Like Tree26Likes
Old 09-12-2012, 03:03 PM   #7711
Trader Rating: 74 (100%+)
Originally Posted by vw addict View Post
can someone please help me here, did a bunch of searching of the thread today and came up with nothing other than that I should have gobs of steering. I don't, I read that 4 gear might be my issue, but just cracked the tranny open, 3.
try adding internal limiters in the shock especially on the rear. ? Carpet offroad is not my thing. I would look on Oople to find a fast carpet setup.
Team and Sales Manager for USRC Imports, home of Sworkz! Looking for drivers for 2017-2018, KingMax Servos www.kingmaxhobby.com Gens Ace www.gensace.com, MIP www.miponline.com,Schelle , WWW. Schelleracing.com, Slavich Designs, GARCIA GRAPHIX
CHECK OUT GARCIA GRAPHIX ON FACEBOOK -LOOKING FOR 2017 TEAM DRIVER'S!
Raul Garcia is offline   Reply With Quote
Old 09-12-2012, 03:19 PM   #7712
Trader Rating: 38 (100%+)
Thanks for the reply, but I don't think that is the issue either. I don't limit any of my other buggies. The problem is I am pushing like crazy on and off power. Thought I was supposed to have tons of steering? My RB5 and B4.1 both have too much steering.
don't take it too serious, they are toys....
vw addict is offline   Reply With Quote
Old 09-12-2012, 03:49 PM   #7713
dmatter's Avatar
Ok guys I figured out my problem with the diff. It appeared to me that the hole in the plastic nut was big enough for the screw to come through, I was wrong. I recommend before building the diff hold the nut with pliers or a vice, something that wont mar up the nut too bad and thread the diff screw completely through once. I thought the spring was totally compressed because the screw was totally stopping. But thats not what happens, the screw hits the super tight plastic "which is good" but makes you think your spring bottomed out. So after cleaning up the threads once and a rebuild the diff tightened up properly and came out super super nice! I wound up with the ears 1.75mm from the end of the slot in the outdrive which is great! With a little more break in it will come over even a little bit more.
Thanks Guys
Dax
dmatter is offline   Reply With Quote
Old 09-12-2012, 03:56 PM   #7714
Matt Howard's Avatar
not many people in the states run on carpet, but I would start with MM3 and tune from there as that setup should have the most steering
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 09-12-2012, 04:32 PM   #7715
Carpet shouldn't be a factor here. All I am asking is a basic way to get rid of push.
Old 09-12-2012, 04:56 PM   #7716
Trader Rating: 21 (100%+)
What caster are you running up front. It's very easy to have the wrong inserts in.
AE B6
AE B64
kerby is offline   Reply With Quote
Old 09-12-2012, 05:01 PM   #7717
I don't know. What should I be looking for? I just got the car and am a total n00b.
Old 09-12-2012, 05:15 PM   #7718
If you cut the 0 inserts its 25 degrees. Here's a link. Take a look at the insert and caster section. Hope this helps. http://www.petitrc.com/setup/durango...ngoDEX210.html
AE B6
AE B64
Old 09-12-2012, 05:31 PM   #7719
Thanks for the link bro, I'm on it like white on rice.
Old 09-12-2012, 06:10 PM   #7720
Send a message via AIM to MMor101
How are the electronics in the RTR DEX?
MMor101 is offline   Reply With Quote
Old 09-12-2012, 06:21 PM   #7721
jonski's Avatar
Trader Rating: 239 (99%+)
It's not out yet.
jonski is offline   Reply With Quote
Old 09-12-2012, 06:22 PM   #7722
Originally Posted by jonski View Post
It's not out yet.
http://www3.towerhobbies.com/cgi-bin...=LXCLZD**&P=ML
Old 09-12-2012, 06:33 PM   #7723
air8's Avatar
Originally Posted by MMor101 View Post
Might have to wait a few weeks until people actually start using them...since they're still new and all. Is that fair??
--Driver...you are cleared into the track.....Smoke On.
--"U Ain't Fast!!"
Chris Pearce
air8 is offline   Reply With Quote
Old 09-12-2012, 06:38 PM   #7724
Didn't know they were new! Sounds fair to me...
I'm trying to find some specs on the steering servo. The motor/ESC combo looks good.
Old 09-12-2012, 06:49 PM   #7725
carpet is a factor here, that's what you're running on. Durango recommends running mid motor when running on carpet or astroturf because that configuration generates more steering. A rear motor car generates too much rear traction for carpet
RCTech #361
St Ives RC Club B4Bandit Australian Racing 16572 10-14-2017 01:35 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
