Like Tree26Likes
Old 09-09-2012, 07:15 PM   #7636
Trader Rating: 520 (100%+)
[QUOTE=Chief;11192018][QUOTE=flame56mx;11191838]
Originally Posted by Chief View Post
I run Kyo cups, ballstuds and turnbuckles, **Kyosho has three different length ball cups designed for the turnbuckles ** I have plenty of room for camber running the med length ball cups, which end of the car are you having an issue?
The issues is with the front. I'm using the med cups. Should I be using different turnbuckles because mine are still stock?
maybe so, the med cups are the same I am using, but Im also using Kyosh links...The durango links seem a bit longer than the Kyosho links I used, only fix I can see is to use the shorter Kyosho cups if you have them..
flame56mx is offline   Reply With Quote
Old 09-09-2012, 09:04 PM   #7637
Chief's Avatar
Trader Rating: 14 (100%+)
[QUOTE=flame56mx;11192092][QUOTE=Chief;11192018]
Ok. Thanks for the help.
What Kyosho links are you using?
____________
TC6
B4.1
FT SC10
Chief is offline   Reply With Quote
Old 09-10-2012, 12:25 AM   #7638
DBL15's Avatar
Ok guys. I have looked on a number of pages and there is quit a few different gearing be said
17.5 blinky mode
I have seen from 75/26 right up to 75/34
What are most using for 17.5 blinky gearing
C/O Coast2coastrc (www.coast2coastrc.com.au) SMC Lipo
Tekno Rc , Team Tekin , Panther-Rc , De Racing , Upgrade Rc , Team Triton rc , M2C clutches , Nitro X fuels
DBL15 is offline   Reply With Quote
Old 09-10-2012, 12:53 AM   #7639
So*Cal AFDude's Avatar
Trader Rating: 21 (100%+)
17.5 blinky mode
I'm rocking 69/31-33! Running a Viper motor.
-Aaron Willming
~ Hobby-Pro USA ~ Viper-RC ~ IERC Raceway ~
www.IERCRaceway.com - www.Facebook.com/IERCRaceway
So*Cal AFDude is offline   Reply With Quote
Old 09-10-2012, 02:45 AM   #7640
ajj
ajj's Avatar
Trader Rating: 18 (100%+)
I run 69/34 with a Speed Passion MMM 17.5 and 15 degrees can timing. Never felt like overheating (5min races).
AJ
Associated SC5M, Hot Bodies D413, Durango DEX210, Durango DEX410, Mugen Seiki MBX7R
ajj is offline   Reply With Quote
Old 09-10-2012, 03:36 AM   #7641
scr8pn4205's Avatar
Big track I run 69/35 Tekin 17.5 blinky timing at 15. Indoor track I usually go to a 33 pinion.
Airtronics M12
Team Xray XB2 2017 CE
TSR power
scr8pn4205 is offline   Reply With Quote
Old 09-10-2012, 03:50 AM   #7642
DBL15's Avatar
Bummer I thought you were all running 75 spurs as I didn't buy any 69
Old 09-10-2012, 05:08 AM   #7643
ekt
ekt's Avatar
35/75 works for me, you need to dremel a bit of the gear cover to make it fit.
ekt is offline   Reply With Quote
Old 09-10-2012, 10:23 AM   #7644
I had some stockers left over from a zx5/rb5 kit.
Old 09-10-2012, 01:46 PM   #7645
jackcarter3's Avatar
Where can I find Ghea racing 4x1.2 and 4x1.3 tapered pistons for the 210? All I can find is 6 hole.
jackcarter3 is offline   Reply With Quote
Old 09-10-2012, 01:50 PM   #7646
murky123's Avatar
you should have gotten a few blanks with the kit you can drill those at your liking
AE SC10 4x4, Durango DEX210 + DESC210R, HB D413
www.rcracing.nl www.mvb.nl
murky123 is offline   Reply With Quote
Old 09-10-2012, 01:54 PM   #7647
zipperfoot's Avatar
Trader Rating: 16 (100%+)
Thats what i did.
zipperfoot is offline   Reply With Quote
Old 09-10-2012, 01:56 PM   #7648
I want tapered pistons.
Old 09-10-2012, 01:56 PM   #7649
coaltrain's Avatar
Any idea what standard size bits are 1.2 and 1.3
DEX210 DEX410 MIP-SCTE
coaltrain is offline   Reply With Quote
Old 09-10-2012, 02:00 PM   #7650
zipperfoot's Avatar
I used a #55 bit (1.32mm) for 1.3mm, and #56 (1.18bit) for 1.2mm. Thats the closest I could find.
St Ives RC Club B4Bandit Australian Racing 16568 09-15-2017 05:07 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
Currently Active Users Viewing This Thread: 3 (1 members and 2 guests)
Lloyd16
