Like Tree26Likes
Old 06-18-2012, 05:57 AM   #6571
Trader Rating: 19 (100%+)
Originally Posted by mister_g View Post
People I know here in Adelaide have had great success with losi 22 items.
Ball Studs come in in 6mm, 8mm and 10 mm lengths.
Depending on link positions you may need to use 22 turnbuckles too as the durango cups are a bit longer.
Modelflight will have everything you need with next day shipping.
I personally use Team-C turnbuckles and cups (as I have Team-C cars too) with 22 ball studs.
http://www.tcmodels.net/index.php?pa...mart&Itemid=71
Cheers Matt
Ta, thanks for that mate.
Another option to add to the list.
I have the J Concept rod ends on my X6 Sq buggy and they are almost the same length as the Durango but are made for 4.3mm ball studs.
Do you have any problem with access to those TLR22 ball studs seeing as they dont have the hex fitting?
Shimmy is online now   Reply With Quote
Old 06-18-2012, 06:10 AM   #6572
Trader Rating: 73 (100%+)
22 ball studs do have a 2mm hex on top.
mister_g is offline   Reply With Quote
Old 06-18-2012, 06:37 AM   #6573
Oh, cool, for some reason I didnt think they did.
Do you have any issues with the link hitting the rim when using the outer holes on the hub?
Also is the 22 ball studs any higher than the stock durango ones?
Old 06-18-2012, 06:44 AM   #6574
TAMAK's Avatar
Trader Rating: 28 (100%+)
New clay car, and my MM4 carpet car!!
TrakPower Speed Equipment / Speed Passion
Serpent Natrix 748 TQ - Nova REX
D413 Reventon 1.1ex 13.5t; AE B6d Laydown Reventon Pro 1.1
DNX408V2-NovaP5, DETC410-Reventon 1.1ex-5.5t MMM
RC10 , RC10GT2- CV-R- SAVOX,
TAMAK is offline   Reply With Quote
Old 06-18-2012, 07:09 AM   #6575
Ive not run on the outer holes but can't see how it would be any different to the stock link setup.
Yes 1mm higher.
Old 06-20-2012, 01:50 AM   #6576
Questions?? remove and tighten slipper
Hello to all of you,
I have just built my DEX and have some problems with the slipper clutch.
First thing is that I have problems to remove it, in order to clean up the slipper or change the 87T gear ?
Of course, I removed the motor, then the 5.5 nut and its spring, but then I can not remove the slipper. It stays in place.. I try using a small hammer to push it out but it did not work..
Any idea ? May be too much lock on the pin ?
My second question is about the tightening of the slipper. Because I do not know how to stop the slipper from slipping when I tighten the nut ?
Thanks for any answer !
gre99ory is offline   Reply With Quote
Old 06-20-2012, 05:21 AM   #6577
TAMAK's Avatar
Photos would help alot. But sounds like you over tightened it and applied too much lock tight. Best bet is to attach a photo.
Old 06-20-2012, 12:26 PM   #6578
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
Something new to paint arrived at my house yesterday!
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 06-20-2012, 12:38 PM   #6579
TAMAK's Avatar
Very Bulldog like. I like it. Will have to order one ASAP. lol
Old 06-20-2012, 02:20 PM   #6580
Ok, will someone pls send TD some Yellow paint? Can we get some Rear yellow wheels already!!
GuiltyByAssoc is offline   Reply With Quote
Old 06-20-2012, 02:28 PM   #6581
aloksatoor's Avatar
Trader Rating: 42 (100%+)
I will wait for the FTW version. However I LOVE the new SC Body.... whens it on sale???
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 06-20-2012, 02:35 PM   #6582
DBL15's Avatar
is that a new shell from Team Durango Randy ?
C/O Coast2coastrc (www.coast2coastrc.com.au) SMC Lipo
Tekno Rc , Team Tekin , Panther-Rc , De Racing , Upgrade Rc , Team Triton rc , M2C clutches , Nitro X fuels
DBL15 is offline   Reply With Quote
Old 06-20-2012, 04:04 PM   #6583
Autocratic's Avatar
Trader Rating: 26 (100%+)
That looks a lot like the Proline Bulldog body.
Thanks to my sponsors for 2015!
XFactory RC | Proline Racing | Fantom Racing | Avid RC | Speed Passion USA | Factory1 | Hy-Traction Juice | Mike's Hobby Shop
Autocratic is offline   Reply With Quote
Old 06-20-2012, 05:38 PM   #6584
Team Tekin
Randy_Pike's Avatar
Yes.
Old 06-20-2012, 11:37 PM   #6585
CFR
CFR's Avatar
Slipper Clutch Issue
The thing won't stop slipping no matter what we do, even with new pads and the nut done up tight.
car has a gear diff installed
CFR is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16568 09-15-2017 05:07 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
