Like Tree23Likes
Old 05-14-2012, 08:36 AM   #5941
Trader Rating: 49 (100%+)
That must have been it, I was looking international. Thank you
Hey, on a side note. What spur gears do you all keep in around when you race and pinions? How about the type of pinion I need because I'm not sure if the ones I have now will work?
Garnold is offline   Reply With Quote
Old 05-14-2012, 09:12 AM   #5942
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
Originally Posted by Shimmy View Post
Also, is there a quicker way to get the gearbox out when in rear motor config?
I had the circlip pop out of the diff (fixed out, I didnt double check to make sure it was in properly) when I was breaking it in and the only way I could get the gear box out was to undo pretty much the whole back end.
Other than that though, the buggy seems pretty good.
I omit the screws that come "up" from the bottom of the upper rear trans brace so what only screws that can be reached from above need to be removed. This cuts out about 60 seconds of tear down time to pull the trans.
It's not the fastest but once you do it a few times you'll get it in and out in about 3-5 minutes.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,KoPropUSA,JConcepts,Avid RC,MIP,SikLidz,ImagineItGraphx, FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 05-14-2012, 10:14 AM   #5943
Trader Rating: 19 (100%+)
48p gears on the 210. Spur gear depends on your motor, but for mod if you have an 81 and 83 handy you should be set. Pinions in the 21-25 range will get you going if running in the 7.5-10.5 range. For blinky 17.5 we ran 75/36 with good speed and overall power.
Serpent America/Desoto Racing- www.serpentamerica.com
TrakPower Speed Equipment- www.trakpowerusa.com
B Fast RC Performance- www.bfastrc.com
Futaba | Strictly R/C- Norridge, IL
Thank you all for the help and support!
Jonny5 is offline   Reply With Quote
Old 05-14-2012, 10:19 AM   #5944
Trader Rating: 137 (100%+)
Default Naked DEX210
Here is what the inside of the car looks like. I hate to cut my motor wires because I hate soldering. Battery wires not so much of a problem. This speed control will probably go into either the DEST210, or a DEX410. Havent made up my mind which to get next.
TLR 22T 3.0, TLR 22-4 2.0 , TLR 22 4.0 X2, 22SCT 3.0, Tekno SCT 4X4, Hobbywing, Futaba, LRH Hobbies, Spektrum Servos, iCharger.
jpcopeland1 is offline   Reply With Quote
Old 05-14-2012, 10:41 AM   #5945
I went to Losi Parts House on a good day and bought 1 of every RW Spur gear they had. Pinions wide array starting from 23-35 all Robinson Racing Black Pinion Gears 48 pitch..
Old 05-14-2012, 11:02 AM   #5946
@Jonny5
Thank you for all your info today. I'm very sorry for all these noob questions right now. My motor(s) right now range from 10-13 so I'll pick up a few pinions to accommodate that.
OK so here goes the really noob question, what does blinky mean? Sry man.
Old 05-14-2012, 11:39 AM   #5947
@Jonny5
Blinky is the term for the no-timing setting on an esc. Older esc's like the novak gtb do not have any timing capability, but when Tekin came out with the RS it changed everything. To help with rules enforcement Tekin created a mode on the esc where it "blinks" when it is in no timing mode, and now most others have followed suit.
Old 05-14-2012, 01:09 PM   #5948
Cool looks like that DE10 will work
http://maine-rc-racing.motion-forum....r-blinky-class
Also, I'm guessing all my Slash pinion gears will work too since they are 48p correct?
Old 05-14-2012, 02:34 PM   #5949
Your good there. As long as 48p your good.
Old 05-14-2012, 02:56 PM   #5950
Trader Rating: 520 (100%+)
Hey John, your RM3 work well on a dusty track, I like the RM4, but when the traction comes up a little, my car goes straight..
flame56mx is offline   Reply With Quote
Old 05-14-2012, 03:23 PM   #5951
aloksatoor's Avatar
Trader Rating: 42 (100%+)
try more antisquat if possible or stiffer rear springs.
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 05-14-2012, 03:30 PM   #5952
Can I get some help on what batteries folks are running? I searched this thread and read about "shorties?"
I have some GensAce 5000mAh 40c batteries I use in my SCT, will these be good? Maybe something smaller/lighter? I like GensAce batteries but not married to them.
Old 05-14-2012, 03:31 PM   #5953
jspurgin's Avatar
Trader Rating: 198 (100%+)
Iv'e been a Hardcore Associated guy for a while when it came to 1/10 but I recently picked up this buggy and Holy Balls it is incredible lol... Best buggy i have driven yet..
Tha mothaflippin Rhymenocerous..
Cause' there aint' no party like a Nana's tea party....
Southern Onroad F1 Champion.. F109
jspurgin is offline   Reply With Quote
Old 05-14-2012, 03:36 PM   #5954
aloksatoor's Avatar
They were introduced cos the losi 22 had a mid motor option which needed shorter batteries. So the length is 96mm rest of the dimensions are same as ur gens ace. Its just got a bit less capacity. I have tried the promatch 50 $ shorties and the protek 70C shorty. Of course the protek has awesome punch but the promatch are not bad for the price.
Getting a shipment from china for the nanotech shorties. Will let you know how they hold against amains offering.
You can use the gens ace you got it just made the car lazier since this has a lot of weight in the back. With a shorty you can place weight up front which really makes it a different beast. Almost as nimble as a AE/Kyosho buggy but super planted still.
Old 05-14-2012, 03:40 PM   #5955
@aloksatoor
Yes, please give us some feedback on those shorties How much do those cost?
Edit:
Are these the ones?
http://www.hobbyking.com/hobbyking/s...Lipo_Pack.html
St Ives RC Club B4Bandit Australian Racing 16564 08-19-2017 05:06 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
