Like Tree26Likes
Old 07-10-2012, 07:57 PM   #6811
Trader Rating: 40 (100%+)
Send a message via AIM to brians11
Originally Posted by nolimit208 View Post
I kept the stock ones for a while but was at a big race and in the rythem section my rear ones would pop off and didn't it almost every qualifier and 2 out of 3 amains which caused me the race. They were brand new also. I replace them before this race.
So now I use Losi Titanium turnbuckle/ballcups/ball studs got the while kit for $35 bucks.
Where did you find this kit?
Team Tekin | Superiorhobbies.com
brians11 is offline   Reply With Quote
Old 07-10-2012, 09:54 PM   #6812
nolimit208's Avatar
Send a message via AIM to nolimit208 Send a message via MSN to nolimit208
Buy 3 of-
http://www.amainhobbies.com/product_...e-Set-2-TLR-22
1x-
http://www.amainhobbies.com/product_...d-Set-4-TLR-22
2x
LHS had them for a little cheaper but still way better then spending on lundsford. I didn't get the Ti ball studs though.
They actually might not be Ti lol but better then stockers. I just baught them and slapped them on really.
nolimit208 is offline   Reply With Quote
Old 07-11-2012, 10:21 AM   #6813
Does anybody know what these are? Oe looks alot like a Durango 2wd buggy and the other is def a DEX210 with aftermarket chassis or side pods.
Durango DEX210 Thread-dex210-spy.jpg   Durango DEX210 Thread-durango_caster.jpg
______________________________________________________
Team Tulsa - Team R/C Paints by Sonny - Durango DEX410
qwkpony is offline   Reply With Quote
Old 07-11-2012, 10:24 AM   #6814
Matt Howard's Avatar
Originally Posted by qwkpony View Post
Does anybody know what these are? Oe looks alot like a Durango 2wd buggy and the other is def a DEX210 with aftermarket chassis.
The first one is a DEX210 with some sort of aftermarket chassis, the second one is a losi 22
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 07-11-2012, 11:19 AM   #6815
nolimit208's Avatar
They actually just cut down the side rails to fit a losi body on the dex210. I have seen this before. i think losi's look horrible so not sure why someone would do this but its just my opinion.
but they are shaving weight off by doing so i guess
Old 07-11-2012, 11:27 AM   #6816
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Originally Posted by Cpt.America View Post
FYI, the Cpt.America mod is only needed if running 30+ degrees of caster. 25 or less and it's unneeded.
Originally Posted by aloksatoor View Post
Did not know that
When running 30 degrees of caster, the ends of the steering blocks are much lower, because they are pitched backwards at 30 degrees. In order to get 0 bumpsteer, you end up having to run an unGODLY amount of spacers... something like 7mm under the ballstud (i forget exactly). That puts far too much leverage against that ball stud.
When you run 25 caster, the pitch is less, and the steering block is rotated forward, rasing the end. So you end up having to run less.... like 2 or 3mm, which works just fine (i don't recall the exact mm needed).
I was running 25 degrees of caster AND the cptamerica mod, and to get 0 bumpsteer, I was down at I believe 0mm of washers under the steering block ballstud. So... if you are set on running 25 degrees of caster, the factory setup works fine. If you are running 30 degrees of caster, you wont be able to achieve 0 bumpsteer without either running 7+mm of wahsers under the steering block ballstud, or.. use the cpt.america steering rack mod
hope that helps.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 07-11-2012, 01:25 PM   #6817
aloksatoor's Avatar
Trader Rating: 42 (100%+)
hope that helps.
Cool to have the info in one post . *deleted* not the place
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 07-11-2012, 01:34 PM   #6818
Super Moderator
Cool to have the info in one post . ****edited**** .
But that is a topic of a different thread. This is a great car and is working great for a lot of people!...
- RCSpecialties -
Old 07-11-2012, 07:06 PM   #6819
Slimsh8t's Avatar
Trader Rating: 39 (100%+)
Default Question
Hey guys who's making aluminum 3degree kick ups.?
Kevin Murphy
Associated B5m/Reedy
AP Custom Paint/Kal-Gard/
Slimsh8t is offline   Reply With Quote
Old 07-11-2012, 07:08 PM   #6820
I've got the one from Team SR and like it.
http://www.teamsr.co/shop/item.asp?item=TSR060
RCTech #361
Old 07-12-2012, 03:15 AM   #6821
scr8pn4205's Avatar
Well did the Captain America mod last night. No issues at all. running center hole in rack with the std lock nuts and no hitting on the arm. Now all I gotta do is go try it out. The car is great and very consistent on the track
Airtronics M12
Team Xray XB2 2017 CE
TSR power
scr8pn4205 is offline   Reply With Quote
Old 07-12-2012, 07:16 AM   #6822
Trader Rating: 19 (100%+)
Went club racing with Cush last night running the +8 chassis on the outdoor track. He had a tough race, missing the landing on the big quad on the first lap and the lead two cars got away clean, but he was able to improve his fastest lap times from a 28.6 with the std chassis to a 27.7 last night. We're going back to practice tonight and try a few things to tighten up a slight exit push, but overall he's pretty happy and the car looks good. My taper pistons showed up too so we'll be testing those as well.
Serpent America/Desoto Racing- www.serpentamerica.com
TrakPower Speed Equipment- www.trakpowerusa.com
B Fast RC Performance- www.bfastrc.com
Futaba | Strictly R/C- Norridge, IL
Thank you all for the help and support!
Jonny5 is offline   Reply With Quote
Old 07-12-2012, 07:21 AM   #6823
rcjunky1's Avatar
I am, I make 0/3, 1.5/3 and 3/3 blocks, as well as shims to raise the 0/3 to the other 2 angles as well. I'm also working on an aluminum +8mm chassis, if things don't get delayed again its looking like maybe the end of the month for those.
Official distributor of Dan-O-Mite Custom Parts- Durango 210 RF pivot blocks
Andrew Butters' Burghgraef
Team Durango Canada
Great Hobbies, Hobbico, Skyrc, Exotek
rcjunky1 is offline   Reply With Quote
Old 07-12-2012, 08:31 AM   #6824
symmetricon's Avatar
Trader Rating: 27 (100%+)
I have been running rcjunky's aluminum hing pin block and it has been flawless.
XRAY / RCAMERICA
JCONCEPTS
RCSHOX
Mikes Hobby Shop
symmetricon is offline   Reply With Quote
Old 07-12-2012, 11:46 AM   #6825
Evil Genius jr.'s Avatar
Trader Rating: 28 (100%+)
I'm thinking of getting the DEX210 to race this indoor season. What spares should I carry if I am the only one using a Durango? Any mods I need to do?
Thanks! Hate to be a noob on this one but after reading the whole DESC410R and about 1000 pages of the SC10 4x4 threads I'm a little rctech threaded out. Search didn't turn up anything useful.
Brushlesshobbies.com
DESC410
Evil Genius jr. is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16568 09-15-2017 05:07 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
