Like Tree27Likes
Old 09-03-2012, 05:39 PM   #7531
yep flame you got it right we were on an outdoor dry slick track i was the only one still pulling wheelies at the end of the day when the track was the slickest , gotta love it.
Mike Richardson
At the track having fun with my friends
blingy is offline   Reply With Quote
Old 09-03-2012, 05:52 PM   #7532
Trader Rating: 520 (100%+)
Yeah, RM4 sounds perfect for that situation..I never found the steering to be too much in that config, but depending on what tire you were using, try something less aggressive, or a different compound.
flame56mx is offline   Reply With Quote
Old 09-03-2012, 07:23 PM   #7533
Dog Runner's Avatar
Trader Rating: 21 (100%+)
Send a message via Skype™ to Dog Runner
Anyone have a new or nearly-new 210 to sell that's not on the For Sale thread yet?
JR
Need a real estate agent? I can help.
Dog Runner is offline   Reply With Quote
Old 09-03-2012, 07:31 PM   #7534
ill post my set up
fr. 4x1.3 32.5 light red mid tower and out on the arm axles inline caster block all the way forward and 1mm under c/l no weight added and steering link forward on the bell crank 22 mm r/h and blue barcodes w/stock foam
rr. 4x1.3 27.5 light red in on tower mid on arm hubs 3mm in front and 1mm in rear c/l #2 w/1mm 3*toe 3*kick and green hybrides w/stock foams my speedo monted behind shorty battery in the mid rec on the left side and 1/4 on right side r/h is 21.5 all of this with rm4 set up
Mike Richardson
Old 09-03-2012, 09:59 PM   #7535
zipperfoot's Avatar
Trader Rating: 16 (100%+)
Took my buggy out for a short test drive today at SRS. Was dry and dusty, since racing was still several hours away. I was amazed at how well it handled. I did end up going with the 4 hole piston mod. Very impressed. All stock except the steering rack in carbon. Bought some drill bits to properly make 4 hole pistons out of the blanks included with the kit. Was told by staff in the shop they were going to start carrying Durango parts. Off to a good start!
Question, since i run a multiple tracks, does this buggy handle outdoor hard packed and indoor clay fairly well with the same set up? (except for tire selection of course), or am i going to be changing set ups all the time?
zipperfoot is offline   Reply With Quote
Old 09-03-2012, 10:00 PM   #7536
zipperfoot's Avatar
Old 09-03-2012, 10:05 PM   #7537
To answer your question. Yes, the same set-up will work, but to get the most from ANY brand car, you will want to change things according to conditions changing. It may not be all the time, as indoor conditions tend to be much more consistent.
Old 09-03-2012, 10:40 PM   #7538
zipperfoot's Avatar
True. But for me i found my b4.1 worlds set up worked on a variety of tracks with minimal adjustments, but on the other end of the spectrum my Losi 22 needed a lot of tuning depending on the track. I was just wondering where the 210 fit into the scope of things.
Old 09-03-2012, 10:41 PM   #7539
Trader Rating: 19 (100%+)
+1. Cush's setups for our home tracks tend to be very similar outdoor/indoor, provided the outdoor track is groomed with good traction. Usually just simple spring/oil changes and battery placement. Both tracks are generally very fast with larger jumps.
XRAY, RC America, MOTIV, Sanwa, Arrowmax, Neverlift Racing Apparel
Jonny5ive Designs- by racers, for racers!
Jonny5 is offline   Reply With Quote
Old 09-04-2012, 08:56 AM   #7540
kwiksi's Avatar
Trader Rating: 109 (100%+)
Send a message via AIM to kwiksi
Anyone know if the TLR alum servo horns (22) have the same offset as the kit servo horns on this buggy?
Thanks in 2017 to
Xray/RC America - JConcepts - Trinity - Sanwa - Hobbywing - Exotek - PT Racing Oils -Schelle
kwiksi is offline   Reply With Quote
Old 09-04-2012, 09:09 AM   #7541
Almost exactly. They are the best servo arm I've found for the buggy yet.
Old 09-04-2012, 09:58 AM   #7542
zipperfoot's Avatar
What's wrong with the stock ones? I am sure the cheap ball cups would pop off before you broke a servo horn!
Old 09-04-2012, 10:12 AM   #7543
kwiksi's Avatar
Thinking about doing this below and was wondering if I should upgrade the horn. The more I think about it. I think the plastic horn would be easier to replace than a servo.
http://www.exotekracing.com/dex210-d...ng-crank-pair/
Thanks in 2017 to
Old 09-04-2012, 10:17 AM   #7544
BLKNOTCH's Avatar
Send a message via MSN to BLKNOTCH
I did this on mine and love the lack of slop I found with the plastic parts.
HB/HPI Racing | Morgan Fuels | HOBBYWING | Airtronics | REDS Racing | HRP | Hobby Revolution | Team N.E.R.D.
BLKNOTCH is offline   Reply With Quote
Old 09-04-2012, 10:45 AM   #7545
Woulvesbaine's Avatar
Zipper,
After racing off and on for years, I have found that Associated cars may be the best for "throwing it on the track" with little adjustment. To this effect, I just put a T4 on the track with the stock (manual) setup on a clay track and it was almost dialed -and it did not even have proper front tires.
I'd be curious to get the same feedback as I am just putting the finishing touches on my 210. This being said, after taking a good 4-5 full practice days to dial in my RB5 SP2, I doubt anything will be so easily dialed in as an Associated.
|| Team C TM4 || OCRC || SCVRC || Facebook: Squid Ink Paint
Woulvesbaine is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16572 10-14-2017 01:35 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
