Like Tree26Likes
Old 08-11-2012, 02:36 PM   #7171
SoCalGuy's Avatar
Hey guys,
Finishing up the build and need a good starting point for the shocks. I've looked at numerous set up sheets and it seems to be all over the place.
Plan on starting out with the stock (kit) springs (unless you advise differently).
Seems most are using 4 hole pistons; should I drill out the included blanks?
Which diameter holes to start with?
What weight oil for front / rear?
Just looking for a good starting point to get me going. Also, starting w/ 30* caster, 1mm trailing, 3* rear toe, 3* antisquat. Small clay track; pretty slow and technical.
Thanks again guys!
SoCal
Mugen MBX6 Eco, Kyosho ZX-5 FS2, Team Durango DEX210
Tamiya TB-03, Tamiya M-05 Pro, Associate 18R, Vaterra Kemora
SoCalGuy is offline   Reply With Quote
Old 08-11-2012, 03:08 PM   #7172
Furtado66's Avatar
Originally Posted by SoCalGuy View Post
Hey guys,
Thanks again guys!
SoCal
Setup also depends on if your are going to use shorty packs or full size.
Furtado66 is offline   Reply With Quote
Old 08-11-2012, 03:41 PM   #7173
SoCalGuy's Avatar
Good point; full size to start, and most likely a 24 gram weight under the servo.
SoCal
Old 08-11-2012, 04:38 PM   #7174
JeremyHarris's Avatar
SoCal
I advise against the any weight especially if you're using a full sized pack. I run 4 x 55 hole tapered pistons with AE 30 up front and AE 27.5 in the rear and I use black springs front and rear. But it also depends on track conditions more than anything.
Jeremy G. Harris
Pro-Line-RCWrapz-LFR-SXT-KustomRCGraphics-Airtronics-Team Associated-Reedy-LRP-Superiorhobbies.com
JeremyHarris is offline   Reply With Quote
Old 08-11-2012, 05:30 PM   #7175
SoCalGuy's Avatar
Thanks Jeremy. Where can I find these; sounds easier than drilling out (or filling the holes) in mine.
Old 08-11-2012, 06:05 PM   #7176
I ordered mine from Nick off of Oople. I have tried them both Taper up and Taper down and prefer taper down on most surfaces but there is a huge difference between standard piston and tapered (either way). I ran 4 x 55 standard pistons, as well. I used a finger drill and #55 bit and drilled out the blank ones from the kit.
Jeremy G. Harris
Old 08-11-2012, 07:08 PM   #7177
Slimsh8t's Avatar
Trader Rating: 39 (100%+)
Has anyone using the lunsford turnbuckle kit had any problem with the ball cups breaking. I had 2 break today in half with the cup still on the ball. Just spent $80 bucks for these things and so far not impressed.
Kevin Murphy
Associated B5m/Reedy
AP Custom Paint/Kal-Gard/
Slimsh8t is offline   Reply With Quote
Old 08-11-2012, 08:39 PM   #7178
Trader Rating: 31 (100%+)
Hey guys,
Thanks again guys!
SoCal
Definitely wouldn't do 1mm trailing, do 4mm.
Ur track sounds like mine. Don't use kit springs, they are for MM setup. Dk grn or blk front and dk blue rear is what I would advise. 30 front 25 rear. Pistons r pretty much the same for most people 4x 1.2rear 4x1.3 front, look at some setups on petit rc and you will see what people r running on clay.
http://www.petitrc.com/setup/durango...ngoDEX210.html
Pistons are done by most by glueing 2 of the holes shut on stock piston which is 6x 1.2 with CA or epoxy.
MBX6-ECO, B5m
Cspurlock is offline   Reply With Quote
Old 08-11-2012, 09:26 PM   #7179
zipperfoot's Avatar
Trader Rating: 16 (100%+)
I just got my B4.1 worlds dialed in and handling just the way I want. So that means it's time to sell it and try something else. Did the 22 thing and was always chasing a set up. Started stock did every mod in the book but could not get it to hold a tight line around the track. From what I am reading it kind of looks like the same thing with the 210. Is there a base set up that works on a variety of tracks or am I going to be playing with oils, pistons and springs in a never ending cycle of trying to get traction and handling at each track I visit? Ya it's all part of the fun, and the 22 definitely improved my diff building skills after five rebuilds in 1.5 months, but still I would like to know what I am in for!
I tried the 410 and noticed that at my local track there were guys using four completely different set ups on four different buggies. Which means to me there was no baseline set up.
zipperfoot is offline   Reply With Quote
Old 08-11-2012, 09:49 PM   #7180
There is no easy button with car setups. This car and the 22 are very tunable and the smallest adjustments make a very large difference. It will take time to develope your own setup because everyones "dialed" set up may not work for you at your track(s). I have a "base" setup for Florida tracks but I do have to fine tune at each different track. My original kit diff had 100+ runs on it and still felt new. The only reason I rebuilt it is because I was for the Reedy Race. Once you finally get a set up on this car that works for you its well worth it.
Jeremy G. Harris
Old 08-11-2012, 10:26 PM   #7181
zipperfoot's Avatar
Thanks for the honest answer. This was kind of a test post as well to see what kind of responses i received. If i posted this question about the b4 on their forum, i would have received smart [email protected]&$d answers galore. Looks like i may have found a new home.
Old 08-12-2012, 01:35 AM   #7182
DBL15's Avatar
rear front suspension 3toe 3kick up
in metal anyone know who makes them ?
C/O Coast2coastrc (www.coast2coastrc.com.au) SMC Lipo
Tekno Rc , Team Tekin , Panther-Rc , De Racing , Upgrade Rc , Team Triton rc , M2C clutches , Nitro X fuels
DBL15 is offline   Reply With Quote
Old 08-12-2012, 01:50 AM   #7183
onekiwi's Avatar
Rcjunky here on the forum or tresrey 2 with spacers
XB2 CE
XB4 16
Sanwa
Hobbywing
#kiwipaint on facebook
onekiwi is offline   Reply With Quote
Old 08-12-2012, 02:15 AM   #7184
ekt
ekt's Avatar
http://www.teamsr.co/shop/product.asp?l=Durango
They make 0, 1.5 and 3
ekt is offline   Reply With Quote
Old 08-12-2012, 05:47 AM   #7185
TSR
Jeremy G. Harris
St Ives RC Club B4Bandit Australian Racing 16570 Today 03:48 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
