Like Tree26Likes
Old 05-25-2012, 01:44 PM   #6196
BOLISARIO's Avatar
Trader Rating: 57 (100%+)
Send a message via AIM to BOLISARIO
I finally started my build and have a couple of questions:
For guys using the TLR 22 aluminum servo arm, are you able to still use the stock 3x6mm screw that attaches to the horn arm? Mine won't screw in and it the horn seems to be threaded for standard.
Also, for the Cap America bump steer mod, the end of the inner ball stud still sticks out of the lock nut even after placing a 1mm spacer under the ball stud. I ended up using the stock lock nut. Is that ok or do i need to raise the ball stud higher?
BOLISARIO is offline   Reply With Quote
Old 05-25-2012, 01:54 PM   #6197
Trader Rating: 19 (100%+)
I noticed the same thing with the servo horn- seems odd since the 22 is a metric car... I just ran a 3mm tap through it. Dab of loctite and it's all good.
Someone else will have to chime in on the steering rack mod- we're still running stock configuration.
Serpent America/Desoto Racing- www.serpentamerica.com
TrakPower Speed Equipment- www.trakpowerusa.com
B Fast RC Performance- www.bfastrc.com
Futaba | Strictly R/C- Norridge, IL
Thank you all for the help and support!
Jonny5 is offline   Reply With Quote
Old 05-25-2012, 02:11 PM   #6198
Cream's Avatar
Another new item for anyone that's interested for the DEX210,
I've produced both a mammoth brass version weighing in at 64g and a lighter 22g high tensile aluminuim version.
Both are identical in design, retaining the droop screw stops and adding a hinge pin lock.
Prices are
Brass 25.00
Aluminium 22.00
Postage is....
U.K. 2.35 recorded
Europe 8.45 recorded (2.70 un-recorded @ your risk)
non European countries 8.95 (3.30 un-recorded @ your risk)
Payment is via paypal as a gift or add 4% of total order inc. delivery to cover paypal charges.
Check out my feedback on http://www.oople.com/forums/showthread.php?t=19612 if you have any concerns.
Cream Extreme R.C.
http://www.oople.com/forums/forumdisplay.php?f=219
Cream is offline   Reply With Quote
Old 05-25-2012, 03:30 PM   #6199
Trader Rating: 520 (100%+)
Prices are
Brass 25.00
Aluminium 22.00
Postage is....
U.K. 2.35 recorded
Nice work Noel, amazing workmanship once again..are these going to be available thorough Tresrey USA
flame56mx is offline   Reply With Quote
Old 05-25-2012, 03:53 PM   #6200
aloksatoor's Avatar
Trader Rating: 42 (100%+)
Weird I used a drill to put the screw in the tlr22 horn and it stuck proper. Maybe an old batch? Anyways for the capt america mod, you should use a shorter ball stud with a non lock tite nut for safe clearance. I have all lunsford buckles cups with losi 6mm 4.8 ball studs. The durango is not really 4.8 mm so had to change out to losi.
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 05-25-2012, 04:02 PM   #6201
Cream's Avatar
No not at the moment, These are the first batch. Kind of a market tester
Cream Extreme R.C.
Old 05-25-2012, 05:20 PM   #6202
BOLISARIO's Avatar
Since I don't have the Lunsford's, maybe I should just use a dremel and cut off the exposed screw threads that stick out of the lock nut?
Old 05-25-2012, 06:33 PM   #6203
jackcarter3's Avatar
may be dating myself here..... just got done skimming this whole thread and noticed a lot of 'seasoned' r/c vets had trouble with the build and complained of poor instructions. i am not saying i had no issues or had to stare at things a little longer than normal and no this build isn't as easy as a b4 but, how many of you succesfully built a schumacher cat in the late 80's? i dont think a company has ever put out a worse manual than that. and these are cars for experienced r/c people, not newbs. anyway, end of rant......
jackcarter3 is offline   Reply With Quote
Old 05-25-2012, 06:36 PM   #6204
aloksatoor's Avatar
Yep should work . I would use a sander myself horrible with hand held tools .
Old 05-25-2012, 07:28 PM   #6205
Jmuck69's Avatar
Neat new item.
http://www.tresrey.com/tresrey/produ...td080_eng.html
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 05-25-2012, 07:47 PM   #6206
Konich's Avatar
Who doesn't like a little radial cooling?
Tresrey Spec DEX410 - Yaiba Spec B5M
Konich is offline   Reply With Quote
Old 05-25-2012, 07:49 PM   #6207
FrEaKiShTuNER's Avatar
Trader Rating: 200 (100%+)
Function and looks!! hard to beat..
~AdamQ~
**Lower feedback ships first**
FrEaKiShTuNER is offline   Reply With Quote
Old 05-25-2012, 07:50 PM   #6208
Jmuck69's Avatar
So does the button screw on to the lower screw and then plugs into the enlarged hole to keep it from twisting? Why did that sound dirty??
B6D | B64D
Old 05-25-2012, 07:52 PM   #6209
Konich's Avatar
Yes it replaces the stock plastic bushing.
Old 05-25-2012, 08:50 PM   #6210
Trader Rating: 74 (100%+)
New red stuff, yeahhhh...... Looks good Dave.
Team and Sales Manager for USRC Imports, home of Sworkz! Looking for drivers for 2017-2018, KingMax Servos www.kingmaxhobby.com Gens Ace www.gensace.com, MIP www.miponline.com,Schelle , WWW. Schelleracing.com, Slavich Designs, GARCIA GRAPHIX
CHECK OUT GARCIA GRAPHIX ON FACEBOOK -LOOKING FOR 2017 TEAM DRIVER'S!
Raul Garcia is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16568 09-15-2017 05:07 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
