Like Tree24Likes
Old 06-10-2012, 10:37 AM   #6466
heygobenny's Avatar
Hey guys, I'm going to buy the Dex210 and I want to know what u guys are running in them? Motors, servos, etc. Also what upgrades you would recommend. I was looking at carbon fiber shock towers. And finally what spare parts I should buy or what is a weak point on it? I would really appreciate any feed back on this. Thanks.
heygobenny is offline   Reply With Quote
Old 06-10-2012, 12:34 PM   #6467
VintageFrog1's Avatar
Trader Rating: 40 (100%+)
Originally Posted by Cspurlock View Post
Mine is the same. I just snug them gently and it seems to be fine, but if you go too tight it will bind.
Cheers for the response mate, much appreciated
VintageFrog1 is offline   Reply With Quote
Old 06-10-2012, 03:46 PM   #6468
Trader Rating: 43 (100%+)
Has anyone found a BETTER shock O-ring?? The stock ones are just junk. They leak when new and are tight on the shock shaft before you even put oil on them. This = a junk shock in my opinion.
Tony Drimel. WCRC. www.windycityrc.com
Blade 270CFX,230S,180CFX,Nano
Trex 450L Dominator
Yokomo YZ2 CA, YZ4
A800A, USGT, USVTA
tonyd is offline   Reply With Quote
Old 06-10-2012, 05:17 PM   #6469
Trader Rating: 520 (100%+)
I have been using Kyosho seals on my 210, they work well...
flame56mx is offline   Reply With Quote
Old 06-10-2012, 07:12 PM   #6470
DBL15's Avatar
wow i have three durango buggy's and car's all with big bores and not 1 of my shocks leak
there is nothing wrong with the o rings are you using green slime or something like that ?
C/O Coast2coastrc (www.coast2coastrc.com.au) SMC Lipo
Tekno Rc , Team Tekin , Panther-Rc , De Racing , Upgrade Rc , Team Triton rc , M2C clutches , Nitro X fuels
DBL15 is offline   Reply With Quote
Old 06-10-2012, 07:36 PM   #6471
Trader Rating: 31 (100%+)
+1
I use green slime too
MBX6-ECO, B5m
Cspurlock is offline   Reply With Quote
Old 06-10-2012, 07:42 PM   #6472
No but if you think your shocks are fine then empty the oil and clean real good then oil o ring and slide it over the shock shaft and feel how much resistance there is. All of that resistance works out to be about 10 weight in oil when your done putting your shocks together. So I am looking for a better seal like a kyosho p3 grooved o-ring or something close.
Trex 450L Dominator
Yokomo YZ2 CA, YZ4
A800A, USGT, USVTA
Old 06-10-2012, 08:01 PM   #6473
heygobenny's Avatar
What shocks are you using?
Old 06-10-2012, 08:36 PM   #6474
DBL15's Avatar
big bores mate
yes so what they get a bit of dirt in the shock oil
but if your a racer then you should be changing your shock oils before race days anyway and it should never be a problem
i rebuild my big bores heapds of times before i replace the O rings etc
green slime and build away if your changing the oils in the shocks like there meant to there should be no problem
on a different note
Tresrey rear hubs ? anone got a part number i have searched Tower like someone posted as they were there? but i cant find any and want to place a order with Tresrey as the plastic hexs are binding if i titghten the wheel nuts up to much
Old 06-10-2012, 10:03 PM   #6475
SLOWINSLOWOUT's Avatar
Trader Rating: 19 (100%+)
What you are describing is called 'stiction' in the dirtbike world. It can effect handling, but only really in hi-speed damping(speed of shock shaft, not vehicle), such as a small bump or rock on the track, not landing from a double for example. There are a few things that can cause it. The o-rings are definitely one of them, BUT. Make sure you do not have too much compression on the o-rings from the nut, you may find that something is not assembled correctly in the seal head, or, you just cranked the bottom nut too tight. Barring that, you could try sanding the guides down abit, to lessen the preload on the o-rings. Another thing to look at is the shafts, the kit ones are not finished all that good IMO, give them a polish, helps alot. Or you could get the Ti coated ones. If any of the aforementioned are the cause, just putting in different o-rings wont really solve your problem.
SLOWINSLOWOUT is offline   Reply With Quote
Old 06-10-2012, 11:52 PM   #6476
Trader Rating: 23 (100%+)
Will a standard size servo like a savox 1258 fit in this buggy? Or do I need a low pro?
chevmaro is offline   Reply With Quote
Old 06-11-2012, 12:23 AM   #6477
DBL15's Avatar
standards fit fine mate i am using full size hitech 7955tg and it fits perfect
Old 06-11-2012, 02:46 AM   #6478
I tried the kyosho seals but found that they do need extra spacers added in to make them work as they are not a direct replacement.
Schumacher K2, KF2, K1, KF | TeamC TM2 V1, TM4 | Durango DEX410 V3 | T-Rex 450SEV2,250SE | EMAX 250 | Gravity 250 | KC250
AmiSMB is offline   Reply With Quote
Old 06-11-2012, 04:01 AM   #6479
Matt Howard's Avatar
big bores mate
on a different note
Tresrey usa is where I got mine
http://www.tresrey-usa.com/tresrey-a...eel-hub-clamp/
I was having the same problem with the rear wheels binding a bit when you tighten down the wheel nut, no problems with the tresrey rear hexes.
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 06-11-2012, 05:10 AM   #6480
Trader Rating: 109 (100%+)
Send a message via AIM to kwiksi
Nothing wrong with em. Use green slime. No junk BB's here. Love em.
kwiksi is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16564 08-19-2017 05:06 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
