Like Tree24Likes
Old 07-10-2012, 10:17 AM   #6796
Default Finished!!
Just finished the build on the car including a Finnisher body (it'll need some strategic sticker placement). Built in MM4 to start. We'll see how long that lasts. Just waiting on return of my charger and batteries and i'll be all set. Playing with NiMh at the moment to test before heading to the track. Only ran up and down the street a couple of times so far. I can tell that I'll need to play with gearing. I have a 33/72 combo at the moment. Plan on hitting the track this weekend or sooner.
damo is offline   Reply With Quote
Old 07-10-2012, 10:58 AM   #6797
P6
kinda a dumb question but are their better or worse slipper pads , and do they make a slotted slipper plate or pad for this buggy, i noticed when i ran the other day i temp the slipper at 140 everything else was under 120 ,, i know it was loose because im trying to wear them in for smoothness
P6 is offline   Reply With Quote
Old 07-10-2012, 11:15 AM   #6798
Trader Rating: 19 (100%+)
Running it loose will glaze the pads over and hurt performance, and also lead to excessive heat like you found. We use stock pads without issue. If your pads are glazed try flipping them over to the fresh side and setting the slipper correctly- the heat should decrease considerably.
Serpent America/Desoto Racing- www.serpentamerica.com
TrakPower Speed Equipment- www.trakpowerusa.com
B Fast RC Performance- www.bfastrc.com
Futaba | Strictly R/C- Norridge, IL
Thank you all for the help and support!
Jonny5 is offline   Reply With Quote
Old 07-10-2012, 12:41 PM   #6799
P6
couldn't i just use a fine grit sand paper on the glazed side just to save the other side untill i need it
Old 07-10-2012, 01:00 PM   #6800
05PSD's Avatar
I always found using a razor blade to scrape the glaze off works quite well.
EB48.4
SCT410
B6
05PSD is offline   Reply With Quote
Old 07-10-2012, 01:31 PM   #6801
+1
Old 07-10-2012, 02:56 PM   #6802
Ethan5050's Avatar
Trader Rating: 54 (98%+)
Hello, well let me start off with saying this is my first 2wd buggy and i hope this was the right choice.. I was debating between the rb5 sp2 wc, and this... Well needless to say i bought the dex... Well I've been going through the this thread and can't find a solid answer so maybe you guys can help me...
ok are the ball cups really that bad? and if so can you tell me a good solid fix(losi,rpm,lungsford cups) with parts numbers.
and finally is there any hop-ups i need for a rock solid racer, and what extra parts should i keep on hand???? Well sorry for the story guys all your input would be greatly appreciated..... thanks!!!!!
Im DONE with NITRO!!!!!!
Ethan5050 is offline   Reply With Quote
Old 07-10-2012, 03:00 PM   #6803
aloksatoor's Avatar
Trader Rating: 42 (100%+)
Originally Posted by Ethan5050 View Post
Hello, well let me start off with saying this is my first 2wd buggy and i hope this was the right choice.. I was debating between the rb5 sp2 wc, and this... Well needless to say i bought the dex, well I've been going through the this thread and can't find a solid answer so maybe you guys can help me...
and finally is there any hop-ups i need for a rock solid racer, and whats extra parts should i keep on hand???? Well sorry for the story guys all your input would be greatly appreciated..... thanks!!!!!
Yep the stockers are really really bad. Replace with lunsford 4.8s or if you have the cash Kyosho hard ends - both will require ball studs to go with since the rango is a little non standard size and bit loose with both brands above (ipersonally found the k ball studs breakable so I use the hpi 4.8 come cheap and tough).
I have both the wc and the dex210. The dex210 is a shelf queen until the molded chassis comes out. Even after I might still keep the kyosho since it likes my driving style so much better and very little slop compared to the rango.
http://www.amainhobbies.com/product_...all-End-Set-10 X 2 and
http://www.amainhobbies.com/product_...m-Ball-Stud-10 X 2
with this option you can use the rango turnbuckles since the ball ends are long.
http://www.amainhobbies.com/product_...m-Ball-Cups-12 with this option you need fatter and longer 3.5mm turnbuckles since the ends are small.
People have used losi but I personally stay away from that brand. No hop ups compulsory but if possible get the ftw racing carbon steering plate and do the capt america mod described previously in the thread. And keep a set of f/r arms and rear hubs nearby. Car is quite tough out of the box.
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 07-10-2012, 03:14 PM   #6804
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
FYI, the Cpt.America mod is only needed if running 30+ degrees of caster. 25 or less and it's unneeded.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 07-10-2012, 03:32 PM   #6805
Trader Rating: 109 (100%+)
Send a message via AIM to kwiksi
There is nothing wrong with the kit ball cups. I had a kit from the first batch and I've never had one pop off during quite a few rough tumbles. The factory Durango guys use them. Just build em right. Grease the turnbuckle threads. I actually threaded mine all the way in and out of the cup a couple of times. Yes it's an extra step and a pain, but worth the trouble.
kwiksi is offline   Reply With Quote
Old 07-10-2012, 03:33 PM   #6806
Vented slipper plates should be out mid month.
http://www.team-durango.com/part-inf...artNo=TD310272
Old 07-10-2012, 03:46 PM   #6807
SavageCanadian's Avatar
Trader Rating: 58 (100%+)
Send a message via MSN to SavageCanadian
If anyone is looking for a 210 I have one for sale FS: DEX210 roller
CR Performance Custom RC Parts (PM for details)
Colin Roussel
2013/2014 WCICS CTA Champ
Awesomatix | Roche | Trinity/Revtech | SANWA | ORCA
SavageCanadian is offline   Reply With Quote
Old 07-10-2012, 04:23 PM   #6808
aloksatoor's Avatar
Did not know that
Old 07-10-2012, 05:45 PM   #6809
Ethan5050's Avatar
So it has lots of slop in the steering, is their any way to get rid of that?
Old 07-10-2012, 07:46 PM   #6810
nolimit208's Avatar
Send a message via AIM to nolimit208 Send a message via MSN to nolimit208
I kept the stock ones for a while but was at a big race and in the rythem section my rear ones would pop off and didn't it almost every qualifier and 2 out of 3 amains which caused me the race. They were brand new also. I replace them before this race.
So now I use Losi Titanium turnbuckle/ballcups/ball studs got the while kit for $35 bucks.
nolimit208 is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16564 08-19-2017 05:06 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
