Like Tree43Likes
Old 07-24-2012, 08:09 AM   #6931
Trader Rating: 19 (100%+)
Originally Posted by Garnold View Post
Nice!
And again, 14mm is more the standard for a 4wd buggy like my 410 correct?
If I did this could I share wheels with my buddies 22?
14mm is only on TD cars. Yes, if you do the 12mm hex mod you can use hex wheels from the 22 or AE cars.
I may be the only one, but I really prefer bearings in the wheels. Not only will you give up the ability to change the axle position up front, but there is less slop in a std bearing setup compared to hex. I wish the new 210 sc had bearings up front too. Oh well.
XRAY, RC America, MOTIV, Sanwa, Arrowmax, Neverlift Racing Apparel
Jonny5ive Designs- by racers, for racers!
Jonny5 is offline   Reply With Quote
Old 07-24-2012, 08:20 AM   #6932
seth556's Avatar
Trader Rating: 42 (100%+)
Originally Posted by Outtacontrol58 View Post
Here is a picture of the hex wheel option on the front of my buddy's 210. So sick!
SWEET!
seth556 is offline   Reply With Quote
Old 07-24-2012, 08:34 AM   #6933
JeremyHarris's Avatar
I have noticed that too but, I'd rather change out the part every so often and gain the ability to interchange wheels. That and I ran my axles all the way trailing anyway... Ha
Jeremy G. Harris
Pro-Line-RCWrapz-LFR-SXT-KustomRCGraphics-Airtronics-Team Associated-Reedy-LRP-Superiorhobbies.com
JeremyHarris is offline   Reply With Quote
Old 07-25-2012, 09:00 AM   #6934
Jeff Werner's Avatar
Trader Rating: 15 (100%+)
Send a message via Yahoo to Jeff Werner
I have seen where many setups are 4 hole pistons. Are there any purpose made 4 hole pistons for the 210? I know there are blanks and people have filled in two holes to make 4 hole pistons. If no purpose built 4 hole which method is preferred Drilling or Filling?
Jeff Werner is offline   Reply With Quote
Old 07-25-2012, 09:20 AM   #6935
You can order cnc pistons from Ghea or Nick on Oople, both of which are in Europe. TD has some of their own coming out soon, but not yet available. If you have a set of blanks drilling isn't bad, but I recommend using a pin vise rather than a drill as the bits are small and break easily. Otherwise fill them by CA gluing a toothpick into the hole, trimming it off flush, and put a small drop of CA on both sides of the hole to cap it off.
Old 07-25-2012, 10:42 AM   #6936
hi there
with which pinion you would start with a Lrp x11 9.5t engine with stock spur?
i drive on a medium size track with low grip. 26 a good point to start?
here my second question.
i┤m running the gear diff on my dex210.
with which oil you would start on a low traction track▀ it┤s better to start with thicker shock oils like 800 to get better traction?
thank you for you help
mihael
mihaelbencek is offline   Reply With Quote
Old 07-25-2012, 11:00 AM   #6937
I use 4 hole tapered 55's that I ordered from Nick. But I also used a hand-drill from snap-on with a #55 drill bit to drill out the stock blank pistons that came with the kit.
Jeremy G. Harris
Old 07-25-2012, 08:37 PM   #6938
Slimsh8t's Avatar
Trader Rating: 39 (100%+)
Default Servo horn
Is anyone using any other servo horns other than the stock plastic ones.? I run savox and am curious if the racers edge aluminum will work.
Thx,
Kevin
Kevin Murphy
Associated B5m/Reedy
AP Custom Paint/Kal-Gard/
Slimsh8t is offline   Reply With Quote
Old 07-25-2012, 08:44 PM   #6939
ekt
ekt's Avatar
Thx,
Kevin
The Losi 22 aluminium servo horn does the job.
ekt is online now   Reply With Quote
Old 07-25-2012, 10:04 PM   #6940
P6
hows everyone's trailing setup washers and all ?
P6 is offline   Reply With Quote
Old 07-25-2012, 10:27 PM   #6941
Azagar's Avatar
Most common setup is 4mm behind the carrier and either max trailing or 3mm on higher traction tracks.
Team Durango DEX210
Avid | AKA | Exotek | Jconcepts | KO Propo | Lunsford | Tekin | Turnigy Nano-tech
Azagar is offline   Reply With Quote
Old 07-25-2012, 10:41 PM   #6942
mdowney's Avatar
Trader Rating: 21 (100%+)
GHEA pistons are at absolutehobbyz.com in the US. I run them on all my cars. Tapered side points down. I learned about them from Maifield. He runs them in his B4. I use the Losi 22 4-hole 1.3mm in my Kyosho big bores, which I run in my RB5 and my B4.
Mike Downey
I try all of the RC kits and usually race at Tacoma RC Raceway
mdowney is offline   Reply With Quote
Old 07-26-2012, 03:46 AM   #6943
Have you ever tried them tapered side up?
Jeremy G. Harris
Old 07-26-2012, 03:52 AM   #6944
Default TD Official Forward Cab
Chris-s is offline   Reply With Quote
Old 07-26-2012, 04:47 AM   #6945
kwiksi's Avatar
Trader Rating: 109 (100%+)
Send a message via AIM to kwiksi
WANT! Found these pics on OOple.
Is it me or does the wheelbase look a little long? Gonna send an email to my team manager about this and avail....Mr. Pike any info on this?
Thanks in 2017 to
Xray/RC America - JConcepts - Trinity - Sanwa - Hobbywing - Exotek - PT Racing Oils -Schelle
kwiksi is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16581 11-23-2017 03:23 PM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-08-2017 12:57 AM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 10:51 PM
