Like Tree43Likes
Old 06-13-2012, 12:26 AM   #6511
hyperSC82's Avatar
Originally Posted by hyperSC82 View Post
I run a 13.5 with a 75 RW spur and a 26T pinion. I think the 23 would be to low. After 10 min my temps are about 120 on the motor and esc.
Oh and that is blinky mode with 45 degrees of timing on my motor
Team Durango DESC410 - Viper VTX10R BE, VST550 4.5
hyperSC82 is offline   Reply With Quote
Old 06-13-2012, 05:31 AM   #6512
kwiksi's Avatar
Trader Rating: 109 (100%+)
Send a message via AIM to kwiksi
Originally Posted by vazzo View Post
Does anyone have a pinion size to run in 17.5 blinky. Currently using a 69 spur/32 pinion. Also am I pushing crap up hill by running MM3 on an outdoor medium to loose/dusty track? Should I be running RM3 instead?
Cheers
Adrian
Ditch the MM3...your not doing yourself any favors in loose/dusty tracks. Go RM4.
You can try my recent setup that I ran with 17.5 in blinky for outdoor low to med bite.
All 17.5 mfr's motors are a bit diff so go by temp.
http://www.petitrc.com/setup/durango...603/index.html
Thanks in 2017 to
Xray/RC America - JConcepts - Trinity - Sanwa - Hobbywing - Exotek - PT Racing Oils -Schelle
kwiksi is offline   Reply With Quote
Old 06-13-2012, 09:48 AM   #6513
rcjunky1's Avatar
Thanks. I confirmed that 25 is the smalles I could safely go, 24 would work but the mesh has a bit too loose for my likings, on low grip it probably would work. I'll be trying 25/75 and go from there, its geared a bit higher then my 22 but running rear motor will keep it cooler and I'll be running a big clay track instead of carpet, so I think it will be fine but will keep an eye on it for sure. if its too high I'll just go to 26/81 (a 27 would be the same ratio) I'm hopeing to give it its maiden run next Wednesday, too much school/summative work to make the first race tonight.
Official distributor of Dan-O-Mite Custom Parts- Durango 210 RF pivot blocks
Andrew Butters' Burghgraef
Team Durango Canada
Great Hobbies, Hobbico, Skyrc, Exotek
rcjunky1 is offline   Reply With Quote
Old 06-13-2012, 12:52 PM   #6514
nolimit208's Avatar
Send a message via AIM to nolimit208 Send a message via MSN to nolimit208
Originally Posted by nolimit208 View Post
Anyone Have a Rear Hub Set I could buy. Mainly the Rear Right hub. Would be willing to buy it or trade off the Ball Diff below.
Diff isn't in the best shape but out drives are new on it and the gear is new also that is on the diff but the thrust and plates are shot.
Just bumpin this post still searching for a Right Rear hub carrier.
nolimit208 is offline   Reply With Quote
Old 06-13-2012, 03:10 PM   #6515
Trader Rating: 19 (100%+)
In stock at Tower Hobbies. Just placed an order last night.
XRAY, RC America, MOTIV, Sanwa, Arrowmax, Neverlift Racing Apparel
Jonny5ive Designs- by racers, for racers!
Jonny5 is offline   Reply With Quote
Old 06-13-2012, 03:36 PM   #6516
nolimit208's Avatar
If you baught
http://www3.towerhobbies.com/cgi-bin...?&I=LXCCTE&P=7
they will not work the bearing sizes are smaller.
This is the correct one.
http://www3.towerhobbies.com/cgi-bin...?&I=LXCBZN&P=7
Stock Number
LXCBZN
Retail Price‡
10.49
Tower's Low Price
$8.99
Stock Status
(Estimated)
Early July
Old 06-13-2012, 05:25 PM   #6517
lockmouth's Avatar
Trader Rating: 33 (100%+)
I'm running 75/30 with a 13.5 and Orion R10 Pro (No Boost). My stuff come off the track ice cold. This car is geared different from the 22 in the tranny, so you have to run a bigger pinion to equal what you would run in a 22.
MARIO KNOX
HOTBODIES RACING / FULL THROTTLE RACEWAY (OWNER / OPERATOR)
lockmouth is offline   Reply With Quote
Old 06-13-2012, 06:16 PM   #6518
BOLISARIO's Avatar
Trader Rating: 57 (100%+)
Send a message via AIM to BOLISARIO
Default Missing kit parts
Well you can count me as another victim of missing kit parts. Finally got to work on building my shocks and noticed I was missing the shock rod end pivot balls for the front AND rear plus 8 low-pro locking nuts. Team Durango needs to fire whoever they got in the QC department in China because they are not getting it done right over there. Did they switch factories after the buyout or something? Because my first two pre-Hobbico kits were complete and i haven't heard of others missing anything either.
Oh well.....
BOLISARIO is offline   Reply With Quote
Old 06-13-2012, 07:16 PM   #6519
rcjunky1's Avatar
production stayed the same, just management changed a bit, but the kits them selves should be unchanged.
Does anyone one know what the internal ratio is on this car?
Team Durango Canada
Old 06-13-2012, 07:35 PM   #6520
Matt Howard's Avatar
2.6
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 06-13-2012, 08:05 PM   #6521
If you baught
Stock Number
LXCBZN
Retail Price‡
10.49
Tower's Low Price
$8.99
Stock Status
(Estimated)
Early July
Nice catch. I didn't order any, but I saw rear hubs listed on the 210 page so assumed they were right.
Old 06-13-2012, 08:11 PM   #6522
Trader Rating: 21 (100%+)
I run 75/31 with my 10.5..... No boost
AE B6
AE B64
kerby is offline   Reply With Quote
Old 06-13-2012, 08:41 PM   #6523
DBL15's Avatar
81 / 27 here small amount of boost on a 10.5
RW spur and schumacher pinon quite as a mouse
C/O Coast2coastrc (www.coast2coastrc.com.au) SMC Lipo
Tekno Rc , Team Tekin , Panther-Rc , De Racing , Upgrade Rc , Team Triton rc , M2C clutches , Nitro X fuels
DBL15 is offline   Reply With Quote
Old 06-13-2012, 08:44 PM   #6524
Konich's Avatar
Anyone running the aluminum rear hubs? If you are what location/washers are you using?
Tresrey Spec DEX410 - Yaiba Spec B5M
Konich is offline   Reply With Quote
Old 06-13-2012, 09:06 PM   #6525
Azagar's Avatar
I use the aluminum hubs, my current setup is middle location with 2 2mm Durango caster block spacers on both sides. For the ball stud I use second to the end starting from the left and using 4mm spacers underneath, (3mm and 1mm Durango caster block spacers) that's only because the Lunsford ball studs are 1mm longer and the hubs don't have enough thread in them to only use a 3mm spacer. It's slightly loose which in my opinion would put too much stress on the hub if a hard hit were to happen. But it has no problem clearing the rear rim and in fact is almost the exact angle of the turnbuckle from the stock hubs.
If anyone is interested the aluminium hubs happen to weigh 10g vs the stock plastic at 6g. A nice upgrade for bling and durability without adding weight overall there only con is the huge price tag.
Team Durango DEX210
Avid | AKA | Exotek | Jconcepts | KO Propo | Lunsford | Tekin | Turnigy Nano-tech
Azagar is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16581 Yesterday 03:23 PM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-08-2017 12:57 AM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 10:51 PM
