Like Tree26Likes
Old 08-08-2012, 03:38 AM   #7126
Trader Rating: 109 (100%+)
Send a message via AIM to kwiksi
[QUOTE=brians11;11067908]So far, there doesn't seem to be a 'fast' tire yet. We got new dirt at the beginning of July and are still searching.
I've tried Rattlers, but the track gets a little dust on it at times and gets really slick. I totally forgot about the toe inserts for the hubs and such. I saw the options on the setup sheet, but just thought I was missing something. I'll keep this in mind next time.
Originally Posted by Cspurlock View Post
Thanks for the detailed response, I'll keep all of this in mind.
Thanks for the input, I'll give these a go. Do you guys feel the shock oil/piston combo is ok? I hadn't thought about the large spur gear effect.
I think your fine with the pistons. I like 1.3 x 4 pretty much everywhere. Could also try a softer rear spring.
kwiksi is offline   Reply With Quote
Old 08-08-2012, 05:26 AM   #7127
JeremyHarris's Avatar
My apologies, you would actually want to take a rear ballstud washer out instead of put one in. I run #55x4 piston front and rear which I believe equates to 1.2. My pistons are also tapered and I run 30wt front oil and 27.5wt rear oil. I advise making one change at a time during practice. Run 3-5 laps make a change, run 3-5 laps, make another change. This way you know exactly what you're changing and how it effects your handling so in the future you know how to solve setup issues. This car is very responsive to small changes. A washer here or there or a shock change and you can really feel a difference so don't do every change at once. There's no easy button with car setups. Baby steps... Ha
Jeremy G. Harris
Pro-Line-RCWrapz-LFR-SXT-KustomRCGraphics-Airtronics-Team Associated-Reedy-LRP-Superiorhobbies.com
JeremyHarris is offline   Reply With Quote
Old 08-08-2012, 05:43 AM   #7128
#55 = 1.3mm
#56 = 1.2mm
Old 08-08-2012, 05:54 AM   #7129
Originally Posted by kwiksi View Post
#55 = 1.3mm
#56 = 1.2mm
Thanks!
Jeremy G. Harris
Old 08-08-2012, 07:28 AM   #7130
Trader Rating: 19 (100%+)
#55 = 1.3mm
#56 = 1.2mm
Sort of. It doesn't equate exactly, and when we're dealing with holes this small a fractionally different hole makes a big difference. Amain sells a nice kit with a pin vise and all of the sizes you'll ever need, both number drills and metric drills that go up by .05mm at a time. Highly recommended to get this kit so if you are copying setups you can copy it exactly. If I say I'm using a 4x1.2 and you use a number drill that is actually 1.17, it will behave differently. Just saying.
Serpent America/Desoto Racing- www.serpentamerica.com
TrakPower Speed Equipment- www.trakpowerusa.com
B Fast RC Performance- www.bfastrc.com
Futaba | Strictly R/C- Norridge, IL
Thank you all for the help and support!
Jonny5 is offline   Reply With Quote
Old 08-08-2012, 07:42 AM   #7131
SoCalGuy's Avatar
Hey Guys,
Started assembling my 210 last night. So far pretty impressed w/ the quality of the kit. Fit and finish is top notch
After reading over the forums and all the tips and tricks I felt prepared for the turnbuckle assembly, but had no idea what a PITA it would be; those buggers are friggin tight! Also, is there a better alternative to the plastic shock cap and plastic pre-load nut for the shocks? I'm guessing the plastic will be fine, but from prior builds, I'm used to those pieces being metal.
SoCal
Mugen MBX6 Eco, Kyosho ZX-5 FS2, Team Durango DEX210
Tamiya TB-03, Tamiya M-05 Pro, Associate 18R, Vaterra Kemora
SoCalGuy is offline   Reply With Quote
Old 08-08-2012, 08:10 AM   #7132
Originally Posted by SoCalGuy View Post
Hey Guys,
SoCal
Upper shock caps are fine. TD makes aluminum preload collars and red aluminum lower caps, and Tresrey has nice red preload collars to match the TD lowers as well. The 210 looks super dialed when equipped with all the red Tresrey bits- Cush's buggies get complimented all the time for being the best looking buggies at the track
Old 08-08-2012, 10:36 AM   #7133
MikeR's Avatar
Trader Rating: 15 (100%+)
Hi Racers,
New goods in stock;
http://www.exotekracing.com/latest-products/
And we've got many more in the works.
Thanks!
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 08-08-2012, 12:22 PM   #7134
BLKNOTCH's Avatar
Send a message via MSN to BLKNOTCH
Had a great first run in my 2wd race with this buggy in MM format, I picked it up from a fellow teammate and it was running a carpet setup so I was working hard every second to find what worked for the dirt track I was racing at. I managed a win in the B main and loved the wheelies down the long straight!!!!!
HB/HPI Racing | Morgan Fuels | HOBBYWING | Airtronics | REDS Racing | HRP | Hobby Revolution | Team N.E.R.D.
BLKNOTCH is offline   Reply With Quote
Old 08-08-2012, 12:25 PM   #7135
BLKNOTCH's Avatar
One thing I would like to know is what do you recommend for the towers? I had a rear tower break on me on landing from a double on the wheels?
Old 08-08-2012, 01:09 PM   #7136
Tresrey sells the Cream rear CF tower, as well as the front. They are rock solid in terms of reliability and very pretty to look at also. We had similar breakage on Cush's buggy on flat landings- when one broke during a race he was leading it was time for some CF goodness.
Old 08-08-2012, 02:24 PM   #7137
I use the stock towers. I am guessing there was a bad batch made because everyone keeps saying they're breaking them. I am still using the one I got in my kit although I have spares. The carbon fiber towers will give you a severe handling change so its really driver preference on which towers you want to run.
Jeremy G. Harris
Old 08-08-2012, 02:50 PM   #7138
BLKNOTCH's Avatar
The handling change wont mean anything to me as I am new to 2wd racing as a whole, I have only ran it once and managed a B main win with a setup on the buggy that was more geared to carpet racing. I want to keep the buggy in Mid Motor configuration and will be racing on tight dirt tracks. I have ordered the Cream towers front and rear aswell as the rear weight from Tresrey. Any other tips?
Sean
Old 08-08-2012, 02:54 PM   #7139
Evil Genius jr.'s Avatar
Trader Rating: 28 (100%+)
Well I'm researching 2wd buggies and now I'm going to ask you guys:
"What makes the DEX210 better than the B4.1 or 22?"
And also the Ball-ends, Steering plate, and shock towers are the only weak points correct? Any other upgrades needed?
Brushlesshobbies.com
DESC410
Evil Genius jr. is offline   Reply With Quote
Old 08-08-2012, 03:08 PM   #7140
Cream's Avatar
Sean
Nice to read :-)
Cream Extreme R.C.
http://www.oople.com/forums/forumdisplay.php?f=219
Cream is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16568 09-15-2017 05:07 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
