Like Tree23Likes
Old 08-08-2012, 03:22 PM   #7141
BLKNOTCH's Avatar
Send a message via MSN to BLKNOTCH
Originally Posted by Cream View Post
Nice to read :-)
Will the front tower work with the Tresrey front bulkhead? or is that what the aluminum parts are?
Sean
HB/HPI Racing | Morgan Fuels | HOBBYWING | Airtronics | REDS Racing | HRP | Hobby Revolution | Team N.E.R.D.
BLKNOTCH is offline   Reply With Quote
Old 08-08-2012, 03:31 PM   #7142
Trader Rating: 19 (100%+)
Sean
The Tresrey bulkhead works perfectly with the Cream front tower- the aluminum parts on it are the ballstud mounts.
Serpent America/Desoto Racing- www.serpentamerica.com
TrakPower Speed Equipment- www.trakpowerusa.com
B Fast RC Performance- www.bfastrc.com
Futaba | Strictly R/C- Norridge, IL
Thank you all for the help and support!
Jonny5 is offline   Reply With Quote
Old 08-08-2012, 03:31 PM   #7143
Cream's Avatar
Sean
Yes, It's a direct replacment for the original part. The aluminium parts are designed to keep the ball studs in the original position and plain, and only weigh 8.4g (4.2g each)
Original concept is here.
http://www.oople.com/forums/showthread.php?t=83523
Cream Extreme R.C.
http://www.oople.com/forums/forumdisplay.php?f=219
Cream is offline   Reply With Quote
Old 08-08-2012, 03:40 PM   #7144
Originally Posted by Evil Genius jr. View Post
Well I'm researching 2wd buggies and now I'm going to ask you guys:
"What makes the DEX210 better than the B4.1 or 22?"
And also the Ball-ends, Steering plate, and shock towers are the only weak points correct? Any other upgrades needed?
Compared to the B4 IMO- more rear traction while still having great steering, more tuning options, and (outside of a few weak spots) more durable. Fit and finish is also better IMO.
Compared to the 22- More rear traction, better steering, and again more tunable. Only place I feel the 22 is better is on rough tracks or very fast, sweeping layouts. And that goes out the window with the long chassis- we run the +8 CF chassis from Tresrey.
They are all good cars, and all can win. I have great appreciation for the engineering and design of the TD cars, and above all we (mostly my brother Cush) are faster and more comfortable with them. Once the DESC210 hits I will no longer have anything but TD cars in our racing stable.
Old 08-08-2012, 03:55 PM   #7145
BLKNOTCH's Avatar
Sweet thats exactly what I wanted to hear, I will be adding both.
Thanks guy's
Old 08-08-2012, 05:05 PM   #7146
SoCalGuy's Avatar
I have ordered the Cream towers front and rear aswell as the rear weight from Tresrey. Any other tips?
I just ordered the FRONT weight from Tresrey thinking that, like my other 2wd buggies from the past, they always needed front weight. Did I miss the boat here?
SoCal
Mugen MBX6 Eco, Kyosho ZX-5 FS2, Team Durango DEX210
Tamiya TB-03, Tamiya M-05 Pro, Associate 18R, Vaterra Kemora
SoCalGuy is offline   Reply With Quote
Old 08-08-2012, 05:46 PM   #7147
SoCal
He's running the car in MM4, so the weight is a different tuning option. Cush's buggy has the Cream under servo weight and battery weight up front. You're all good
Old 08-08-2012, 05:59 PM   #7148
BLKNOTCH's Avatar
I have to say I was very surprised how well the buggy was planted with no weights added
Old 08-08-2012, 06:01 PM   #7149
SoCalGuy's Avatar
Thanks Jonny5
For the shocks, are these worth getting, or are the kit ones OK (I seem to have read this somewhere over the last several hundred pages):
http://www.amainhobbies.com/product_...or-Oil-Shock-8
Any "hints" for building the shocks?
SoCal
Old 08-08-2012, 06:32 PM   #7150
rsawyers9's Avatar
Anybody that is running on outdoor large tracks should not hesitate to try rm4. I had struggled when the track dusted over with rm3 for weeks. Without changing anything other than going from rm3 to rm4, the buggy was a totally different animal. Traction went through the roof and the buggy was much more stable in the loose sections. IMO, this is what makes the 210 better than the competition. Desc210, here I come.
Mugen MBX6R US | Novarossi P5 | 2058 | Savox |
rsawyers9 is offline   Reply With Quote
Old 08-08-2012, 07:13 PM   #7151
Thanks Jonny5
SoCal
I've heard nothing but good things about those orings, but I've also never had any reason to try them as the stock ones have been good for me. There are a few things to do:
_
Chamfer the shock cap with a razor/xacto/large countersink. This helps seat the cap more fully over the oring.
Sand the spacer that goes between the orings to shorten it a bit, a half mm or so. Then when the orings swell (they all do, no matter the manufacturer), the orings have room to expand.
Use green slime, liberally.
And I double bleed my rear shocks. I always run zero rebound (really because I can make them consistent more than anything), but with a single bleed they always got some rebound after pumping them up by hand. So I pump the shaft 10 times, and re-bleed them. I figure it's an emulsion shock anyway so it has to have air anyway. I think not doing this is what causes some people to have issues with their shock caps, but we have never lost one (aside from gnarly, arm removing wrecks). The fronts for some reason are fine with a single bleed- odd, but that's what I've seen.
It's really a standard build IMO. I did the same stuff on my AE shocks.
Old 08-08-2012, 07:44 PM   #7152
JeremyHarris's Avatar
It's a half a pound heavy if you run a full sized pack. I'm surprised people are adding weight at all! The buggy has more than enough tuning options to adjust the setup to where you don't need weight.
Jeremy G. Harris
Pro-Line-RCWrapz-LFR-SXT-KustomRCGraphics-Airtronics-Team Associated-Reedy-LRP-Superiorhobbies.com
JeremyHarris is offline   Reply With Quote
Old 08-10-2012, 11:33 AM   #7153
murky123's Avatar
when a track is a little bumpy, somewhat blown out or bad shape.
What do you guys prefer? less anti-squat or more anti-squat ?
AE SC10 4x4, Durango DEX210 + DESC210R, HB D413
www.rcracing.nl www.mvb.nl
murky123 is offline   Reply With Quote
Old 08-10-2012, 11:49 AM   #7154
Trader Rating: 31 (100%+)
less
MBX6-ECO, B5m
Cspurlock is offline   Reply With Quote
Old 08-10-2012, 12:24 PM   #7155
tommy911t's Avatar
Trader Rating: 50 (100%+)
Composite chassis sounds awesome!
http://www.redrc.net/2012/08/team-du...tr/#more-57508
tommy911t is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16564 08-19-2017 05:06 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
banx
