Like Tree23Likes
Old 05-31-2012, 10:04 AM   #6286
Trader Rating: 17 (100%+)
Installing gear diff today. I run on a blue groove track that ocassionally gets dusty. I'm planning on using Kyosho 1000 wt diff oil. I've seen people posting that hey just coat gears in black grease. Which way should I go.?
meddman is offline   Reply With Quote
Old 05-31-2012, 10:24 AM   #6287
murky123's Avatar
just coat the gears with black grease or use shockoil somewhat around 45 and 55 wt.
I have tried 1000cst and it felt like a spool
AE SC10 4x4, Durango DEX210 + DESC210R, HB D413
www.rcracing.nl www.mvb.nl
murky123 is offline   Reply With Quote
Old 05-31-2012, 10:48 AM   #6288
Trader Rating: 49 (100%+)
Default Travel Bag
Anyone have a favorite bag they store/transport their buggy in?
Garnold is offline   Reply With Quote
Old 05-31-2012, 11:45 AM   #6289
aloksatoor's Avatar
Trader Rating: 42 (100%+)
Nope just a avro mills stackable container
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 05-31-2012, 05:09 PM   #6290
Trader Rating: 31 (100%+)
Can you describe what you meant by felt like a spool? I have 1k in mine and I think it feels fine, but was curious if it would be better with grease in it so I am interested as to what you felt the difference was?
MBX6-ECO, B5m
Cspurlock is offline   Reply With Quote
Old 05-31-2012, 05:30 PM   #6291
Panic09's Avatar
I see a few people changing to the gear diff ? Are you guys happy with it? I had one in my rb5 and it felt slow. Didn't have the direct feel that you can get from a ball diff...
"I was so far behind I thought I was first"
MIKES RC WORLD(r.i.p) | TACOMA RC RACEWAY | FOUR SEASONS RC RACEWAY(r.i.p) | ISLAND RACEWAY
Panic09 is offline   Reply With Quote
Old 05-31-2012, 05:42 PM   #6292
Trader Rating: 21 (100%+)
I'm loving this ball diff. So much better than the Kyosho and AE. Been running it for a couple of month..... Still butter smooth
Kyosho Rb6.6
Kyosho ZX6.6
Kyosho Rt6
kerby is offline   Reply With Quote
Old 05-31-2012, 06:22 PM   #6293
nolimit208's Avatar
Send a message via AIM to nolimit208 Send a message via MSN to nolimit208
I really like my gear diff. I use black grease, had tried other fluids in it but it seemed to push when exiting corners on throttle.
nolimit208 is offline   Reply With Quote
Old 05-31-2012, 06:48 PM   #6294
Trader Rating: 74 (100%+)
B fast ball diff for me. Never again on the gear diff.
Serpent USA www.serpentamerica.com, King Max Servos, Gens Ace, MIP, www.miponline.com,Schelle , WWW. Schelleracing.com, Slavich Designs, GARCIA GRAPHIX
CHECK OUT GARCIA GRAPHIX ON FACEBOOK -LOOKING FOR 2017 TEAM DRIVER'S!
Raul Garcia is offline   Reply With Quote
Old 05-31-2012, 06:50 PM   #6295
I use me Atomik-RC hauler. It works great. The only hauler I've seen that has draws you bolt together.
Old 05-31-2012, 07:12 PM   #6296
Ray Kindstrom's Avatar
Trader Rating: 147 (100%+)
Ever hear the slogan "There's no wrong way to eat a Reece's"? That's the way I feel about the gear diff/ball diff question. I've run both on about every current vehicle on the market. One is better in some section and the other is better on other sections. I like the "connected" feel of a ball diff and the ease of maintenance of a gear diff. I'm a set it and forget it kinda guy, that's why I run the B-fast stuff. I always suggest you try both and see what YOU like the best. I've taken the diff out of the 210 a bunch of times....it's easier to adjust the screw than it is to change oil/grease.
Ray Kindstrom is offline   Reply With Quote
Old 05-31-2012, 07:50 PM   #6297
I put the gear diff in and omg....smooth smooth smooth. Just put some black grease in and away we went. A relation was awesome. No push. Of course with battery pushed all the way up. Stock front springs. Losi white in rear. 30 /25 shock oil. 23 mm ride height. Set slipper. Easy peasy. No maint for awhile.
Thing jumps like a dream. On rough long straight it just kept pulling and stayed planted. Traction for days.
Old 05-31-2012, 09:06 PM   #6298
aloksatoor's Avatar
Anyone messed with the droop settings? I have an extra set of shocks I setup tonight to have around 4mm limiters for fronts and 3 mm for rears. I got sick of the drive shaft bind/noise on full droop on rears. So went ahead and did all 4 shocks with internal limiters.
Can never get the screw droop consistent since I end up eyeballing it . Will do some testing this race weekend. I think I will end up with zero droop once again since my track's pretty rough but at least the cars super quiet on the bench now with rear droop.
Have an itch again to do something different . First things gonna be the annoying brace which connects top of gearbox to the lower chassis brace. That's going to be replaced with 2 titanium turnbuckles (sv2 style). Should clean up airflow/wiring around ESC (which btw is in my battery tray).
Next making a CF right angle channel to mount the esc as far back as possible (maybe even sideways) and the modified cf battery strap of course since the rear brace won't be there to press the stock strap down.
Old 05-31-2012, 11:11 PM   #6299
Tunatsol's Avatar
Plz post pics of it that sounds like somthing i would like to try
Josh Youngs
Team Durango: DNX8, Dex8, 408, 210, 410v3,
Sponsored By: Dialed Hobbies
Tunatsol is offline   Reply With Quote
Old 06-01-2012, 01:42 AM   #6300
murky123's Avatar
feeling like a spool, I ment : to heavy, to tight.. resulting that the back of the car like to step out when going on throttle.
this is on low traction surface
I now run 50wt losi shock oil in mine, and the gear diff just keep getting better and better every run. smoother and smoother.
I do think that a gear diff is not for dirt out door tracks, but more for high traction carpet indoor tracks.
On dirt you should always run a ball diff for the best feeling.
But Im lazy and I do not feel like setting and tunning a ball diff between heats, that is why I run a gear diff
St Ives RC Club B4Bandit Australian Racing 16564 Yesterday 05:06 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
stoopideric
