Like Tree26Likes
Old 09-07-2012, 08:28 AM   #7591
Panda-PR's Avatar
Originally Posted by Jonny5 View Post
Thanks, added to the cart.
Is this the front weight I need?
http://www.tresrey-usa.com/cream-fro...ex210-dest210/
snake pit:
Serpent: S811T TE-Novarossi Roma/Werks 2058 | S811b-e 2.0
Kyosho MP9 TKI3 Nova 4btt wc & Losi SCTE 2.0
Thanks to Merlin Fuel/Sweep Tires
Panda-PR is offline   Reply With Quote
Old 09-07-2012, 09:17 AM   #7592
Trader Rating: 19 (100%+)
We have that installed as well. Really helped get the car balanced out for the way Cush likes to drive it.
Serpent America/Desoto Racing- www.serpentamerica.com
TrakPower Speed Equipment- www.trakpowerusa.com
B Fast RC Performance- www.bfastrc.com
Futaba | Strictly R/C- Norridge, IL
Thank you all for the help and support!
Jonny5 is offline   Reply With Quote
Old 09-07-2012, 02:55 PM   #7593
Trader Rating: 109 (100%+)
Send a message via AIM to kwiksi
A nice alternative..cheaper too.
http://www.exotekracing.com/dex210-d...-brass-weight/
Nice to see a fellow Boriqua on here running Durango!
kwiksi is offline   Reply With Quote
Old 09-07-2012, 04:25 PM   #7594
i saw on someones set up they are using a +8 mm alum chassis is that aval and if so does anyone have a part num .I know using a graphite chassis is lighter can someone running one tell me if they noticed a differance the how the loss of weight down low changed the car i know that the lenght gives stability . thnx
Mike Richardson
At the track having fun with my friends
blingy is offline   Reply With Quote
Old 09-07-2012, 04:58 PM   #7595
Panda-PR's Avatar
Gracias! Carpet is getting big here on the island!
snake pit:
Old 09-07-2012, 05:40 PM   #7596
My younger brother is the one actually driving the car, but I can tell you from watching that the car looks better everywhere on the track. We have both chassis (std length and +8 by 8 Racing, sold by Tresrey-USA) and he says that they both feel more consistent and more forgiving at or near the limits. The extended chassis is much more stable and less aggressive through the turns, and is planted in high speed sweepers. He ran them back to back on the outdoor track and while his fast times were virtually identical, the +8 was much more consistent. He still prefers the standard length cf chassis for small or very technical layouts, but our home track is generally very fast with large jumps and large radius corners, so the +8 sees most of the track time there. Either way, the weight savings is right around 60g and is an improvement from our experience.
The +8 aluminum I saw is from RDRP, and I don't think it's available just yet.
Old 09-07-2012, 05:48 PM   #7597
Autocratic's Avatar
Trader Rating: 26 (100%+)
I just weighted the car with the +8 carbon chassis. Should be right around 1500g race ready. That's with full Lunsford kit, ti screws all around, Tresrey front bulkhead, plastic towers, shorty lipo & servo.
Still need to order another Speed Passion and transponder. Going to mount everything on the chassis inline.
Thanks to my sponsors for 2015!
XFactory RC | Proline Racing | Fantom Racing | Avid RC | Speed Passion USA | Factory1 | Hy-Traction Juice | Mike's Hobby Shop
Autocratic is offline   Reply With Quote
Old 09-07-2012, 06:27 PM   #7598
zipperfoot's Avatar
Trader Rating: 16 (100%+)
You must have some serious coin tied up in that car!
zipperfoot is offline   Reply With Quote
Old 09-07-2012, 06:33 PM   #7599
Trader Rating: 31 (100%+)
Wow that is lite. Is the front bulkhead lighter than stock?
MBX6-ECO, B5m
Cspurlock is offline   Reply With Quote
Old 09-07-2012, 06:37 PM   #7600
Autocratic's Avatar
Yea. It's lighter than I was expecting. It's 60g difference between the stock chassis and +8 carbon. The last time I remember weighting the car I was around 1600g, and that was before the screws and different servo.
The Tresrey front bulkhead is about 8g heavier from what I recall.
Old 09-07-2012, 06:53 PM   #7601
Default Diff
If anyone else has been having problems with their outdrives wearing excessively, I was able to make a hybrid diff using ae outdrives from a sc10 and some of the parts from the TD diff. Only have a few packs through it, but so far so good. The cups are a little longer so the dog bones sit in them a little deeper which i think will help the wear.
MBX6-ECO, B5m
Old 09-07-2012, 07:08 PM   #7602
Autocratic's Avatar
Which SC10 outdrives? The newer flanged or the older flat ones?
Old 09-07-2012, 08:17 PM   #7603
Wow man, that's super light. This gonna be a stock class killer?
Old 09-07-2012, 08:21 PM   #7604
The newer flanged ones. U need lots of shims, but it will work.
Here r the parts I used:
Ae parts:
Sc10 outdrives, Thrust bolt & nut, spring, inner bearings, thrust washer and balls, diff plates
TD parts:
Main gear and balls, outer bearings
Shim between outer bearing and outdrive
MBX6-ECO, B5m
Old 09-08-2012, 03:37 AM   #7605
retsoorkcuf's Avatar
Default gearing for 17.5
Im new to buggies i have been into short course for a while i just bought a dex210 and am looking for a good gearing set up for my tekin 17.5 for a large clay indoor track any help would be appreciated thanks
retsoorkcuf is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16570 Yesterday 03:48 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
