Like Tree24Likes
Old 06-21-2012, 02:35 AM   #6586
Trader Rating: 49 (100%+)
Guys, other then here and dirt runners do you know of any places that allow up practice time? I was told that Barnstorm is race only. Where else do you guys go to mix it up some?
Garnold is offline   Reply With Quote
Old 06-21-2012, 03:34 AM   #6587
Originally Posted by CFR View Post
Slipper Clutch Issue
The thing won't stop slipping no matter what we do, even with new pads and the nut done up tight.
car has a gear diff installed
Check the spacer on the layshaft. File it down if there is any wear on the inside of the tube and then put some 1/8 clutch shims either side making sure that there is still some play when the gearbox is put together. You can also put some shims before the first slipper pad goes on to get some more tension on the slipper. I would also advise using AE pads cutting them down to make sure they sit flat in the spur gear and then you should not have any more problems. HTH.
Schumacher K2, KF2, K1, KF | TeamC TM2 V1, TM4 | Durango DEX410 V3 | T-Rex 450SEV2,250SE | EMAX 250 | Gravity 250 | KC250
AmiSMB is offline   Reply With Quote
Old 06-21-2012, 05:51 AM   #6588
Trader Rating: 21 (100%+)
Default My 1st buggy
I decided to pick up a buggy to race an additional class to 2wd SC. I had a chance to run a couple laps last night on the track. Unfortunately it didn't last long b/c the rear hub broke right at the ball stud. Are there HD-rear hubs to purchase or do I simply get the stock ones again?
Simple paint job:
mulepic is offline   Reply With Quote
Old 06-21-2012, 05:57 AM   #6589
dexon555's Avatar
Simple paint job:
TD makes aluminum rear hubs.
http://www.team-durango.com/part-inf...artNo=TD330377
CSRCCC -Officer-
Team Durango: DEX410 v.3, DESC410R
KO Propo: EX-10 Eurus w/ Drop Down
Tekin: RS-Pro & Redline 6.5, RX-8 & Pro4 4000kv
Hi-tec: X4/AC Charger
dexon555 is offline   Reply With Quote
Old 06-21-2012, 06:35 AM   #6590
Trader Rating: 19 (100%+)
Just changed over to 4 gear rear motor.
Only just messing about on the lounge room floor (carpet) at first I didnt really notice any difference but then I put on some old well worn calibers and it stuck like glue, before they were like a sprint car.
Hopefully this will help a little on the track and not take away too much steering.
Shimmy is offline   Reply With Quote
Old 06-21-2012, 06:49 AM   #6591
Originally Posted by dexon555 View Post
A little pricey for my beginning stages. I'm not going to have to replace all the plastic w/ aluminum to get durability am I?
Old 06-21-2012, 07:06 AM   #6592
dexon555's Avatar
No, not "all" but, with any kit they try to meet a price point fot the kit and have to make compromises. As you race you will decide which parts are worth the upgrade. I was just trying to answer your question about a durable option.
CSRCCC -Officer-
Old 06-21-2012, 07:23 AM   #6593
And you did, thanks I appreciate it. Fortunately I have a milling machine, I might try to work w/ the stock plastic ones and beef them up to withstand my driving skill (or lack thereof).
Old 06-21-2012, 07:44 AM   #6594
Trader Rating: 73 (100%+)
Default Carbon Chassis Durability
Hi All,
A quick question for any of you running a carbon chassis.
How are they holding up?
Any areas of concern or any failures?
Cheers
mister_g is offline   Reply With Quote
Old 06-21-2012, 07:57 AM   #6595
Originally Posted by mister_g View Post
Hi All,
Cheers
Got the same question. It weights 1 Oz. anybody know how much the stock alum. ones weight?
GuiltyByAssoc is offline   Reply With Quote
Old 06-21-2012, 08:26 AM   #6596
Trader Rating: 31 (100%+)
Another less expensive option you can try is to take the long ball stud(not sure the part#) and run it through the hub and then put a low profile nut on the back. A couple of us have done that and not had any issues since.
MBX6-ECO, B5m
Cspurlock is offline   Reply With Quote
Old 06-21-2012, 08:39 AM   #6597
Default share ideas
I had a thought:
A lot of us share our tips and tricks on this thread when someone asks a question, but what if we all posted our little mods we have done that have been succesful so that we can all benefit from them? I know that I learn little things all the time reading this thread, it would be nice to collaborate all of our tips. I will go first:
I put little black Orings in between the screw head and the gear cover. It gives a cushion so that when you tighten down the screw you don't break the gear cover. I haven't broken one since I started doing that.
I run long ball studs through the rear hub and put a low profile nut on the back to stop the ball stud from ripping through the rear hub.
hope to hear some tips from others!
MBX6-ECO, B5m
Old 06-21-2012, 08:48 AM   #6598
Stock chassis weighs 106 grams and the carbon versions I have seen are 45 grams.
Old 06-21-2012, 02:28 PM   #6599
heygobenny's Avatar
What carbon chassis conversions are there?
Durango FTW
Team Durango DESC410R W/ Tekin RX8 Pro 4
Team Durango DEX408 W/ Tekin Rx8 t8
Team Durango + Savox + Futaba + Tekin + AKA + GensAce + Upgrade + Exotek =WIN
heygobenny is offline   Reply With Quote
Old 06-21-2012, 04:45 PM   #6600
Konich's Avatar
Currently 8 Racing makes a standard CF chassis and a +8 as well for the 210
Tresrey Spec DEX410 - Yaiba Spec B5M
Konich is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16564 08-19-2017 05:06 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
