Durango DEX210 Thread
#7621
#7623
the only thing thats week is the steering rack get a cardon one.
#7624
I practiced with the car the other day. I had some binding with one axle. I found it was a combination of the axle and too much pressure on the bearing from tightening the hex. The buggy felt undergeared and as a result i took some hard hits and a couple of tumbles not being able to clear the triple. I fixed the axle, but the moral of the story is I did not pop off one ball cup. They seemed soft, but stayed on the car. The Buggy held together fantasticaly.
Fyi the Tresrey hexes come with two shims for each side. I only used one per side. Took the pressure off the bearings.
#7629
well since i got the car used and after my trophy race i thought i would rebuild my diff WOW what a pain it is to get to the diff take the WHOLE rear end off to get to it REALLY couldnt they come up with a better way . I guess ill see how long it is till the next time i have to rebuild it ,im hoping its a while .
#7630
R/C Tech Elite Member
#7634
[QUOTE=Chief;11191788]
I run Kyo cups, ballstuds and turnbuckles, **Kyosho has three different length ball cups designed for the turnbuckles ** I have plenty of room for camber running the med length ball cups, which end of the car are you having an issue?
I am running the black Ti shafts also..
#7635
[QUOTE=flame56mx;11191838][QUOTE=Chief;11191788]
The issues is with the front. I'm using the med cups. Should I be using different turnbuckles because mine are still stock?
