Like Tree23Likes
Old 07-07-2012, 08:35 PM   #6781
Azagar's Avatar
Any chance you could tell us your total weight Randy with the composite chassis.
Team Durango DEX210
Avid | AKA | Exotek | Jconcepts | KO Propo | Lunsford | Tekin | Turnigy Nano-tech
Azagar is offline   Reply With Quote
Old 07-07-2012, 08:39 PM   #6782
nolimit208's Avatar
Send a message via AIM to nolimit208 Send a message via MSN to nolimit208
Originally Posted by hyperSC82 View Post
What oil you guys running in your gear diffs?
Black grease. I dont use any diff fluid. I found it rotates alot better with the black gear grease.
nolimit208 is offline   Reply With Quote
Old 07-08-2012, 06:04 PM   #6783
vazzo's Avatar
Trader Rating: 100 (100%+)
Originally Posted by kwiksi View Post
Ditch the MM3...your not doing yourself any favors in loose/dusty tracks. Go RM4.
You can try my recent setup that I ran with 17.5 in blinky for outdoor low to med bite.
All 17.5 mfr's motors are a bit diff so go by temp.
http://www.petitrc.com/setup/durango...603/index.html
Thanks for the info mate. Just a quick one, in your setup you mention and.1 inserts not knowing the tyres already came with and.1 I bpurchased and.1 firm inserts seperately and glued them up. Will the firm inserts make a huge difference over the ones that come with the tyres standard?
Thanks,
Adrian
Gone riding, cya.........
vazzo is offline   Reply With Quote
Old 07-08-2012, 06:26 PM   #6784
Trader Rating: 109 (100%+)
Send a message via AIM to kwiksi
double post
kwiksi is offline   Reply With Quote
Old 07-08-2012, 06:26 PM   #6785
Thanks,
Adrian
Your welcome Adrian
Tires were JConcepts Groovies & Flipouts in rear. Track was hard packed with some loose dirt. Too dusty for Double Dees, but not loose enough for Goosebumps.
JConcepts all come with And1 inserts. I use a cut down rear foam (3/4)in the front tire though.
Old 07-08-2012, 08:10 PM   #6786
Just getting ready to order some pinions and spur gears. Any suggestions for a 17.5 Orion motor?
Shins is offline   Reply With Quote
Old 07-08-2012, 09:09 PM   #6787
vazzo's Avatar
I run 69/34 soon to be 35 as the Novak 17.5 likes to be geared up
^^Thanks again David.
Old 07-08-2012, 11:24 PM   #6788
onekiwi's Avatar
Originally Posted by discgolferlee View Post
Any tips on removing shock caps or taking shocks apart withou scratching the bodies all up. Any special shock tools I might be missing. I know some kits come with plastic shock wrenches for working on your shocks.
Just use a pair of pliers and with the cutting bit of it lift up the rubber grommet at the base and clamp it there, that part of the shock doesn't go near the orings anyway, This is how I do mine and they still look pretty darn good
Ahhh your talking about the bodies after I re read the post, anyway I just jse a rag and do mine hand tight then give it a little crank, has never come loose yet
XB2 CE
XB4 16
Sanwa
Hobbywing
#kiwipaint on facebook
onekiwi is offline   Reply With Quote
Old 07-09-2012, 04:13 AM   #6789
I would get a 69 & 75. I've played with motors that liked both.
Old 07-09-2012, 10:00 PM   #6790
SLOWINSLOWOUT's Avatar
Trader Rating: 19 (100%+)
Anyone using the TD alloy rear hubs? What is the shimming spec to set the ball stud at the same height as the plastic hubs?
SLOWINSLOWOUT is offline   Reply With Quote
Old 07-09-2012, 10:15 PM   #6791
nolimit208's Avatar
I don't have the alloy ones but measurement from hinge pin to center of ball stud is about 27mm's. Should be able to get it to stock height using a set of callipers.
Old 07-09-2012, 10:54 PM   #6792
Azagar's Avatar
Well if you happen to use the Lunsford ball studs then 4mm is the smallest you can go since the 8mm stud is 1mm too long to fully screw into the hub with just a 3mm spacer. I use 4mm and have no problems, no rubbing on the rim at all.
Team Durango DEX210
Old 07-10-2012, 04:56 AM   #6793
We've got 2.5mm under the ballstud on the alloy hubs. That's the minimum amount of shims you can put in with the stock length ballstud, though you could dremel a bit off the end if you want to lower it some more.
Another note on the aluminum hubs- we have the Tresrey clamping hexes on both buggies, and when I tried to tighten the wheel I got some serious binding. After a bit of fiddling with shims I found that placing 3 silver and 1 copper shims (the ones found in the package with the Tresrey hubs) inside the outer bearing acts like a crush tube and allows you to tighten it up with no bind at all. I'll measure the thickness of the shim stack next time it all comes apart, but that should help anyone having the same issue get it resolved.
Serpent America/Desoto Racing- www.serpentamerica.com
TrakPower Speed Equipment- www.trakpowerusa.com
B Fast RC Performance- www.bfastrc.com
Futaba | Strictly R/C- Norridge, IL
Thank you all for the help and support!
Jonny5 is offline   Reply With Quote
Old 07-10-2012, 06:40 AM   #6794
discgolferlee's Avatar
Trader Rating: 42 (100%+)
thanks for tip on the shaft.
yeah just bought the buggy used and shock caps appear to be on pretty tight.
discgolferlee is offline   Reply With Quote
Old 07-10-2012, 07:06 AM   #6795
Just got word from Tresrey that the red motor plates are in stock and ready to ship. These are machined for extra cooling and of course have the signature red anodizing.
St Ives RC Club B4Bandit Australian Racing 16564 Yesterday 05:06 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Kremzeek
