Like Tree17Likes
Old 05-09-2012, 03:46 PM   #5836
DBL15's Avatar
Originally Posted by BOLISARIO View Post
My kit should be arriving by the end of the week. I decided to get the gear diff set and was wondering what diff oil wt should I use for indoor clay with med-high bite? 650-1000wt or AE black grease?
i have seen on oople that most are using 650cst shock oils in there gear diffs
might be worth a try
i too have 1 on the way as i am not a ball diff fan but not sure what i will build it with either right now grease or shock oils
C/O Coast2coastrc (www.coast2coastrc.com.au) SMC Lipo
Tekno Rc , Team Tekin , Panther-Rc , De Racing , Upgrade Rc , Team Triton rc , M2C clutches , Nitro X fuels
DBL15 is offline   Reply With Quote
Old 05-09-2012, 04:31 PM   #5837
Trader Rating: 19 (100%+)
Originally Posted by aloksatoor View Post
I was on the fence whether to get the bfast kit for stock diff or the gear diff. Went with the ball diff. And boy the bfast feels sooo smooth compared to the geared durango diffs (had only the sc diff to compare)... Let us know what works for you though!
On a side note anyone tried rear anti roll bars yet with really soft springs?
+1 for the BFast diff setup. Buttery goodness!
Originally Posted by murky123 View Post
I do run the geardiff on dirt.
But in my opinion ( and some others ) a gear diff should not be used on dirt. a ball diff gives the buggy better handeling.
a gear diff cant slip.
indoor carpet and surface like that is where a gear diff could be used.
I run the gear diff just because Im lazy in rebuilding balldiffs
With all of the cars we run (mostly my brother), proper maintenance can be tough to keep up on. Ever since we started using the BFast kits in the 210 the diff maintenance is virtually nonexistent. He will wear out the outdrives on his buggy before the diff needs service- it's really quite unbelievable how long their diffs last if you build them right. I won't run anything else in our cars, period.
Serpent America/Desoto Racing- www.serpentamerica.com
TrakPower Speed Equipment- www.trakpowerusa.com
B Fast RC Performance- www.bfastrc.com
Futaba | Strictly R/C- Norridge, IL
Thank you all for the help and support!
Jonny5 is offline   Reply With Quote
Old 05-09-2012, 05:04 PM   #5838
Trader Rating: 21 (100%+)
Where can you get the BFast diff setup for the dex210?
mulepic is offline   Reply With Quote
Old 05-09-2012, 05:45 PM   #5839
Slimsh8t's Avatar
Trader Rating: 39 (100%+)
Bfast direct ..I just installed and broke mine in and it's golden.
Kevin Murphy
Associated B5m/Reedy
AP Custom Paint/Kal-Gard/
Slimsh8t is offline   Reply With Quote
Old 05-09-2012, 05:47 PM   #5840
Do you need the whole kit, or just rings? If it's the kit, which balls are people having success with?
Old 05-09-2012, 06:22 PM   #5841
Slimsh8t's Avatar
I did the kit with the rings & carbide balls & also ordered the caged thrust bearing as well & it's butter.
Kevin Murphy
Old 05-09-2012, 06:41 PM   #5842
Jmuck69's Avatar
My set-up for diffs is BFast Carbide diff balls, Stock TD rings & Schumacher ceramic thrust bearing...buttery and maintenance free.
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 05-09-2012, 06:56 PM   #5843
nolimit208's Avatar
Send a message via AIM to nolimit208 Send a message via MSN to nolimit208
I have a Tacky engine assembly lube in mine. Just enough to coat the gears a little bit and its working very well for me.
nolimit208 is offline   Reply With Quote
Old 05-09-2012, 07:34 PM   #5844
That's making my head spin Is that the generally accepted configuration?
Old 05-09-2012, 08:10 PM   #5845
Straight from their website- http://bfastrc.com/durango.html. Great service to go along with top notch products
Old 05-09-2012, 08:26 PM   #5846
BOLISARIO's Avatar
Trader Rating: 57 (100%+)
Send a message via AIM to BOLISARIO
Yeah me too. I have zero experience with ball diffs and the whole break in and how to properly build them. I prefer the K.I.S.S. approach of a gear diff.
So with AE black grease, it's pretty much a light coat on the gears and that's about it?
BOLISARIO is offline   Reply With Quote
Old 05-09-2012, 08:29 PM   #5847
Jmuck69's Avatar
Why does that make your head spin? Carbide is really the only diff ball that works in the diff and the ceramic thrust assembly is for smoothness and durability. The stock TD diff rings are perfectly flat and smooth.
http://www.amainhobbies.com/product_...g-w-SiNi-Balls
B6D | B64D
Old 05-10-2012, 08:59 AM   #5848
Machined Motor Mount:
Machined Rear Hubs:
Xray XB4 | Kyosho RB6 | Kyosho Rudebits DB2
Chris-s is offline   Reply With Quote
Old 05-10-2012, 09:26 AM   #5849
Slimsh8t's Avatar
What are you guys running for motors in stock 13.5 no boost.?
I'm running a viper system now & want to try something different. My buddy is running Orion & it's smooth but sure is loud in his b4.1
Thinking about ..
Reedy
Lrp
Kevin Murphy
Old 05-10-2012, 09:27 AM   #5850
Machined Rear Hubs:
Love me some vertical ballstud adjustment on the rear hubs. Looks good!
St Ives RC Club B4Bandit Australian Racing 16562 Today 05:07 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
