Like Tree33Likes
Old 08-31-2012, 03:37 AM   #7501
coaltrain's Avatar
Originally Posted by Atomicsickness View Post
From what I have been told the composite +8mm chassis is going to be the same chassis as the RTR. Looks like you will need the RTR body for it also because of the bracing in the front. I'll wait for the aluminum +8mm.
DEX210 DEX410 MIP-SCTE
coaltrain is offline   Reply With Quote
Old 08-31-2012, 06:13 AM   #7502
me too alittle more weight makes it more stable.and it looks cool
zylstra is offline   Reply With Quote
Old 08-31-2012, 06:57 AM   #7503
t8rtot's Avatar
Trader Rating: 14 (94%+)
Originally Posted by coaltrain View Post
Does anyone have an eta for that
Sfida
t8rtot is offline   Reply With Quote
Old 08-31-2012, 10:39 PM   #7504
zipperfoot's Avatar
Trader Rating: 16 (100%+)
Just finished the build. Very impressed with the quality except the ball cups. Running the motor wires cleanly for the rm4 set up proved a challenge.
zipperfoot is offline   Reply With Quote
Old 09-01-2012, 12:16 AM   #7505
onekiwi's Avatar
I think the stock body fits with elongated front holes.
Mid sept the RTRs are planned for release so hopefully around that time.
No official pic of the chassis TD320163 but on oople and TD site you can see it
Jonny5 you say you are no more than 3 pads from front MM stop. What size are the pads?
XB2 CE
XB4 16
Sanwa
Hobbywing
#kiwipaint on facebook
onekiwi is offline   Reply With Quote
Old 09-01-2012, 12:41 AM   #7506
murky123's Avatar
Originally Posted by JosephBlack View Post
Johnny,
When you guys are running the standard chassis, where do you normally run the battery? Do you run it up against the mm batt stop? RM batt stop?
Thanks looking for a starting point.
I run the RM setup. but I removed all the battery stops.
I have used velcro on my chassis and shorty's , that way I have no need for battery foams and I can put my shorty everywhere I want .
All the way up against the servo or all the way in the back against the tranny, or something in between.
My track can change grip levels within the hour. The way I described above I can use the full potential of the weight distribution of this buggy.
we must not forget that this buggy is the most balanced buggy on the market and this weight distribution is absolutely one of its best features.
I have also drilled 2 holes with a body reamer in my stock batterybrace.
When I but my shorty all the way in the back against the tranny, the + and - tabs will disappear under the batterybrace, with those 2 holes I can put the plugs in the tabs.
AE SC10 4x4, Durango DEX210 + DESC210R, HB D413
www.rcracing.nl www.mvb.nl
murky123 is offline   Reply With Quote
Old 09-01-2012, 12:59 AM   #7507
onekiwi's Avatar
When do you have the bat foward and rear? Whats the track like then? What will it do Fwd and Rear
XB2 CE
XB4 16
Sanwa
Hobbywing
Old 09-01-2012, 01:20 AM   #7508
murky123's Avatar
when a blue groove is coming up and there is high traction I will move the battery more forward.
when it is very dusty, low grip or when the track is blown out I move the battery more in the back
Old 09-01-2012, 07:56 AM   #7509
Trader Rating: 19 (100%+)
Guess I should have clarified that, but when I reference battery pads I am referring to AE pads as they are most common.
XRAY, RC America, MOTIV, Sanwa, Arrowmax, Neverlift Racing Apparel
Jonny5ive Designs- by racers, for racers!
Jonny5 is offline   Reply With Quote
Old 09-01-2012, 06:22 PM   #7510
zipperfoot's Avatar
Has anyone ever tried the stock set up?
I always like to set my buggies to factory specs, try it first, and work from there. But with the springs included in the kit and the six hole pistons, the suspension is WAY too soft, and pretty much un-drivable. I used Losi 35 wt oil which according to Durango's chart is the same as the 450 cts they recommend in the manual.
Does anyone have a spring and oil set up I can use with the six hole pistons 1.2 or 1.3?
Old 09-01-2012, 07:08 PM   #7511
The main reason we started running 4 hole pistons is that the car bottoms too easily with 6 holes. You could go way up on oil, but that's more of a band aid. Had the car handling well through the turns with 6 holes, but bottomed even on small doubles. It's pretty easy to close off some holes in the stock pistons- CA glue a toothpick into the hole, trim it off flush on both sides, then put a drop of CA on both sides of the piston to cap the holes off.
Old 09-01-2012, 08:28 PM   #7512
zipperfoot's Avatar
I see that just about everyone runs 4 hole even the team guys. Its a known issue, so why dont they add them to the kit? or sell them as an option?
Maybe they should add some toothpicks to the kit!
Old 09-01-2012, 08:49 PM   #7513
Aaronk99's Avatar
I was running pistons with closed off holes but recently i picked up some of durango's new 4 hole tapered pistons featuring a 1.0mm hole so the car doesnt bottom out as easy,i just tested new layout today and my 210 buggy was screamin'
Team Xray X12-Speed passion GT2.1-Trinity d3 13.5
TLR 22 - Speed Passion Reventon Pro - V 3.0 6.5t
Lesiure Hours Raceway&Hobby shop
Aaronk99 is offline   Reply With Quote
Old 09-01-2012, 08:52 PM   #7514
T-BirdJunkie's Avatar
Location: Norwood, OH...and CCRCR and The OhioRCFactory
Send a message via AIM to T-BirdJunkie Send a message via MSN to T-BirdJunkie
So what oils are you guys running with 4 hole 1.2mm pistons? Was thinking 30 frt/25 rear.
If you don't allow yourself to make mistakes, you'll never allow yourself to succeed
T-BirdJunkie is offline   Reply With Quote
Old 09-01-2012, 08:56 PM   #7515
Aaronk99's Avatar
I was 32.5 frt. 30 rear running same pistons with shorty pack
St Ives RC Club B4Bandit Australian Racing 16572 10-14-2017 01:35 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
