Like Tree43Likes
Old 07-30-2012, 12:51 PM   #6991
Trader Rating: 19 (100%+)
http://www.youtube.com/watch?v=cT3-r...e_gdata_player
Here's the link to Cush's win on the indoor leg of the Futaba Electric Challenge.
XRAY, RC America, MOTIV, Sanwa, Arrowmax, Neverlift Racing Apparel
Jonny5ive Designs- by racers, for racers!
Jonny5 is offline   Reply With Quote
Old 07-30-2012, 01:21 PM   #6992
Trader Rating: 49 (100%+)
Wow great race! Really fun to watch that one. The buggy handled great
Garnold is offline   Reply With Quote
Old 07-30-2012, 01:37 PM   #6993
scr8pn4205's Avatar
Car looks great with the +8 carbon chassis. Nice run
Airtronics M12
Team Xray XB2 2017 CE
TSR power
scr8pn4205 is offline   Reply With Quote
Old 07-30-2012, 02:21 PM   #6994
fastzach's Avatar
Trader Rating: 57 (100%+)
Send a message via AIM to fastzach
What ball cups are you guys using? I just finished building my kit and there is nothing that pisses me off more than the ball cups popping off when you are simply trying to adjust camber. I put black grease in there for lubrication of the threads in the ball cups, that doesn't seem to be the problem, they went together, but the POS stock ones pop off easily. I can't very well trust them on the track if they don't even hold up in the pits.
Any help is appreciated, thanks
fastzach is offline   Reply With Quote
Old 07-30-2012, 02:31 PM   #6995
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
@fastzach A trick I use before building the turnbuckles is to take a long 3mm screw and pre thread each ball end. this makes it super easy to adjust them later without having that issue. You can also take some soft jaw pliers and give each end a "pinch" on the area that the threaded turnbuckles is inside, this will make it a bit easier "printing" the threads a bit deeper.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 07-30-2012, 02:46 PM   #6996
aloksatoor's Avatar
Trader Rating: 42 (100%+)
Losi or kyosho,but both would need 4.8 ball studs though (hpi is cheapest,K and L are same price I think). As usual durango ball studs are not standard sized. Also use white silicone grease for plastics black grease might break it down making it worse over time.
If you are hell bent on the stockers, put 2 hex drivers through the holes on the cups so they do not slip out.
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 07-30-2012, 03:04 PM   #6997
Along these same lines, I simply chuck the turnbuckle in a small drill and prethread (with grease) every ballcup. Make a pile of rights and a pile of lefts. Then they build and adjust like butter. We still use stock ballstuds and cups exclusively.
Old 07-30-2012, 03:37 PM   #6998
AE metric ball studs for the TC5/TC6 and RPM ball cups. Best setup IMO.
______________________________________________________
Team Tulsa - Team R/C Paints by Sonny - Durango DEX410
qwkpony is offline   Reply With Quote
Old 07-30-2012, 03:59 PM   #6999
Jeff Werner's Avatar
Trader Rating: 15 (100%+)
Send a message via Yahoo to Jeff Werner
Jonny- now that you have put some time on the +8 chassis, what are your thoughts on the added length over the stock length. I saw pics on oople of the rtr car with a molded +8 and hope that will be available if going to +8 are the way to go. I race on med to high bite clay indoor.
Jeff Werner is offline   Reply With Quote
Old 07-30-2012, 06:56 PM   #7000
kwiksi's Avatar
Trader Rating: 109 (100%+)
Send a message via AIM to kwiksi
Default New 'Race Ready' RTR cars from Team Durango
Cats out the bag....can't wait for the chassis and body to be avail...nice that they will come with competitive Speed Passion electronics.
http://www.oople.com/forums/newreply...reply&p=679364
Thanks in 2017 to
Xray/RC America - JConcepts - Trinity - Sanwa - Hobbywing - Exotek - PT Racing Oils -Schelle
kwiksi is offline   Reply With Quote
Old 07-30-2012, 07:03 PM   #7001
Crawlin's Avatar
Trader Rating: 22 (100%+)
Wanted to thank all of those who have had input in this thread. Just read through all of the posts (wow that was alot of information). I feel that while my LHS support is not plentiful, I still like this buggy and what it has to offer in comparison to the other players. Unfortunately before the buyout, TD wasn't big in my area I guess and the LHS sent back all of the parts that were just collecting dust. I understand their position as it is a rather large place, and that is alot of inventory/cash to free up if its just sitting there.
Anyways, this leads me to plan ahead for preparing for any sort of breakage. I just plan on running stock buggy (17.5) as it is very popular along with stock SC in this area. So besides the below list, what else should I be looking at for extras (minus spare wheels/tires for changing track conditions, spare electronics, etc..) in case of breakage?
Front and Rear Arms
Steering Knuckle & Hub Set
Rear Driveshafts
Gear Cover
Shock Tower Set
Front Bulkhead & Susp. Mounts
Ball Diff Screw, Spring, Nut
?Extra Ball Diff Set? - Kind of as a "might as well" type thing, then don't need ball diff screw, spring, nut
HD Ball End Set
I would be looking at a couple of the Tresrey pieces for upgrades, but just small stuff like the steering plate and wheel hex's. Also looking at Bfast's pro driver's kit w/ carbide balls since it seems they were talked highly about on here.
Am I missing anything else? For just the stock parts, it seems like I'm only 80-90 away from buying a second kit, so is it worth it to just do that to have all spare bolts and pieces?
Thanks again!
Crawlin is offline   Reply With Quote
Old 07-30-2012, 07:04 PM   #7002
aloksatoor's Avatar
+1 for the composite chassis should be easy to wrench the rear now and a nice 13.5 included too!!!
Old 07-30-2012, 07:40 PM   #7003
kwiksi's Avatar
Front and Rear Arms
Rear Driveshafts
Gear Cover
Shock Tower Set
HD Ball End Set
Thanks again!
To be honest with you. The only thing you really need is the Tresrey steering plate. The Tresrey hexes are nice to have. Make life easier as I've lost a couple of pins. Although I've never broke the kit plastic toe blocks. I do have a machined alum 3/3 toe block for peice of mind. Have a 2/3 as well for tuning. Car is built like a tank. I have broken one rear shock tower on a freak upside down landing. Haven't broken anything else..Some folks swear by the carbon towers, but I've had no issues with the kit plastic towers ever since. I have a bunch of nip spares in my box that I've never needed...so far. Lol
The Bfast kit isn't needed. The kit ball diff is good. Just build it right.
Thanks in 2017 to
Old 07-30-2012, 08:16 PM   #7004
@Jeff Werner- It's hard for me to exactly say since Cush is the one driving, but I can tell you that he loves the car with the long chassis, and I've never seen him look better driving a buggy. Initially he liked the standard length cf chassis better for indoor, but he ran the extended chassis this weekend inside as he tried the other car and preferred the stability the extended chassis gave him. I'm sure if we go to a track that's really tight the standard length will be preferred, but if you have both and know where you're racing making the switch back and forth isn't too bad really. I would say it really comes down to track layout as to which is better. Just another option to add to the vast list of tuning variables for this car
@Crawlin- your list looks good, maybe even a bit overkill, but that's about what I bring with too. IMO the Tresrey rack and aluminum toe blocks are must have. Otherwise the car is built very tough. If you want it bomb proof, throw on some cf towers. The Cream pieces from Tresrey have held up to everything Cush has thrown at it, and believe me, the kid pushes his cars hard and when he gets it wrong it gets really wrong. But the car gets marshalled and motors away- save for an occasional ballcup popping as it cartwheels away.. Oh yeah, the stock diff is very good for a stock diff- a BFast kit makes for the nicest, longest lasting diff I've ever built. Outdrives wear out before the BFast parts need to be replaced for us. Worth every penny to me.
Old 07-30-2012, 08:19 PM   #7005
Crawlin's Avatar
Greatly appreciate the help. I honestly don't feel my driving is good enough to recognize the difference in shock towers. Plus just the $8 vs $60 thing, haha.
Could you explain the 3/3 and 3/2 numbers then? I mean I know what toe is about, just reading the tresrey site is a little hard to understand. Stock is 3* toe and then each one of those kits alters the kick up according to which block you have? what is the stock "kick up" then? I think I missed that in the thread somewhere or read past it. Or should I be looking different manufacturer for the blocks?
St Ives RC Club B4Bandit Australian Racing 16581 11-23-2017 03:23 PM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-08-2017 12:57 AM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 10:51 PM
