Durango DEX210 Thread
#6906
I am no team driver but there are quite a few ppl including me having trouble with ceramics as diff balls. Search in the same thread and you will find many. The diff barks a lot even with any amount of tightening. The best upgrade is to get the bfast kit or least the diff balls.
It was barking at take off, so I loosend the slipper to the point where it doesn't, about 1 mm thread showing on the adjustment screw. I only hope the spur doesn't over heat now
#6907
Do you guys think an 80a esc will be good with a 10.5 motor? Im running on a small indoor clay track.. http://www.youtube.com/watch?v=mYj8QCqpEGI
I run a brushless hobbies 120a with a 10.5 in my xxx-sct and the temps are super low. It rarely breaks 100 with ambient temps around 85-90
#6908
#6911
#6913
#6915
Yes, it fits the B4.1, Kyosho, and Team C wheels. I used the new Team Durango steering knuckle, Team Kyosho front axle (one with the hex already on it), and the Kyosho axle shims. The Team Durango axles should be out soon and or are already out. I know my lhs has them on backorder. I asked Jorn what axles he uses and he had his custom made.. ha
