Like Tree23Likes
Old 07-01-2012, 10:03 PM   #6706
Trader Rating: 19 (100%+)
Originally Posted by nolimit208 View Post
Never mind on the setup. PDF keeps failing to upload.
Try to save the file as a jpeg, or take a picture of the screen and upload that. Ran into the same issue- kept saying the file size was too big.
Serpent America/Desoto Racing- www.serpentamerica.com
TrakPower Speed Equipment- www.trakpowerusa.com
B Fast RC Performance- www.bfastrc.com
Futaba | Strictly R/C- Norridge, IL
Thank you all for the help and support!
Jonny5 is offline   Reply With Quote
Old 07-01-2012, 10:49 PM   #6707
Azagar's Avatar
It seems we 210 owners take a lot of pride on our clean layouts, great looking car Jonny5
I was taking a look at many of Jorn's buggy pictures and it appears he is using the 410 aluminum wing mount to secure his wing, anyone got any ideas how he does that? Not a fan of using those safety pins to secure my wing, even after boreing out the old wheel cones to use that instead of the stock plastic ones.
Team Durango DEX210
Avid | AKA | Exotek | Jconcepts | KO Propo | Lunsford | Tekin | Turnigy Nano-tech
Azagar is offline   Reply With Quote
Old 07-02-2012, 07:10 AM   #6708
I just snip off the buttons on the stock wing mount and drill/tap a hole to use screws to secure the wing. I've seen on Oople.com that some guys are cutting up the rear bulkhead off the 410 and bolting it to the rear tower to raise the wing- they claim it helps with rear towers breaking as well.
Old 07-02-2012, 02:31 PM   #6709
onekiwi's Avatar
Jorn is using protypes of Im not sure what make but possibly durangos own. There is another company coming out with alu mount but not sure when they will be released, check redrc or neobuggy they had the company on their site.
I also use the cut 410 mount om my MM 210, I havent tried it on a RM car yet
XB2 CE
XB4 16
Sanwa
Hobbywing
#kiwipaint on facebook
onekiwi is offline   Reply With Quote
Old 07-02-2012, 04:04 PM   #6710
nolimit208's Avatar
Send a message via AIM to nolimit208 Send a message via MSN to nolimit208
Here is my setup for NCT #3 in Meridian Idaho. Large track, blue groove.
nolimit208 is offline   Reply With Quote
Old 07-02-2012, 07:14 PM   #6711
P6
Do u time down the motor on smaller tracks I have the 8.5 reedy with a brushlesshobbies 120a and 65c nanotech packs I'm trying to figure out if I should turn up the motor or just leave it at 20 and mess with the esc
P6 is offline   Reply With Quote
Old 07-02-2012, 07:17 PM   #6712
Trader Rating: 31 (100%+)
does anybody else find this ride height strange
MBX6-ECO, B5m
Cspurlock is offline   Reply With Quote
Old 07-02-2012, 07:17 PM   #6713
MantisWorx's Avatar
Trader Rating: 28 (97%+)
typically when using boost you want to keep the motor timing at zero and let the ESc control your timing band. Using both will result in higher temps and "flattening" your power near the end of the race.With an 8.5 it already has plenty of low end so just bring in the turbo with about a .4 second delay and the smoothest ramp.
MantisWorx is offline   Reply With Quote
Old 07-02-2012, 07:26 PM   #6714
P6
so instead of leaving at the 20 turn it to 0 and use esc timing ill have to figure it out but thanks , more forum time i guess lol its killing me waiting to drive the thing ive had it almost a month now and its one thing after another to keep it from running
Old 07-02-2012, 07:31 PM   #6715
I typically leave an 8.5 with the std 20deg timing it comes with and leave the esc with no boost on its stock settings. 8.5 is a lot of motor for a 2wd buggy and you probably just need to gear for your particular track and you will be fine.
MBX6-ECO, B5m
Old 07-02-2012, 07:46 PM   #6716
DBL15's Avatar
20mm front and 16mm back i thought miss print ? but it might work for him
C/O Coast2coastrc (www.coast2coastrc.com.au) SMC Lipo
Tekno Rc , Team Tekin , Panther-Rc , De Racing , Upgrade Rc , Team Triton rc , M2C clutches , Nitro X fuels
DBL15 is offline   Reply With Quote
Old 07-02-2012, 08:02 PM   #6717
Yeah I was thinking misprint also
MBX6-ECO, B5m
Old 07-02-2012, 09:08 PM   #6718
+1. You can always turn it up if you need more, but better to walk before you run, especially when feeling out a new ride.
Old 07-02-2012, 09:43 PM   #6719
MantisWorx's Avatar
If you crank your motor timing to 20* it is 20* at all times and will create unnecessary heat . If you use 20* of boost you can set where the power comes in and will give you a softer bottom end which tends to work better on 2wd since you are traction limited in most situations. 20* is 20* but by using the ESC for timing you can control when and where you need the power. Instead of having to "roll" the throttle you can be more aggressive with your trigger finger and not worry about over powering the car. Its much easier to apply 20* of timing once you are already moving than it is to add it from a dead stop. One of the reasons that boost works so well!
Old 07-03-2012, 09:31 AM   #6720
P6
gear mesh problem ? so the driveling without the motor seems smooth spinning tires or spur to check the pinion on the motor spins smooth but as soon as the pinion and spur mesh no matter how tight or loose the mesh is it feels like its skipping gears on the spur when i spin the wheels gearing is 24 81 rm3 ,, any ideas? ive already taken it all apart and everything looks fine and it was put together right , and i just drove it with no problems walked up stairs and then it started ,, by the way thanks for the forum thats why i bought this buggy i love it after only driving a slash 4x4 and last rc were in 03 back in the brushed motor days
St Ives RC Club B4Bandit Australian Racing 16563 Today 04:32 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
stoopideric
