Like Tree43Likes
Old 05-28-2012, 09:51 AM   #6241
Trader Rating: 316 (100%+)
For the gear diff do you guys use oils or black grease?
Jermaine Mitchell
I laugh at serious racers acting like B****
Free Agent racing team. No sponsors needed.
Mercenary Racer
jmoneym is offline   Reply With Quote
Old 05-28-2012, 10:40 AM   #6242
Trader Rating: 19 (100%+)
Originally Posted by SLOWINSLOWOUT View Post
Ya, the shafts kinda through me for sure, they didnt look too bad when I was putting them together, figured it was some tarnish or some thing and would clean off with some oil, wrong!! Ended up chucking them in the drill and polishing with some compound, they are good now, but not some thing I thought I'd be doing to new parts.
I have some large diameter counter sinking bits, might see if one of those would work to put a shampfer on the inside of the caps. The cap to body seal is a bad design, should have better provision for the o-ring to be captured.
Very weird about the shafts, but I polish mine (and hinge pins) on initial build anyways.
I started using the orings off the regular bore shocks for the cap seals. They require more stretch to get them on, making them a bit smaller. That coupled with a chamfer on the cap and no issues at all.
XRAY, RC America, MOTIV, Sanwa, Arrowmax, Neverlift Racing Apparel
Jonny5ive Designs- by racers, for racers!
Jonny5 is offline   Reply With Quote
Old 05-28-2012, 11:15 AM   #6243
Trader Rating: 17 (100%+)
No one using gear diffs?
meddman is offline   Reply With Quote
Old 05-28-2012, 12:09 PM   #6244
murky123's Avatar
I run on hardpacked dirt, and use 50WT Losi shock oilt in the durango gear diff
AE SC10 4x4, Durango DEX210 + DESC210R, HB D413
www.rcracing.nl www.mvb.nl
murky123 is offline   Reply With Quote
Old 05-28-2012, 12:30 PM   #6245
Trader Rating: 139 (100%+)
I havent bothered ordering one since the Ball Diff is so good on the car.
TLR 22T 3.0 (Retired), XRAY XB4 '18, 2X Yokomo YZ-2 DTM, YZ-4 SF (please hurry), Mugen MBX7R Eco, Hobbywing, Futaba, LRH Hobbies, Amain Hobbies, iCharger.
jpcopeland1 is offline   Reply With Quote
Old 05-28-2012, 12:31 PM   #6246
Thats a good idea, I have some old AE shocks around here I could try the rings on.
Old 05-28-2012, 12:39 PM   #6247
Tunatsol's Avatar
I'm useong AE black with AE green slime on the xrings
Josh Youngs
Team Durango: DNX8, Dex8, 408, 210, 410v3,
Sponsored By: Dialed Hobbies
Tunatsol is offline   Reply With Quote
Old 05-28-2012, 12:40 PM   #6248
kwiksi's Avatar
Trader Rating: 109 (100%+)
Send a message via AIM to kwiksi
+1
Thanks in 2017 to
Xray/RC America - JConcepts - Trinity - Sanwa - Hobbywing - Exotek - PT Racing Oils -Schelle
kwiksi is offline   Reply With Quote
Old 05-28-2012, 01:08 PM   #6249
I'm using on the gear diff 50000 cps on carpet and 20000 on astro turf.
supra is offline   Reply With Quote
Old 05-28-2012, 01:18 PM   #6250
Recommendations for dirt? Blue groove
Old 05-28-2012, 02:30 PM   #6251
nolimit208's Avatar
Send a message via AIM to nolimit208 Send a message via MSN to nolimit208
I run on blue groove and use a little bit of the black grease.
nolimit208 is offline   Reply With Quote
Old 05-28-2012, 04:20 PM   #6252
evostyle's Avatar
Trader Rating: 102 (98%+)
mine's for sale
Team Durango DEX210 2wd buggy like NEW ( not AE losi nib )
"If you no longer go for the gap that exist, you are no longer racing". Ayrton Senna
evostyle is online now   Reply With Quote
Old 05-28-2012, 07:06 PM   #6253
DBL15's Avatar
tiny bit of black grease just to coat the thing not full thats for sure
smooth as silk and i like it better then ball diff
C/O Coast2coastrc (www.coast2coastrc.com.au) SMC Lipo
Tekno Rc , Team Tekin , Panther-Rc , De Racing , Upgrade Rc , Team Triton rc , M2C clutches , Nitro X fuels
DBL15 is offline   Reply With Quote
Old 05-28-2012, 07:09 PM   #6254
Trader Rating: 49 (100%+)
So I was just about ready to pull the trigger on a Hitech HS-7945TH servo when I came across this SC-1251MG low profile servo here on this thread. Is it better to have a low profile servo for this buggy? Are the too even in the same league with each other? Can I get some feedback from folks that have used either and they 2 cents. Right now I'm running a HS-5645MG, would it even be worth the upgrade? Thanks
Garnold is offline   Reply With Quote
Old 05-28-2012, 08:19 PM   #6255
BOLISARIO's Avatar
Trader Rating: 57 (100%+)
Send a message via AIM to BOLISARIO
+1
I'm using black grease lightly coated on the gears for indoor clay.
BOLISARIO is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16581 Yesterday 03:23 PM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-08-2017 12:57 AM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 10:51 PM
