22 - Speed Passion Reventon Pro - V 3.0 6.5t
Lesiure Hours Raceway&Hobby shop
Aaronk99 is offline   Reply With Quote
Old 09-16-2012, 08:04 PM   #7813
Don't mean to answer for Jon, but I think his latest set-up is here:
http://www.petitrc.com/setup/durango...ngoDEX210.html
Old 09-16-2012, 08:07 PM   #7814
Thanks man! That's the one. Not much has changed really except for Tresrey rear hubs and removing 1mm from the rear camber link.
Old 09-16-2012, 09:59 PM   #7815
Does anyone know if the TLR 22 gear diff fits?
I have already tried tthe sc10 gear diff, and just built up the durango one. I don't really like either one but DO want to run gear diff. It seems like the TLR is the remaining option, but wondering on the fitment.
dr_speed is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16572 10-14-2017 01:35 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
