Like Tree27Likes
Old 05-28-2012, 07:36 PM   #6256
BOLISARIO's Avatar
Trader Rating: 57 (100%+)
Send a message via AIM to BOLISARIO
Originally Posted by Jonny5 View Post
Very weird about the shafts, but I polish mine (and hinge pins) on initial build anyways.
I started using the orings off the regular bore shocks for the cap seals. They require more stretch to get them on, making them a bit smaller. That coupled with a chamfer on the cap and no issues at all.
What's the part number for the regular bore orings? I'm almost done with my build and all I have left to do are the shocks. I'm assuming these are the same shocks used on the DESC410R which I have no problem with leaks. Are other 210 owners experiencing shock leakage from the bottom seals AND cap seals?
BOLISARIO is offline   Reply With Quote
Old 05-28-2012, 08:01 PM   #6257
hacker's Avatar
Trader Rating: 140 (100%+)
RTFM
hacker is offline   Reply With Quote
Old 05-28-2012, 08:08 PM   #6258
Autocratic's Avatar
Trader Rating: 26 (100%+)
Originally Posted by hacker View Post
RTFM
Don't think reading the manual has anything to do with it.
The stock BB cap o-rings just suck. Even after beveling the edges I still had leaks. I moved to the small bore cap o-rings and haven't had an issue since.
Thanks to my sponsors for 2015!
XFactory RC | Proline Racing | Fantom Racing | Avid RC | Speed Passion USA | Factory1 | Hy-Traction Juice | Mike's Hobby Shop
Autocratic is offline   Reply With Quote
Old 05-28-2012, 08:08 PM   #6259
aloksatoor's Avatar
Trader Rating: 42 (100%+)
Originally Posted by Garnold View Post
So I was just about ready to pull the trigger on a Hitech HS-7945TH servo when I came across this SC-1251MG low profile servo here on this thread. Is it better to have a low profile servo for this buggy? Are the too even in the same league with each other? Can I get some feedback from folks that have used either and they 2 cents. Right now I'm running a HS-5645MG, would it even be worth the upgrade? Thanks
Don't buy that servo (1251 low pro). I had that in the cougar and it broke very quickly. The gears strip too easily. Instead put a little more $$ and get the 1258/1257 savox way better titanium geared servos. None have given any sort of trouble after 6 months!!!
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 05-28-2012, 08:12 PM   #6260
BOLISARIO's Avatar
RTFM
DNFTT
Old 05-28-2012, 09:50 PM   #6261
Trader Rating: 138 (100%+)
An Update to my setup sheet under John Copeland at PetitRC. I changed my oils from 25 AE in the back to 27.5, and front from 27.5 to 30 AE in the front. Dialed. Everything else the same, the best the car has ever been. leaving AE cars in turns in the dust along with Losi 22's. This is medium bite setup with shorty lipos. Car was on Rails Running with pretty much no tred left Barcoes front and rear. I am trying the B4.1 Hex mod next with Losi 22 rims to get the correct offset. No Spacers.
TLR 22T 3.0, 2X Yokomo YZ-2 DTM, B64D (Temporqary 4 wheel), Mugen MBX7R Eco, Hobbywing, Futaba, LRH Hobbies, Amain Hobbies, iCharger.
jpcopeland1 is offline   Reply With Quote
Old 05-28-2012, 10:05 PM   #6262
Tunatsol's Avatar
Originally Posted by DBL15 View Post
tiny bit of black grease just to coat the thing not full thats for sure
smooth as silk and i like it better then ball diff
running my gear diff with black AE full and its still smooth as glass and i to like it better than the ball diff indoor mid bit carpet
Josh Youngs
Team Durango: DNX8, Dex8, 408, 210, 410v3,
Sponsored By: Dialed Hobbies
Tunatsol is offline   Reply With Quote
Old 05-28-2012, 10:14 PM   #6263
Never had an issue with them from the start.
Old 05-28-2012, 10:21 PM   #6264
Carpet begs for Mid Motors, I took a trip last year to Vancouver with my Cougar and it was the fastest damn car on carpet, on clay, non-blue groove tracks it was aweful no side bite at all. Spent nearly $200.00 on the newish Brass back plane for the chassis, and the exteneded 8mm CF Chassis, did me no good unless the clay tracks were soaked and traction was at a premium.Which didnt last long enough for me to get the traction needed becauser of Short Brain (SC trucks), Nowe my setup which I spent 8 hours on changing shock oils give me the rear motor advantage, whith the steering of a Mid Motor car. Nobreaking loose, no side stepping on jumps that land you directly into a turn, The buggy is Totally diealed, best 10Th Scale buggy I have ever driven, and that is not a short list. RB5 Worlds before it was a world, B4.1 before it was a worlds, and a Perfectly Setup 22. The Car is dialed, Perfect, so dialed. Sorry, just a bit drunk (holidays!) YAY! but I was beating Sponsored drivers in makshift stock clas races at OC/RC.
Old 05-29-2012, 04:03 AM   #6265
Trader Rating: 49 (100%+)
So are you more a fan of the Savox servos over the Hitech? I first was thinking about the Hitech ti servo. A little pricey but since I have the servo horns (and spares) plus already use them in other trucks I thought that was the way to go. Just never knew about these low pro servos and thought I should ask. Are they even worth looking into?
Savox do seem a lot cheaper though and might be worth considering switching?
Garnold is offline   Reply With Quote
Old 05-29-2012, 04:13 AM   #6266
rcjunky1's Avatar
the couger just destroys servo gears, everyone local that had one (we ran on carpet) was destroying servo gears until they put a modded servo saver (not much room) mean while all the 22s were fine and now the 210's, no one had issues without servo savers except the couger. Theres nothing wrong with the 1251, but I'd always go for a full sized servo if you have space, the motors are bigger and much better.
Official distributor of Dan-O-Mite Custom Parts- Durango 210 RF pivot blocks
Andrew Butters' Burghgraef
Team Durango Canada
Great Hobbies, Hobbico, Skyrc, Exotek
rcjunky1 is offline   Reply With Quote
Old 05-29-2012, 04:16 AM   #6267
I didn't realize the big price difference with Hitech servos and Savox servos. Are the Savox servos as good? I mean it's a really big difference! Might be worth switching over to them.
Old 05-29-2012, 04:41 AM   #6268
hacker's Avatar
He wanted part number for original bore orings.
Download the dex410 manual and look it up yourself ya lazy biatch
You guys need to use oil on the orings, and not nip it up too tight, and yes i did initially tighten it up too much but not anymore.
Old 05-29-2012, 05:12 AM   #6269
kwiksi's Avatar
Trader Rating: 109 (100%+)
Send a message via AIM to kwiksi
No leakage or rip on my orings.
Thanks in 2017 to
Xray/RC America - JConcepts - Trinity - Sanwa - Hobbywing - Exotek - PT Racing Oils -Schelle
kwiksi is offline   Reply With Quote
Old 05-29-2012, 05:15 AM   #6270
BOLISARIO's Avatar
Hypocrisy comes in all forms....especially in troll form:
Viper RC -
Practice what you preach "ya lazy biatch."
St Ives RC Club B4Bandit Australian Racing 16572 10-14-2017 01:35 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
