Like Tree23Likes
Old 07-12-2012, 11:50 AM   #6826
scr8pn4205's Avatar
Im new to the DEX210 myself. So far the car has been tough. Didnt have an issue with ballcups or studs but changed out to the 4.8mm ones. maybe a front and rear tower, front arms but i have yet to break anything yet
Airtronics M12
Team Xray XB2 2017 CE
TSR power
scr8pn4205 is offline   Reply With Quote
Old 07-12-2012, 12:14 PM   #6827
Trader Rating: 19 (100%+)
Originally Posted by Evil Genius jr. View Post
I'm thinking of getting the DEX210 to race this indoor season. What spares should I carry if I am the only one using a Durango? Any mods I need to do?
Thanks! Hate to be a noob on this one but after reading the whole DESC410R and about 1000 pages of the SC10 4x4 threads I'm a little rctech threaded out. Search didn't turn up anything useful.
IMO there are two absolute must haves for the car- a CF rack and an aluminum RF hinge pin block (all of our hop ups come from www.tresrey-usa.com) Add CF front and rear towers and the car is really tough, pretty much bulletproof.
Check out the ball diff build guide on the TD website and follow it carefully (use BFast balls for great life between rebuilds), and you're pretty set. Great car and super tunable.
On another note, the Tresrey motor plates showed up today. Nice looking piece as expected, but they have a really neat feature- the plastic bushing that spaces between the trans case and the motor plate is replaced by an aluminum one that threads into the motor plate. Of course it can be configured to fit any motor layout you use, but it's a really nice touch showing the attention to detail of the Tresrey line.
Serpent America/Desoto Racing- www.serpentamerica.com
TrakPower Speed Equipment- www.trakpowerusa.com
B Fast RC Performance- www.bfastrc.com
Futaba | Strictly R/C- Norridge, IL
Thank you all for the help and support!
Jonny5 is offline   Reply With Quote
Old 07-12-2012, 12:28 PM   #6828
Evil Genius jr.'s Avatar
Trader Rating: 28 (100%+)
So These:
http://www.tresrey-usa.com/tresrey-d...teering-plate/
(or this? http://www.team-durango.com/part-inf...artNo=TD320157)
http://rcshox.com/shoxshop/catalog/p...products_id=61
http://www.tresrey-usa.com/cream-fro...r-replacement/
I can't find the RF hinge pin block. Do you have a part #? Thanks!
I'll probably just get the gear diff as I have no experience with ball diffs and from what I heard the DEX210 one is not a good first ball diff.
Brushlesshobbies.com
DESC410
Evil Genius jr. is offline   Reply With Quote
Old 07-12-2012, 01:06 PM   #6829
So These:
Here's the RF block- http://www.tresrey-usa.com/tresrey-a...degree-dex210/
As for the gear diff, I haven't used it and personally have never liked them in 2wd . There are plenty of guys on here though that can point you in the right direction there.
Old 07-12-2012, 06:00 PM   #6830
scr8pn4205's Avatar
wondering what gearing to start out with for a track like RC Excitement roughly 100x50 running Tekin 13.5 open esc. Any help would be appreciated
Airtronics M12
TSR power
Old 07-12-2012, 08:13 PM   #6831
Jomo918's Avatar
I did some gearing combos for myself so i always know where I'm geared. Here you go. 13.5 turn should be around a 7.0 FDR. so in order to achieve it you can run a 76 spur and a 28 pinion.
Spur / pinion X internal gear ratio = Final drive ratio (FDR)
72/32x2.6=5.85
72/31x2.6=6.04
72/30x2.6=6.24
75/34x2.6=5.73
75/32x2.6=6.09.................13.5 turn = 7
76/30x2.6=6.56.................76/28=7.06
76/28x2.6=7.06
76/25x2.6=7.90
78/24x2.6=8.45
81/24x2.6=8.77.................7.5turn = 9.5
81/22x2.6=9.57.................81/22=9.57
83/22x2.6=9.81
83/20x2.6=10.79
83/18x2.6=11.99
85/18x2.6=12.28................17.5turn= 6
85/22x2.6=10.04................72/31=6.04
85/24x2.6=9.21
87/18x2.6=12.56
87/20x2.6=11.31
87/23x2.6=9.83..................10.5 turn= 8
87/24x2.6=9.425.................76/25= 7.90
~~~~~ Joey Morales ~~~~~
Hotbodies D8T/Spektrum
Novarossi/AKA/Futaba
Heritage RC Raceway, San Diego CA
Jomo918 is offline   Reply With Quote
Old 07-12-2012, 09:08 PM   #6832
P6
i acually just logged in to check and see if that toe block has been covered great post jonny5 , hit a wall in the dining room and it poped right out
P6 is offline   Reply With Quote
Old 07-12-2012, 10:00 PM   #6833
DBL15's Avatar
72/32x2.6=5.85
72/31x2.6=6.04
72/30x2.6=6.24
75/34x2.6=5.73
76/28x2.6=7.06
76x25x2.6=7.90
78/24x2.6=8.45
83/22x2.6=9.81
83/20x2.6=10.79
83/18x2.6=11.99
85/24x2.6=9.21
87/18x2.6=12.56
87/20x2.6=11.31
87/23x2.6=9.83
87/24x2.6=9.425
what about for a 10.5 mate you think ? higher or lower FDR ?
great post by the way
C/O Coast2coastrc (www.coast2coastrc.com.au) SMC Lipo
Tekno Rc , Team Tekin , Panther-Rc , De Racing , Upgrade Rc , Team Triton rc , M2C clutches , Nitro X fuels
DBL15 is offline   Reply With Quote
Old 07-12-2012, 10:11 PM   #6834
Jomo918's Avatar
10.5 turn you want to be at about 8 FDR! So try a 76/25 which equals a FDR of 7.90! Gets u real close!
Old 07-12-2012, 11:36 PM   #6835
ekt
ekt's Avatar
I found a couple sites that help with choosing gearing.
http://www.teamnovak.com/tech_info/b...r_gearing.html to get an idea of what FDR you want and http://www.gearmachine.net/ makes an easy table to see what gearing gets you close to the FDR.
ekt is offline   Reply With Quote
Old 07-13-2012, 04:11 AM   #6836
Team Durango DEX210 Gear Chart
Arn0 is offline   Reply With Quote
Old 07-13-2012, 07:09 AM   #6837
scr8pn4205's Avatar
who makes a 76 spur for this
Airtronics M12
TSR power
Old 07-13-2012, 07:27 AM   #6838
ekt
ekt's Avatar
If I remember correctly Schumacher spurs fit, they make a 76t.
Old 07-13-2012, 08:07 AM   #6839
hyperSC82's Avatar
Here you go RW makes a 75 tooth spur
http://www.amainhobbies.com/product_...ear-75T-DEX210
Team Durango DESC410 - Viper VTX10R BE, VST550 4.5
hyperSC82 is offline   Reply With Quote
Old 07-13-2012, 07:46 PM   #6840
Trader Rating: 49 (100%+)
Looking at a Reedy 9.5. Would this motor be better in the 210 or 410? The track I run on is pretty small. Thought I would get some ideas. Anyone using this motor?
Garnold is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16564 08-19-2017 05:06 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
