Durango DEX210 Thread
#6077
#6079
More red sexiness from Tresrey: http://tresreyusa.blogspot.com/2012/...shing.html?m=1
#6080
Im getting back into the hobby after 15+ years away. I was going to buy an associated but i like the looks of this and the cougar sv2. I know schumacher has been around a long time but if i buy a durango how long have they been in business? I dont want to buy a car and then i cant get parts. I wont have 10 cars like some of you my wife will not like that alot...lol. I like being a bit diffrent and the quality of these 2 intrigues me. There is no dealer that i can find near me here in st louis. Is it hard to get parts? If so what should i buy in advance to have on hand? Im guessing a-arms and other suspension parts. Anything else? If you have or have ran both cars id really love to hear how they compare. Thank you.
#6081
#6083
#6084
#6086
I had a Schumacher Cougar SV. Could not get mid motor to work unless I was on a high bite blue groove track. As far as spares, towers (unless you go the Tresrey route and get carbon fibre towers), Ball cups in case you pop one off, Upgraded Ackerman link (a few different companies make aftermarker parts like Tresrey, FTW, etc...) Mine has been rock solid out of the box, only thing I changed was ackerman plate and I have taken some nasty tumbles that would have broken any other car. Got landed on my an 8th scale car trying to quad a set of doubles was going very fast and got mega air, no problem. The car in stock form is very tough. I would also HIGHLY recommend you get a b-fast diff kit for it, the stock steel balls will fry on you if you dont watch out for how tight your diff is. Car likes a tight diff.
Thoughts?
#6087
Agreed on the durability. The rango's front end is a 1/9th scale car instead of 1/10!! The way it handles bad driving (by me) is amazing.
I was replacing cougar arms almost every race weeked with a mod motor (that car is now retired to 17.5 blinky duty if enough ppl show up at my track to run that class!!). In 3 months with around 10 race/practice days, I have broken one rear arm while testing a brand new 6.5 crashing sideways.
With regards to handling, I still like the cougar better (have never run the rango in mid motor). Parts quality and fit and finish on the cougar is still better than the rango and if you plan to run ONLY indoors on super high bite tracks as jp had mentioned then this car is good.
As an all rounder (with hopefully LHS support soon) I would go with the rango 9 times outa 10
#6088
#6089
I ran a Cougar at WCRC. When the track was wet and traction was up , the car was good, when the track dried out and traction went away so did the car. Outdoor blue groove, and indoor carpet, astroturf, is what the car was designed to be run on, and that is where it excels. Any other condition and mid-motor is pretty much useless due to the rear end stepping out on you under accelleration exiting turns. They jump better, and turn better, But I have yet to see a mid-motor configuration that works on clay tracks due to the unstableness of the surface it's self. Hell even Losi gave up on trying to get the 22 to work on clay in mid motor.
#6090
ya the durango is tuff havent broken a thing yet but pop ball cups off put the b-fast diff in but the carbon thrust balls and washers must be shorter cant get it to tighen up.or the circle clip is bent only have one. anybody tell me whats up with that.do i have to use the original washers?
