Like Tree26Likes
Old 07-22-2012, 02:09 AM   #6916
silvalis's Avatar
Trader Rating: 29 (100%+)
How many twists does your ball diff spring have? All of the pictures I see on the durango site have 3 twists. The two springs I have have 4 twists. Having a lot of trouble with getting the diff right, it's like the diff spring is too long.
oof, but you get the idea...
Slipper spring, new diff spring, old diff spring, zx5 diff spring
IMG_0050 by silvalis, on Flickr
Spring off the durango site
http://www.team-durango.com/blog/wp-...ush-spring.jpg
2013 QLD Champion Potato Sack Racer
silvalis is offline   Reply With Quote
Old 07-22-2012, 04:54 AM   #6917
Trader Rating: 241 (99%+)
Originally Posted by JeremyHarris View Post
Yes, it fits the B4.1, Kyosho, and Team C wheels. I used the new Team Durango steering knuckle, Team Kyosho front axle (one with the hex already on it), and the Kyosho axle shims. The Team Durango axles should be out soon and or are already out. I know my lhs has them on backorder. I asked Jorn what axles he uses and he had his custom made.. ha
Do you have a part # for the knuckle? Is it available yet?
Thanks!
***Team driver for Team Associated, Reedy, A-Main Hobbies, ProTek RC, AKA and Integy***
Fred Perkins is offline   Reply With Quote
Old 07-22-2012, 05:06 AM   #6918
Trader Rating: 109 (100%+)
Send a message via AIM to kwiksi
What do you mean when you say "right"? It not getting tight enough?
kwiksi is offline   Reply With Quote
Old 07-22-2012, 05:14 AM   #6919
silvalis's Avatar
If I set it loose similar to my RB5 the end of the axle hits the diff bolt and the diff slips.
If i screw it down tight enough to clear the axle, the diff is too tight and I have zero diff action. I actually tried to run it earlier and I think I flattened the diff balls because it was so tight.
This is following that diff build guide on the website too.. I've rebuilt this several times and ordered the new diff screw/spring because I initially thought the spring was too long.
This means I've checked and rechecked the thrust washer, sanded the plates, etc, etc...
Old 07-22-2012, 07:22 AM   #6920
Trader Rating: 19 (100%+)
How are you breaking it in? If you used stock balls and tried to tighten it to where the nut sits flush in the outdrive all at once, you very well could have flat spotted the balls. During break in it usually takes 4-5 times of "running it in" and tightening a little bit after to actually get it tight enough
Serpent America/Desoto Racing- www.serpentamerica.com
TrakPower Speed Equipment- www.trakpowerusa.com
B Fast RC Performance- www.bfastrc.com
Futaba | Strictly R/C- Norridge, IL
Thank you all for the help and support!
Jonny5 is offline   Reply With Quote
Old 07-22-2012, 07:54 AM   #6921
TAMAK's Avatar
Trader Rating: 28 (100%+)
+1. And also, if you suspect the clip was compressed too long, replace it.. I have had an issue with my last diff build with a faulty clip. I thought it was good, but after replacing it with another one. No problems. Also, pick some clips up from Mcmaster, a bag of 50 clips is just as cheap as a small TD bag.
TrakPower Speed Equipment / Speed Passion
Serpent Natrix 748 TQ - Nova REX
D413 Reventon 1.1ex 13.5t; AE B6d Laydown Reventon Pro 1.1
DNX408V2-NovaP5, DETC410-Reventon 1.1ex-5.5t MMM
RC10 , RC10GT2- CV-R- SAVOX,
TAMAK is offline   Reply With Quote
Old 07-23-2012, 12:35 PM   #6922
JeremyHarris's Avatar
Thanks!
Td330382 for $4.50 and it is available!
Jeremy G. Harris
Pro-Line-RCWrapz-LFR-SXT-KustomRCGraphics-Airtronics-Team Associated-Reedy-LRP-Superiorhobbies.com
JeremyHarris is offline   Reply With Quote
Old 07-23-2012, 08:54 PM   #6923
nolimit208's Avatar
Send a message via AIM to nolimit208 Send a message via MSN to nolimit208
Looks like this is all that is needed for the 12mm hex fronts. I just compiled it from what J. Harris posted but with links to the parts.
Steering Knuckle:
http://www3.towerhobbies.com/cgi-bin...?&I=LXCNYC&P=7
Axle Shaft:
http://www.amainhobbies.com/product_...t-Set-RB5-WC-2
Axle Spacers:
http://www.amainhobbies.com/product_...r-Axle-Spacers
Wheele Nuts:
http://www.amainhobbies.com/product_...ock-Nut-Gold-4
nolimit208 is offline   Reply With Quote
Old 07-24-2012, 05:32 AM   #6924
Steering Knuckle:
Axle Shaft:
Axle Spacers:
Wheele Nuts:
Thanks!! That is exactly what I used!
Jeremy G. Harris
Old 07-24-2012, 05:52 AM   #6925
Trader Rating: 49 (100%+)
Steering Knuckle:
Axle Shaft:
Axle Spacers:
Wheele Nuts:
Sorry for stepping in late but what is this conversion for?
Garnold is offline   Reply With Quote
Old 07-24-2012, 06:07 AM   #6926
If you look on page back there is a picture. It is the front hex option for the 210.
Jeremy G. Harris
Old 07-24-2012, 06:10 AM   #6927
Thank you. That it pretty cool. I'm guessing you would have to buy new front wheels to support this correct?
Really cool idea!
Also, is the 12mm hex the standard for this size buggy and 14mm for a 4wd buggy? My 410 has the upgraded 14mm hex on it when I bought it and that seems to be the standard. Sorry about this dumb ones
Old 07-24-2012, 06:14 AM   #6928
Really cool idea!
Yes, you would need a 12mm hex front wheel such as the B4.1, Kyosho, Team C wheels all fit. They're more "standard". You can also use the JC adapter on the rear to run 12mm hex wheels on the rear, that way you can run the 12mm wheels all the way around. I prefer this, not only because I happen to have a ton of 12mm wheels but because I can be at a race and borrow a wheel more easily... Ha
Durango uses 14mm hexes on their 2x and 4x buggies. All other companies use 12mm with the exception of Losi who uses a 10mm hex on the front of the 22. I wish everyone would just come out with a standard wheel/offset...
Jeremy G. Harris
Old 07-24-2012, 06:17 AM   #6929
Nice!
And again, 14mm is more the standard for a 4wd buggy like my 410 correct?
If I did this could I share wheels with my buddies 22?
Old 07-24-2012, 06:29 AM   #6930
Hi there
With which pinion you would start with a 9,5 turn engine on a medium size, mid traction track with stock spur?
mihaelbencek is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16570 Yesterday 03:48 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
