Like Tree24Likes
Old 08-16-2012, 06:15 PM   #7261
Trader Rating: 109 (100%+)
Send a message via AIM to kwiksi
Originally Posted by zipperfoot View Post
Really sitting on the fence trying to decide whether or not to buy this car. I tried the 22 but never quite got it dialed to my liking. The B4.1 was pretty good out of the box, and really good with some minor mods.
I really like the quality of Durango, and even though my local shops do not stock parts, I can order them online in bulk. Recently I have found most of the local shops carry less and less of the most used parts for the B4 and 22 anyway.
So before I pull the trigger, I read several thousand pages on this thread, and based on your suggestions, I will only need a few minor parts to make the car bullet proof.
What are the most common parts to break and what should I stock up on?
Who's set up should I start out with as a baseline for a medium bite, outdoor dirt and clay track? What about indoor clay?
The buggy is real durable. I def would get the carbon/alum steering plate. Just the std...towers, arms, etc. I have only broke a rear tower since the car first came out. I have a lot of nip that never get touched. Lol.
I have a nice low to med traction outdoor setup listed here. I really like the benefits of RM4 outdoors where grip low to med.
http://www.petitrc.com/setup/durango...603/index.html
There are many other setups you can choose from for specific conditions as well here. http://www.petitrc.com/setup/durango...ngoDEX210.html
kwiksi is offline   Reply With Quote
Old 08-16-2012, 07:19 PM   #7262
slow_jun's Avatar
Trader Rating: 14 (94%+)
Default dex 210 part Numbers
Guys,
need your help, can someone direct me to the full DEX 210 Gear diff parts lists Link/site, Im trying to get all these parts from Amain, dont ask why please... and please dont tell me just get the whole set from Tower, reason why is shipping is much cheaper at Amain than in tower... thats the reason.. hahahah...
Im missing this two parts, Highlighted below.
can some one give the link/ part numbers so that i could proceed to order it at amain.
note. E clips is already taken care off.
is the shim on the top most part this one , for the oring washer cover?
http://www.amainhobbies.com/product_...mm-Shim-Set-10
and the lower shims ( gear shims) , is it this one?
and the screws , is it this one?
http://www.amainhobbies.com/product_...x-Screw-Set-10
thanks again guys..
Mag 3 taon, tapos isalpak pa sa PAGMUMUKHA KO......... tagal....Deeeeymmm!!!
slow_jun is offline   Reply With Quote
Old 08-16-2012, 07:55 PM   #7263
Trader Rating: 19 (100%+)
Originally Posted by slow_jun View Post
Guys,
thanks again guys..
You've got them right man.
Serpent America/Desoto Racing- www.serpentamerica.com
TrakPower Speed Equipment- www.trakpowerusa.com
B Fast RC Performance- www.bfastrc.com
Futaba | Strictly R/C- Norridge, IL
Thank you all for the help and support!
Jonny5 is offline   Reply With Quote
Old 08-16-2012, 07:56 PM   #7264
slow_jun's Avatar
Hi Johnny5
thanks you so much Sir... you dont know how much you helped me... hahaha..
thanks a million...
Old 08-16-2012, 07:58 PM   #7265
zipperfoot's Avatar
Trader Rating: 16 (100%+)
Thanks for the help and info! I never had this kind of support with other brands.
zipperfoot is offline   Reply With Quote
Old 08-16-2012, 08:31 PM   #7266
Tate72's Avatar
Trader Rating: 52 (98%+)
And this is why Team Durango will be on top!!
Team Durango, http://www.team-durango.com/
TrakPower Speed Equipment, http://www.trakpowerusa.com/
DE Racing, http://www.deracing.net/
WWW.JCPRCRACEWAY.COM
Tate72 is offline   Reply With Quote
Old 08-16-2012, 08:36 PM   #7267
snaketaco's Avatar
Thinking about trying the gear diff just for fun. What fluid should I start with for a low to medium out door track? Thanks for all the help.
My apologies for any errors in grammar, and spelling. It's a forum not a term paper! STADIUM TRUCK FOREVER!!!
Some day I want to be one of the guys with the cool T shirts and fancy stickers. I bet they get all the girls!
snaketaco is offline   Reply With Quote
Old 08-16-2012, 08:47 PM   #7268
zipperfoot's Avatar
Ive read a popular choice is to coat the parts with AE black grease.
Old 08-16-2012, 09:09 PM   #7269
P6
anyone try out the revolution designs bass front suspension block yet or how about the exotech rear hubs , the ball stud moved to the next hole over on a really light hit so i was thinking aluminum would be good , and the suspension block is just weight to the front for my aggressive bad driver style and it looks easier to clean than plastic
P6 is offline   Reply With Quote
Old 08-16-2012, 11:17 PM   #7270
DBL15's Avatar
Black grease mate just enough to cover the gears.
Will take about 2 or 3 lipos to loosen up then they are perfect
C/O Coast2coastrc (www.coast2coastrc.com.au) SMC Lipo
Tekno Rc , Team Tekin , Panther-Rc , De Racing , Upgrade Rc , Team Triton rc , M2C clutches , Nitro X fuels
DBL15 is offline   Reply With Quote
Old 08-17-2012, 12:26 AM   #7271
snaketaco's Avatar
Cool black grease it is. Sounds easy enough. Thanks
Old 08-17-2012, 04:09 AM   #7272
Your welcome. That's what we're here for.
Old 08-17-2012, 02:46 PM   #7273
Trader Rating: 31 (100%+)
Default diff
I wanted to ask anyone here that has tried the sc10 gear diff in the car for some help. I would be interested to know if you did anything other than just shim it(which is all that I have read)? I am trying to fit a B4.1 diff in my buggy and it seems that the gear is a little smaller in diameter, so assuming the sc10 diff was the same size I was wondering how you dealt with that?
And to answer the question that I know is coming, I am doing it because the outdrives on this car suck! I know some of you don't have problems, but I also know a lot of people that do, and I unfortunately fall into the latter, so I want a solution.
Thanks in advance!
MBX6-ECO, B5m
Cspurlock is offline   Reply With Quote
Old 08-17-2012, 03:08 PM   #7274
EvanAZ's Avatar
Trader Rating: 99 (100%+)
Thanks in advance!
I have a B4/SC10 BALL diff in mine, it requires 2 bearings on each side and shrink wrap on the outdrives to take up the slop. I just had it apart changing it from RM4 to RM3 and should have taken pics.
Hope this helps.
**Over The Top RC - Cars for Kids Program**
***Looking for a responsible person to help run the track and program***
EvanAZ is offline   Reply With Quote
Old 08-17-2012, 03:24 PM   #7275
kbish76's Avatar
Default Thanks
Thank you all for the info and help regarding the set-ups and lipo choices. It's almost ready to run! I will let you know how it goes.
kbish76 is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16564 08-19-2017 05:06 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
