Like Tree43Likes
Old 09-04-2012, 03:53 PM   #7546
Tech Legend
Cain's Avatar
Trader Rating: 239 (100%+)
for those who run this indoors on carpet or a super high bite surface, what motor layout configuration is popular?
Thinking of trying a 1/10 2wd buggy for the winter indoors carpet track. Fan of the B4 line, but not of the screw type they use.
< HB Racing D413 | Tekno EB48SL / SCT410.3 | Tekno EB410 | Yokomo YZ-2 DTM x 2 | LC Racing EMB-1 Buggies and Truggies >
Old 09-04-2012, 04:53 PM   #7547
Panda-PR's Avatar
Hi, what do you guys think of this motor/esc combo for carpet (x3a= 5.5T)
http://www.falconsekido.com/products...o-for-1-10-car
snake pit:
Serpent: S811T TE-Novarossi Roma/Werks 2058 | S811b-e 2.0
Kyosho MP9 TKI3 Nova 4btt wc & Losi SCTE 2.0
Thanks to Merlin Fuel/Sweep Tires
Panda-PR is offline   Reply With Quote
Old 09-04-2012, 09:31 PM   #7548
zipperfoot's Avatar
Trader Rating: 16 (100%+)
Had my buggy out for the second time on a different track. This time the car felt under geared. Went up to 32/69 but still had trouble clearing the tripple with a 13.5. Did not have this issue with the b4.1. Same gearing, motor and esc. I am begining to wonder if it is because the buggy is heavier?
Also, i checked the slipper that was fine the day before but was now super tight, no slipping at all. Had trouble getting it adjusted. When checking it by holding the rear wheels and gassing it, i tried to adjust it, but it would either lift the front wheels about an inch, not at all, or bind completely. I am using AE b4 slipper pads. Any ideas?
zipperfoot is offline   Reply With Quote
Old 09-04-2012, 10:05 PM   #7549
Trader Rating: 19 (100%+)
32/69 seems overgeared to me. Try a 75 pinion also, the larger spur gear, even with the same ratio as a smaller spur, will generate more torque due to it having more leverage.
First, make sure it's not your diff slipping. Then adjust your slipper on the track, not on the bench (after all you don't race on the bench, at least not with cars anyway ) I try to have someone in pit lane with a slipper wrench to tighten/loosen if needed before a race, especially if track conditions change though the night. And once you're close, small adjustments make a big difference- a 1/4 or even an 1/8 of a turn can be all you need. If you can't get it right on the track, maybe try a new spring. There have been some people who couldn't get it tight enough, but it sounds like yours is getting tight enough, just not getting fine tuned where you want it.
XRAY, RC America, MOTIV, Sanwa, Arrowmax, Neverlift Racing Apparel
Jonny5ive Designs- by racers, for racers!
Jonny5 is offline   Reply With Quote
Old 09-04-2012, 10:29 PM   #7550
Trader Rating: 520 (100%+)
Hey Cain, try and get a hold of Joe Z Sr. He runs his @ MMR and has it working really well from what I have heard..
flame56mx is offline   Reply With Quote
Old 09-05-2012, 06:07 AM   #7551
Trader Rating: 61 (100%+)
http://www.rcshox.com/durango-garodisc/
LATER COOKIE
TEAM REDS RACING ENGINES USA
TEAM PROLINE-RACING
TEAM RC AMERICA/XRAY/HUDY
zixxer is offline   Reply With Quote
Old 09-05-2012, 06:28 AM   #7552
Trader Rating: 73 (100%+)
I run on carpet at my local track - anthing between 4.5 to 7.5 turn motor is used
On carpet you can put a lot of power down
Many actually run the 5.5 HW combo with good success.
Chers Matt
mister_g is offline   Reply With Quote
Old 09-05-2012, 07:05 AM   #7553
Default Front hubs
Cut 5.5mm off the DEX210 front axle, screw them on to the back of the DEST210 front axles. Install that into the DEST210 steering hubs along with 5.5mm of 5X7mm spacers. Now the 210 uses the same front and rear wheels/tires as my DEX410v3.
______________________________________________________
Team Tulsa - Team R/C Paints by Sonny - Durango DEX410
qwkpony is offline   Reply With Quote
Old 09-05-2012, 07:07 AM   #7554
kwiksi's Avatar
Trader Rating: 109 (100%+)
Send a message via AIM to kwiksi
If anybody needs shorty packs I have some 4/s.
Thanks in 2017 to
Xray/RC America - JConcepts - Trinity - Sanwa - Hobbywing - Exotek - PT Racing Oils -Schelle
kwiksi is offline   Reply With Quote
Old 09-05-2012, 08:36 AM   #7555
mo
mo's Avatar
What transmission setup are you running? (3 gear or 4?) I had a similar problem when running RM4. Even with a mod motor I was lacking punch and couldn't clear a triple that everyone else could. I kept messing with the diff and slipper and nothing helped. I changed to 3 gear and all of a sudden had a ton of power. Haven't gone back to 4 gear to try and figure out why yet. Hoping to do so soon.
TLR, Spektrum, Tekin, SMC, MO-GRIP, www.factory-rc.com https://www.shapeways.com/shops/MPP
mo is offline   Reply With Quote
Old 09-05-2012, 10:40 AM   #7556
Panda-PR's Avatar
Chers Matt
Thanks!
snake pit:
Old 09-05-2012, 11:22 AM   #7557
discgolferlee's Avatar
Trader Rating: 42 (100%+)
what color springs come with the dex210?
discgolferlee is offline   Reply With Quote
Old 09-05-2012, 11:43 AM   #7558
zipperfoot's Avatar
I am running three gear. The final drive was the same as the B4.1 at 2.6, so I used the same gearing. I started at 31/69, went to 32/69, and then to 33/69 at a local track with a medium sized triple. With a 13.5, you had to have a fresh battery and line it up properly to clear it even with the B4.1 Worlds, but the 210 was a struggle from the get go.
I also took the motor and ESC right out of the B4 and placed it in the 210. Reset the radio and end points and was good to go. I should point out I am not using timing or boost, so with the 210 being heavier than the B4, it may just not be enough power to clear it cleanly running a 13.5.
Either way I am happy with the buggy. The buggy is very stable, and easy to drive. I think I found the perfect set up too. Using the stock dark blue springs in front with 4 hole, 1.3 pistons, and 35 wt Losi oil, and stock light blue springs in rear with 4 hole, 1.2 pistons, and 27.5 Losi oil in the back. Soaks up everything well, does not bottom, and has plenty of traction.
For me the most surprising thing was the buggy has a ton of steering. I am running a shorty pack all the way forward with a foam spacer in the rear. No weight at all. Very happy.
Old 09-05-2012, 11:46 AM   #7559
Dark blue front and light blue rear. They are good for a starting point, but most wind up one or two rates softer in the front and one or two rates firmer in the rear.
Old 09-05-2012, 11:55 AM   #7560
zipperfoot's Avatar
While testing the buggy, I noticed the transmission had a slight clicking sound and a slight vibration in the rear coming from either the axles or the tranny. At first I thought it was out of true tires.
Since it felt I was lacking for power I took everything apart to check for binding and found the tranny was perfect. I remember Johnny5 stating in a post he found a small burr on one of the gears causing a clicking sound. I inspected the tranny and found nothing.
What I did find was one of the axles was clicking when I turned it by hand. The bearings were fine, but it seems where the driveshaft and bushing meet the axle there was some rubbing of either the pin, bushing, or the driveshaft against the inside of the axle. Cleaned everything reinstalled the axles, placed the pin in a different hole, and everything was smooth.
Has this happened to anyone else?
St Ives RC Club B4Bandit Australian Racing 16576 Yesterday 07:25 PM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-08-2017 12:57 AM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 10:51 PM
