Like Tree26Likes
Old 08-03-2012, 02:09 AM   #7066
LOW ET's Avatar
Trader Rating: 96 (100%+)
looking for a new buggy and i'm torn between the dex210 or b4.1ft worlds. any thoughts to help me out?
LOW ET is offline   Reply With Quote
Old 08-03-2012, 02:30 AM   #7067
slow_jun's Avatar
Trader Rating: 14 (94%+)
Originally Posted by rsawyers9 View Post
What shock o rings are you guys running? I changed oil in my shocks the other night and was surprised to find the old oil was terribly dirty. About the color of chocolate milk. lol
http://www.amainhobbies.com/product_...or-Oil-Shock-8
no leaks here , just add up on maintenance. maybe you need to get the shock cover to minimize dirt.
Mag 3 taon, tapos isalpak pa sa PAGMUMUKHA KO......... tagal....Deeeeymmm!!!
slow_jun is offline   Reply With Quote
Old 08-03-2012, 04:19 AM   #7068
scr8pn4205's Avatar
Originally Posted by Jonny5 View Post
Lots of pretty red stuff on there! . We had 35/75 in Cush's buggy with a Revtech Magzilla. Actually ran down to 36/69 without any heat issue, but it didn't wind up as well as with the 75 spur. Probably drop a tooth or two if you have a standard rotor in it and see how it goes from there.
75/35 wow I had 75 33 and it was hitting my gear cover so I was gonna try a 69/34 to help clear it.
Airtronics M12
Team Xray XB2 2017 CE
TSR power
scr8pn4205 is offline   Reply With Quote
Old 08-03-2012, 05:13 AM   #7069
JeremyHarris's Avatar
Originally Posted by zipperfoot View Post
Is there a front hex conversion out there for this car?
Yes, look about five pages back.
Jeremy G. Harris
Pro-Line-RCWrapz-LFR-SXT-KustomRCGraphics-Airtronics-Team Associated-Reedy-LRP-Superiorhobbies.com
JeremyHarris is offline   Reply With Quote
Old 08-03-2012, 07:25 AM   #7070
Trader Rating: 19 (100%+)
Yeah, it took a little dremel work on the inside of the gear cover to make it happen. That car still has the original gear cover on it though, so now worries there. When we did gearing testing I just left it off until I found what worked best, then had to clearance a bit to clear the pinion once we settled on a gear package.
XRAY, RC America, MOTIV, Sanwa, Arrowmax, Neverlift Racing Apparel
Jonny5ive Designs- by racers, for racers!
Jonny5 is offline   Reply With Quote
Old 08-03-2012, 07:51 AM   #7071
SoCalGuy's Avatar
Ok, well I guess I need a lesson on gearing. My new Dex arrives next week, and I'll be going w/ the 13.5T motor. Does the kit include more than one spur? Does it have the pinion(s)? What mod / pitch are the gears? Where would be a good place to start regarding the gearing without having to Dremel the cover down.
Thanks guys,
SoCal
Mugen MBX6 Eco, Kyosho ZX-5 FS2, Team Durango DEX210
Tamiya TB-03, Tamiya M-05 Pro, Associate 18R, Vaterra Kemora
SoCalGuy is offline   Reply With Quote
Old 08-03-2012, 08:05 AM   #7072
Thanks guys,
SoCal
It comes with an 87 spur. With a Tresrey 8.5 we run 25/81 (RW spur). Running a 13.5 you shouldn't need to dremel anything as you won't be running anything like blinky 17.5 gearing. If I had to take an educated guess I would think somewhere around 28/75 would be a decent starting spot for blinky 13.5, but we've never run 13.5 in the buggy. Hopefully somone else can chime in on this one for ya.
Old 08-03-2012, 08:56 AM   #7073
Evil Genius jr.'s Avatar
Trader Rating: 28 (100%+)
Is it possible to fit AE spurs on the truck?
Brushlesshobbies.com
DESC410
Evil Genius jr. is offline   Reply With Quote
Old 08-03-2012, 09:06 AM   #7074
Schumacher and RW spurs are direct fit. To use an AE spur you need to ream (or bore if you have machining capability ) the center hole out. If doing it by hand with a reamer, go slow and do each side a little at a time, checking the slipper hub for a snug fit. A little too big on the hole and the gear will be unusable.
Old 08-03-2012, 09:07 AM   #7075
Okay thanks! So you know by how much?
Have a ton of AE spur and looking into this car so don't want to waste them!
DESC410
Old 08-03-2012, 10:14 AM   #7076
SoCalGuy's Avatar
Thanks Jonny5
I was going to go w/ a smaller motor since I'm a bit of a novice in the 2wd deal, and our new track layout is pretty tight and technical; I'm worried about launching it in the parking lot! Anyway, maybe others can add their $.02 as well.
Thanks again,
SoCal
Old 08-03-2012, 10:22 AM   #7077
This will work too-
.tresrey-usa.com/tresrey-slipper-hub-layshaft-set-dex210
put www. in font the of treasrey...won't let me linke it due to lack of post count.
Team Associated, Kyosho.
EZSC is offline   Reply With Quote
Old 08-03-2012, 10:33 AM   #7078
Tresrey makes a replacement layshaft and slipper hubs that allows the use if AE style spurs and slipper pads.
______________________________________________________
Team Tulsa - Team R/C Paints by Sonny - Durango DEX410
qwkpony is offline   Reply With Quote
Old 08-04-2012, 04:28 AM   #7079
Here is Cush's setup from this past weekend: http://www.petitrc.com/setup/durango...ngoDEX210.html
Indoor and outdoor are posted at the top of the clay and dirt sections, respectively.
Old 08-04-2012, 06:41 AM   #7080
i had the same issue with the 35 pinion hitting the cover do you have to drimel alot or not? went back to a 34.
zylstra is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16572 10-14-2017 01:35 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
