Like Tree23Likes
Old 06-14-2012, 08:02 PM   #6541
nolimit208's Avatar
Send a message via AIM to nolimit208 Send a message via MSN to nolimit208
Buying a shorty pack to lower weight and be more adjustable.
Has anyone used the 3k 70c shorty by protek. Its $25 cheaper and 40g lighter then the 4.1k 70c they have. Think the 3k will last me more then enough time to race, just asking if anyone uses them for this car or any 2wd mod car.
nolimit208 is offline   Reply With Quote
Old 06-15-2012, 10:52 AM   #6542
Fast410's Avatar
Trader Rating: 40 (100%+)
does anyone no if someone makes a aluminum shock caps for the dex 210 big bores?
GRUDGE RACING $$ PROMOD KUSTOMZ real race car fabrication and custom painting -airbrushing CHICAGO WISEGUYS RACE CIRCUT-1/4 mile Door Slammers @ 200mph plus
Fast410 is offline   Reply With Quote
Old 06-15-2012, 10:56 AM   #6543
dexon555's Avatar
No aluminum caps yet.
CSRCCC -Officer-
Team Durango: DEX410 v.3, DESC410R
KO Propo: EX-10 Eurus w/ Drop Down
Tekin: RS-Pro & Redline 6.5, RX-8 & Pro4 4000kv
Hi-tec: X4/AC Charger
dexon555 is offline   Reply With Quote
Old 06-16-2012, 12:28 AM   #6544
Azagar's Avatar
Quick question to those using losi/rb5/b4 12mm hexs wheels. I was trying to figure this out today at the track because I was fed up with not having any TD rims in stock at my lhs, but plenty of 22 and b4 wheels.
The offset difference between the jconcepts mono losi 22 wheels and the dex210 wheels is just 2mm. Not sure if this is true for the b4 rims lhs only had pin style ones in stock, if someone has some b4 hex rims and would like to check that would be great. I bought jconcept model# 2091, measured the hex, 6mm width. Now the stock 14mm hex is 4mm wide. So can it really be that simple that all I need are those jconcept hex and no spacers and the offset stay unchanged when using losi rims or any other 12mm hex rim? It just seems too good to be true which is why I ask. My tresrey b4 axels came in today so i'll be using jc relux b4 rims upfront with 22 mono rims for the rear if all this works out.
Team Durango DEX210
Avid | AKA | Exotek | Jconcepts | KO Propo | Lunsford | Tekin | Turnigy Nano-tech
Azagar is offline   Reply With Quote
Old 06-16-2012, 06:13 PM   #6545
P6
so what c rating am i suposed to look for the races are 5 mins and 7 mins and i think the longest ive seen was a ten min main so i want to buy a couple to last 12-15 mins and a couple practice packs all the same c if i can , been reading just confused on what i should use im running 8.5t reedy sonic sensored with 120a esc savox servo the motor and servo are in the mail still,still researching batteries and esc before i buy any recommendations? ,,, thanks everyone for your help i ask alot of questions but i wanna know as much as i possibly can
P6 is offline   Reply With Quote
Old 06-16-2012, 08:45 PM   #6546
Mopar's Avatar
For battery http://www.amainhobbies.com/product_...-ROAR-Approved. I would not run for more than 8min in practice, it just takes longer to recharge. For ESC Tekin RS Pro, you can't go wrong, http://www.amainhobbies.com/product_...-Brushless-ESC. That's my 2 cents.
Mopar is offline   Reply With Quote
Old 06-16-2012, 09:00 PM   #6547
Trader Rating: 19 (100%+)
I have 3 of these and they are going good so far.
http://www.hobbyking.com/hobbyking/s...dProduct=23134
Shimmy is offline   Reply With Quote
Old 06-16-2012, 09:55 PM   #6548
Trader Rating: 31 (100%+)
Default nd help
Has anyone seen a rear camber link fix made of brass? I thought I saw one on here a while ago but can't find it anywhere. Appreciate the help..
MBX6-ECO, B5m
Cspurlock is offline   Reply With Quote
Old 06-16-2012, 10:45 PM   #6549
nolimit208's Avatar
Have seen CF and Delrin ones on here. Haven't seen a brass one.
http://www.tresrey-usa.com/tresrey-a...r-link-dex210/
Old 06-17-2012, 01:17 AM   #6550
hacker's Avatar
Trader Rating: 140 (100%+)
hi mate, do you know how heavy this lipo is?
it has 2 weights on their website. I am assuming the heavier one is boxed up ready to be shipped weight, or its just extremely heavy for a shorty
hacker is offline   Reply With Quote
Old 06-17-2012, 01:18 AM   #6551
Azagar's Avatar
They weigh 188g. I own 5 myself
Team Durango DEX210
Old 06-17-2012, 01:24 AM   #6552
hacker's Avatar
thought so, thanks for that.
Old 06-17-2012, 01:28 AM   #6553
hacker's Avatar
my intellect shorty weighs 218.5 grams, so 188 grams seems optimistic
Old 06-17-2012, 02:07 AM   #6554
Mine are 189g
My full size turnigy 2s hard case is 273g and full size intellect 2s hard case is 275g.
Old 06-17-2012, 04:12 AM   #6555
hacker's Avatar
ok thanks you 2
St Ives RC Club B4Bandit Australian Racing 16564 08-19-2017 05:06 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
