Like Tree24Likes
Old 05-17-2012, 09:41 AM   #6046
Trader Rating: 137 (100%+)
Originally Posted by Jmuck69 View Post
The stock shafts are too long, get the optional TD gold shafts. They are 2mm shorter and the piston will be flush with the top of the body.
-1 on gold
+1 on black ti
lol....
TLR 22T 3.0, TLR 22-4 2.0 , TLR 22 4.0 X2, 22SCT 3.0, Tekno SCT 4X4, Hobbywing, Futaba, LRH Hobbies, Spektrum Servos, iCharger.
jpcopeland1 is offline   Reply With Quote
Old 05-17-2012, 12:27 PM   #6047
Jmuck69's Avatar
Originally Posted by jpcopeland1 View Post
-1 on gold
+1 on black ti
lol....
I like the gold shaft since they match my gold teeth.
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 05-17-2012, 12:57 PM   #6048
Guys, will the 12mm bigbore springs from Losi or Avid work on the Dex210 shocks? got whole bunch left over from the B4 BB conversion.
GuiltyByAssoc is offline   Reply With Quote
Old 05-17-2012, 01:15 PM   #6049
Slimsh8t's Avatar
Trader Rating: 39 (100%+)
Yep
Kevin Murphy
Associated B5m/Reedy
AP Custom Paint/Kal-Gard/
Slimsh8t is offline   Reply With Quote
Old 05-17-2012, 02:03 PM   #6050
Jmuck69's Avatar
I have the AVIDS on mine as we speak and work great. Red fronts and rears
B6D | B64D
Old 05-17-2012, 02:34 PM   #6051
Doitinthedirt's Avatar
So here is my question of the day...what other shock caps will fit on the Big bore if any?
22?
www.radiopost.com
Doitinthedirt is offline   Reply With Quote
Old 05-17-2012, 03:05 PM   #6052
DBL15's Avatar
ok gearing question guys i am curently running 10.5 T with small amount of boost with 87 / 25 gearing
now i see on here a lot of people running 83 or even 81 spurs if i was to keep the 25 pinon what does a smaller spur do ? more top speed or more torque etc ?
C/O Coast2coastrc (www.coast2coastrc.com.au) SMC Lipo
Tekno Rc , Team Tekin , Panther-Rc , De Racing , Upgrade Rc , Team Triton rc , M2C clutches , Nitro X fuels
DBL15 is offline   Reply With Quote
Old 05-17-2012, 03:12 PM   #6053
Smaller spur= more top speed. Btw I'm running a hpi 10.5 with 76 spur and 29 pinion + boost. I think you can gear up a lot.
Yellow Wheels is offline   Reply With Quote
Old 05-17-2012, 03:27 PM   #6054
DBL15's Avatar
temps would say that as well as i only get to 40 deg C after 10 to 15 mins run
but i dont want it to be uncontrollable when you pull the trigger i am looking for a bit more top speed but no more low end torque etc as i have plenty to make all the jumps with out it being to wild out of slow speed corners etc
Old 05-17-2012, 03:28 PM   #6055
FrEaKiShTuNER's Avatar
Trader Rating: 200 (100%+)
I'm running a 75/26 with a tekin 10.5 and it's pretty dialed for a medium(ish) indoor clay.. No boost or timing as of now.
~AdamQ~
**Lower feedback ships first**
FrEaKiShTuNER is offline   Reply With Quote
Old 05-17-2012, 03:36 PM   #6056
A smaller spur and larger pinion will give more top speed and make the car more driveable. Probably best to start with a smaller spur, this will bring the motor forward a bit (the 210 is a bit heavy in the rear if you run rear motor). Keep an eye on the temperature and go to a bigger pinion if the temps allow.
Old 05-17-2012, 03:41 PM   #6057
DBL15's Avatar
ok i have a RW 81 spur so you think try that with say a 27 pinon ?
so thats 81 / 27 from 87 / 25 ?
is that about right ? or go bigger i think i have a 28 pinon as well
thanks for your help mate
Old 05-17-2012, 03:50 PM   #6058
I think different brands of motors need to be geared differently, but 81/27 seems like a safe place to start. Just keep an eye on the temperature. If it gets hot try a 26, if not try a 28.
Old 05-17-2012, 05:29 PM   #6059
22?
Anyone?
www.radiopost.com
Old 05-17-2012, 05:35 PM   #6060
ChadRacing's Avatar
Does anyone make swaybars for this kit?
ReVtech / Trinity / EAMotorsports
HotShot RC / Nexus Racing
Xray T2 '009 w/Exotek Chassis, BMI DB12rr, Tamiya F104X1
Team Durango DEX210
ChadRacing is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16564 08-19-2017 05:06 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
