Like Tree43Likes
Old 07-26-2012, 08:46 PM   #6961
Jeff Werner's Avatar
Trader Rating: 15 (100%+)
Send a message via Yahoo to Jeff Werner
What gearing do you recommend when running 17.5 Blinky? Getting some gears in the offseason and did not know what spurs to keep on hand.
Jeff Werner is offline   Reply With Quote
Old 07-26-2012, 08:51 PM   #6962
rcjunky1's Avatar
Originally Posted by Dog Runner View Post
Is there anywhere I can get an aluminum rear toe block that has 3' toe and zero anti-squat?
I do and still have some in stock, as well as 1.5* and 3*, and if you want I also have shims to raise the 0* to 1.5 or 3*, and the +8mm aluminum chassis comming soon.
Originally Posted by AMorgan View Post
I'm curious if anyone else is having the same problem I am; I keep breaking front C-Hubs. I've broken 4 now and they all had one thing in common, they all had a void in the mold just below the camber mounting holes. I believe this void is weakening the part and creating most of my issues. Is anyone else breaking these with some regularity? The car will usually take some decent hits without issue, but this one piece is a pretty regular race ender for me and it's usually on a small hit. Any thoughts/solutions would be appreciated.
I was talking to one of the Great Hobbies team drivers and he recently built a new car the exact same way as the first and has broken 2 rear hubs and 2 c hubs on the new car, but not a single thing on the old car, we think there was a bad batch of plastic. My car is an early car and its been bulletproof for me, including many hard hits to the shock towers
Official distributor of Dan-O-Mite Custom Parts- Durango 210 RF pivot blocks
Andrew Butters' Burghgraef
Team Durango Canada
Great Hobbies, Hobbico, Skyrc, Exotek
rcjunky1 is offline   Reply With Quote
Old 07-26-2012, 09:55 PM   #6963
JeremyHarris's Avatar
Originally Posted by Fred Perkins View Post
Do you know if he cut down the axle? I have to use a lot more spacers than that.
No, I did not cut the axle down. It is an extremely tight fit though. The spacer that comes with the axle is closest to the screw, then, there is on spacer on each side of the bearings. So, 3 spacers per side and width is exactly the same as before.
Jeremy G. Harris
Pro-Line-RCWrapz-LFR-SXT-KustomRCGraphics-Airtronics-Team Associated-Reedy-LRP-Superiorhobbies.com
JeremyHarris is offline   Reply With Quote
Old 07-27-2012, 04:32 AM   #6964
kwiksi's Avatar
Trader Rating: 109 (100%+)
Send a message via AIM to kwiksi
Pick yourself up some 69 & 75 spurs. Pinions from 30t and up.
Thanks in 2017 to
Xray/RC America - JConcepts - Trinity - Sanwa - Hobbywing - Exotek - PT Racing Oils -Schelle
kwiksi is offline   Reply With Quote
Old 07-27-2012, 07:52 AM   #6965
rcjunky, I wish I could say it was a "bad batch" issue. The car is from the second set of cars to come to the states, and the C-Hubs I broke are from the first batch into the states and obviously the ones that originally came on the car and they all break the same way. I think way the mold is designed is causing the problem (I believe Losi had this issue initially with the XXX-4 arms). It feeds from 2 plugs, one at the top and one at the bottom of the C-Hub and where they meet, the void is forming. I have about 3 bags worth of C-Hubs currently (and 5-6 bags of front knuckles and rear hubs, hahaha) so I'm hoping these will last me a little while, but I would love to just replace that part with aluminum. I believe the surrounding parts are stong enough to take the abuse; though at this point, this seems to be an issue only I am having.
AMorgan is offline   Reply With Quote
Old 07-27-2012, 08:04 AM   #6966
TAMAK's Avatar
Trader Rating: 28 (100%+)
Exotek!!
http://www.redrc.net/2012/07/exotek-...ts/#more-57176
TrakPower Speed Equipment / Speed Passion
Serpent Natrix 748 TQ - Nova REX
D413 Reventon 1.1ex 13.5t; AE B6d Laydown Reventon Pro 1.1
DNX408V2-NovaP5, DETC410-Reventon 1.1ex-5.5t MMM
RC10 , RC10GT2- CV-R- SAVOX,
TAMAK is offline   Reply With Quote
Old 07-27-2012, 11:50 AM   #6967
scr8pn4205's Avatar
Looking at some set up sheets and I see a lot of people are using full droop. Just curious as to how they are doing this. If I take the droop screw out of rear arm so there is full droop and when holding it in the air I pull the trigger and I have the dogbone almost out of the diff cups and the chatter from the cva is bad. Just wondering if there is a measurement like we use to use on the 1/8 scale to measure droop. Center of upper to center of lower shock mount bolt
Airtronics M12
Team Xray XB2 2017 CE
TSR power
scr8pn4205 is offline   Reply With Quote
Old 07-27-2012, 12:02 PM   #6968
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
This is also affected by how long you run your rear shocks and what holes they're mounted.
I run full droop screws installed.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 07-27-2012, 12:47 PM   #6969
scr8pn4205's Avatar
Thats what Im wondering about is the length people are using on the shocks....eyelet to eyelet. Right now im middle top and middle to outside on bottom mount location
Airtronics M12
TSR power
Old 07-27-2012, 12:51 PM   #6970
scr8pn4205's Avatar
and you have no driveshaft chatter when u pull the trigger and the suspension is at full droop???
Airtronics M12
TSR power
Old 07-27-2012, 01:00 PM   #6971
Team Tekin
Randy_Pike's Avatar
No
Old 07-27-2012, 02:40 PM   #6972
scr8pn4205's Avatar
No
u running 3 or 1.5 squat
Airtronics M12
TSR power
Old 07-27-2012, 03:45 PM   #6973
Team Tekin
Randy_Pike's Avatar
2 at the moment.
Old 07-28-2012, 02:16 AM   #6974
Azagar's Avatar
The outdrives on the gear diff are much longer then the ones on the ball diff, this is primarily why I run full droop, before I couldn't.
Team Durango DEX210
Avid | AKA | Exotek | Jconcepts | KO Propo | Lunsford | Tekin | Turnigy Nano-tech
Azagar is offline   Reply With Quote
Old 07-28-2012, 11:31 AM   #6975
scr8pn4205's Avatar
Thanks makes sense.. With the ball diff at 1.5 squat my dogbone pin is half way out of the diff cup at full droop when rotated so the pins are up and down at full droop
Airtronics M12
TSR power
St Ives RC Club B4Bandit Australian Racing 16580 Today 03:10 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-08-2017 12:57 AM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 10:51 PM
