Like Tree26Likes
Old 08-25-2012, 06:49 AM   #7411
I have a question how does rebound affect the handling of the car and why does it seem that the car set ups i see has so much droop in the susp. and has anyone tried running the shocks behimd the tower and flipping the arms around thats all i have for now thnx
Mike Richardson
At the track having fun with my friends
blingy is offline   Reply With Quote
Old 08-25-2012, 08:09 PM   #7412
Autocratic's Avatar
Trader Rating: 26 (100%+)
Originally Posted by Jonny5 View Post
I don't remember the exact numbers, but it's a few grams more than half the weight of the stocker.
Are you and your brother running either carbon fiber chassis?
Thanks to my sponsors for 2015!
XFactory RC | Proline Racing | Fantom Racing | Avid RC | Speed Passion USA | Factory1 | Hy-Traction Juice | Mike's Hobby Shop
Autocratic is offline   Reply With Quote
Old 08-25-2012, 09:51 PM   #7413
Does anyone know the part number for tresrey +8 mm chassis i did search forum and nothing apeared ,thnx
Mike Richardson
Old 08-25-2012, 09:53 PM   #7414
zipperfoot's Avatar
Trader Rating: 16 (100%+)
Did you try.... http://www.tresrey-usa.com/
zipperfoot is offline   Reply With Quote
Old 08-25-2012, 10:28 PM   #7415
Trader Rating: 19 (100%+)
Have one of each and he uses both depending on the track. The standard works better for him on small or tight tracks, but he likes the +8 better on large, sweeping layouts.
Serpent America/Desoto Racing- www.serpentamerica.com
TrakPower Speed Equipment- www.trakpowerusa.com
B Fast RC Performance- www.bfastrc.com
Futaba | Strictly R/C- Norridge, IL
Thank you all for the help and support!
Jonny5 is offline   Reply With Quote
Old 08-25-2012, 10:58 PM   #7416
P6
what gearing for 10.5t novak no boost or timing i have 81 76 87 spurs and 22-25 pinions would 76 24 be okay itll be for indoor high bite clay
P6 is offline   Reply With Quote
Old 08-26-2012, 02:41 AM   #7417
mrjeremyaaron's Avatar
Originally Posted by kwiksi View Post
Where are your spring collars at? No offense, but you are reading the gauge right? I know sometimes I have to look twice on my AE gauge.
Measure it right before the bend for the kick up. I actually got rid of the bumps stops on the plastic pivot. I use 2mm limiters in my front shocks. I had dirt stuck between the bump stop and droop screw so I said screw it.
Off to the races!
Sounds like I was measuring correctly. After putting a pack or two through the new rig the ride height settled for some reason.
Went through at least 8 packs today and I gotta say the 210 might be the best balanced car I've driven i reckon. basically ran the kit setup on what was a very dry, very dusty, medium sized clay track. Would have been undrivable with my b4.1, but managed to give a few mod 4x4's a run while I still had rear tyre tread. No real big jumps to contend with at this track so went right down to 25wt in the rear which kinda gave the semi-chewed tyres a second life.
Love how this car almost doesn't feel like a traditional 2wd, such is the stability in the back end. More inclined to 4w drift instead of spin out (running 4RM initially).. Subtle under steer is a good thing in this class.
mrjeremyaaron is offline   Reply With Quote
Old 08-26-2012, 04:21 AM   #7418
Hi !
Have a problem with my DEX210 and esc/motor.
Yesterday my car started to loose punch and speed and suddenly stopped.
Found it to be the front bearing on my 8.5 Novak Ballistic.
Changed the bearing but the car is still slow and without the punch it used to have. Tried a new rotor and still the same. The esc and motor are also very warm now after about 5mins of running.
The drivetrain have no binding and is very easy to spin.
The esc (Xerun V2.1) also did a default setting on its own 2 days ago.
Sound and light signals works as they should.
Is it the motor or the esc that is the problem you think ?
My collection :
Durango DEX410/210, DEST410
Tamiya AVANTE, PORSCHE 934 1/10, DF03, TB EVO V, TB02, TRF414, TA04R, TRF501X, TRF511, TRF201, TT01210wb, TXT-1, TLT-1, CLOD BUSTER, TOP FORCE, MAZDA 787, RM-01 +++
KYOSHO INFERNO GT2, ST-RR VE, TURBO OPTIMA, OPTIMA MID LWB, ULTIMA +++
ridgeracer is offline   Reply With Quote
Old 08-26-2012, 04:53 AM   #7419
Originally Posted by ridgeracer View Post
Hi !
Most likely more than the front bearing gone on that motor. Know someone with a spare you can test? It took me plugging my 2.1 in the wrong way to destroy it.
Old 08-26-2012, 06:27 AM   #7420
BLKNOTCH's Avatar
Send a message via MSN to BLKNOTCH
I did not see it on the tresrey site so I am thinking it may not be available yet.
HB/HPI Racing | Morgan Fuels | HOBBYWING | Airtronics | REDS Racing | HRP | Hobby Revolution | Team N.E.R.D.
BLKNOTCH is offline   Reply With Quote
Old 08-26-2012, 07:28 AM   #7421
You mean like this: http://www.tresrey-usa.com/8-racing-...ssis-dex210-8/
Old 08-26-2012, 07:32 AM   #7422
i found the chassis its under the 8-racing on the left thnx im still wondering about the rest of my other questions though ,thnx
Mike Richardson
Old 08-26-2012, 07:55 AM   #7423
Jeff Werner's Avatar
Trader Rating: 14 (100%+)
Send a message via Yahoo to Jeff Werner
Well had the first outing with the buggy and man I am pumped. I have been racing Nitro for some time and had not raced 2wd mod since brushed motors.... I came down the drivers stand after the first practice run and was smiling ear to ear. I found the car was just in balance. I read that in an above post and agree. The buggy is just balanced. I had a few little bugs but the night was a blast and I am pumped for the rest of the season. I did learn my lesson on how tight to have the gear case and my gear cover is in need of being replaced. Does anyone make an aftermarket one for the 210? This is a very good buggy. I am glad to be in the Durango camp!
Jeff Werner is offline   Reply With Quote
Old 08-26-2012, 09:01 AM   #7424
discgolferlee's Avatar
Trader Rating: 42 (100%+)
Not trying to spam but figured I would let my Durango peeps know I listed some dex210 wheels and tires in classifieds.
durango dex210 wheel and tire lot.
discgolferlee is offline   Reply With Quote
Old 08-26-2012, 09:13 AM   #7425
Autocratic's Avatar
So is Cush running just the carbon chassis's strictly?
St Ives RC Club B4Bandit Australian Racing 16568 09-15-2017 05:07 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
